sgtsampay
C120 evolve to.. C140 Custom
sgtsampay
More photos. (The field photos are what I have completed so far using this deck before the updates along with my C160 hydro. This grass is about 2-3 feet tall and really worked the tractor. Now, yes a real bush hog would be better however, I do not have one I figured I can use what I got and once its cut down, it will be way easier to maintain. This is after him letting it go for about 3 years due to his house burning down and his health going poor for a while.)
 01d3f834-1852-4aa0-a56a-4f3569cc30da.jpg.4c3aba0c46caa6cd20cf554b2e4e1e2c.jpg01a76226-5258-4e5d-964a-675efadf4ffc.jpg.3a9a0ac2d74205af56808ef88900cf56.jpgIMG_1598.JPEG.8f98f12e4375e75dacf36e087c6c6fdf.JPEGIMG_1597.JPEG.9868a771c9599109374f5d5cdd610276.JPEG371b20de-16e8-4047-9e37-b50f1cd61fe6.jpg.9771e12dd24eb913f20c9466d17a5f76.jpg
Edited by sgtsampay
  • Like 4
  • Excellent 3
ebinmaine
5 minutes ago, sgtsampay said:
K341
Niiiiice work!    FYI that'd be a C160.
I like the second fuel tank idea.
sgtsampay
Haha, you got me. I corrected it to K321. LOL. I hope the second fuel tank idea works well. It was very easy to install and get going.
8ntruck
Second fuel tank should be a workable idea.  Seems to me that Wheel Horse had a kit to add a second fuel tank - not a real common item, though.
ebinmaine
Correct. It was a rectangular 5 gallon tank meant to be added to the 500 series tractors behind the seat.
I have a tank here from a Toro zero turn that looks very similar.
Handy Don
Fuel load could easily outlast the operator’s bladder.
  • Haha 3
ebinmaine
Quite true
sgtsampay
Update:
I replaced the battery connectors and then put in a much smaller and way battery CCA battery.
  • Like 4
ebinmaine
11 minutes ago, sgtsampay said:
smaller
Be sure to keep the battery from sliding around in the tray.
I've had to use little chunks of wood and/or felt as "spacers"
sgtsampay
I used chunks of wood for that purpose. Its super snug right now so it should not move..
Pullstart
the world is our bathroom :greetings-clappingyellow:
  • Haha 2
sgtsampay
Update:
so I put jt all back together minus the belt cover. The cover is able to mount due to the idler pulley rubbing against the side of the cover. So I just made the clutch brake on the tractor chassis so I can run the whole thing without the cover.
So during the test drive, I started to test mow. Well two things happened. First the midmount let go due to the spring being weak. I later took it apart and put in a much stronger spring that keep the wheel lock in place. Second thing was how forward the mower deck is pointed. I will be later today, correcting this via the truion in the thread rod.
At least it drives and works correctly the most part.
sgtsampay
Update: so I corrected the mower deck and now it seems to have a blade height of 4.25in at slot 5. So I’m pleased. Slot ; is about 3.75 or so.
I also removed the second set of blades and are just running the gator g6 blades as I felt with the x blade setup the rpm would only go to about 3200rom with the mow deck on and without the second set it will go to about 3460rpm. So clearly the engine was just about maxed out with spinning the dual set of blades and that’s even with it not driving the hydro. I do think there is a difference in power with this deck on my c160 hydro. Which I figured I would t notice due to one being an 8speed and the other a hydro. It’s interesting.
well thank you all for reading about my latest project. It was fun sharing.
ineedanother
Curious what you're using for a tach. I've had this one a little while and it's okay but I'm not in love with it.
sgtsampay
I’m using an engine tach. The blue one on the top let side of the dash. It’s a little slow at times but it also counts the hours as well.
I have not use a lazer tach at work yet to see the pulley speed or anything like that.
ineedanother
Cool. I've got that one here somewhere and used to use it with chainsaws. I remember now that it worked pretty well. Thanks
ebinmaine
How does take the reading?  Wire wrap the plug wire?
ineedanother
Yes, powered with a button battery. I used to velcro it to a hood or dash to watch the speed for one reason or another. It was pretty accurate from what I can remember. I haven't used it in a while.
ebinmaine
I have a tach that uses a tiny piece of reflective material stuck on the rotating item to read rpm. Works fine for tractor checks but I don't see how it would function for a chainsaw.
I should really have a separate tool for those.
ineedanother
I just do 2 strokes by ear now. I just richen them up on the top end to slow them a bit and adjust once see how they do under a full load.
ebinmaine
Same.
sgtsampay
Update:
So I put the new tractor to work on the field finally. It ran very well. I was able to make 3 passes before I  had to go home due to the muffler splitting apart. So I had to order the amazon one that your guys have tried. We will see.
Now, my issue is how the mower deck seems to be running great. Spinning great until the tractor bogs down to about 3 k and then the mower deck seems to drop in speed very fast. The engine doesn't go any lower though. I'm running the tractor in 1 or 2 low as well. At first I was thinking the PTO is slipping but I'm not so sure and i don't want to keep making it tighter in fear it will wreak the bearings. The mule drive belt seems to be very tight as well and its a new belt. What am I missing? Can anyone refresh me about how to confirm the PTO is not to tight? LIke I know when you turn the lever the steering tower will twist a tad along with the engine slightly twists as well. My C160 does the same thing and both have brand new PTO clutch disks.  The C160 also would bog down running this deck and the engine RPM would go down to 2.3k. Then I would stop moving and let the engine catch back up. Any thoughts you guys?
