Simplecity
Just Acquited
Simplecity
Good Afternoon All
 Just acquired rear discharge deck and spare mule drive for the Raider 12.
Can anyone ID the deck? I see not tags on it.
Once my mid mount hitch arrives I should be able to mount and mow.
 Also, the hight adjustment has no markings, so I'll ASSUME that you adjust with a tape measure off of the blade tips.
 Thanks to all who respond
ol550
Looks like the blades are too short. ?
  • Confused 1
peter lena
@Simplecity  what is the width  underside  deck  inner side wall to wall , ?  looks like a 42"  also lucky you !  no baffles !  also no related rot . I have 3  of those , this what my decks look like , how do  spindles sound move , any roughness at all ? have a regular bearing clean out and re grease , with  lucas x tra hd  green chassis grease  , also did my mule  drive bearings , no  noise or bearing whine , what an opportunity  !   mine are  rust free and quietly very solid . BTW  the related pto  lever set up  . is a GOLD MINE  FOR IMPROVEMENT  . did this too. wish you were closer !   ask away , pete
" rear discharge , also lucky yoy
Simplecity
Simplecity
Pete
  It is a 42". Would you have any idea of a model #? I would like to get a parts manual.
My PTO is the older style.
The Raider 12 did not come to me with a deck. My wife has used it to haul a garden cart. The decks offered were vertical belt driven. I added the mule drive to have a better deck selection.
 I had a Simplicity 3416H 48" left side discharge deck for close to 50 years. I really liked how it mowed. A couple of years ago a Wheel Horse 857 found its way into the garage. I never knew the rear discharge deck existed. It has a 36" deck and it mows as well as the Simplicity.  I'm  relatively new to the Wheel Horse world. The tractors are simple to work on (at least the older models) the attachments, however, are a bit more complicated.
gwest_ca
It will be one of these. A few of the differences are noted but not all.
These all use blades with 3/4" center hole.
1977 model 75-42MR02 replaced by - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support)
1978 model 85-42MR01 - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support)
1979 model 95-42MR01 - Shares an illustrated parts list with 85-42MR01 - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support)
1979 model 95-42MR02 - (Has no multi-link hardware at the gauge wheel support)
1980-1983 model 05-42MR01
1984 model 05-42MR02 - Last year for bearings with 3/4" ID
1985 model 05-42MR03 - First year for bearings with 17mm ID unless older spindles were updated.
1986-1988 model 05-42MR04
1989-1990 model 15-42RC01
1990-1992 model 15-42RC02
1993-2012 model 78350
Note - 17mm is .669"
gwest_ca
I don't know if it will help but is there a part number on the belt routing decal or any of the others?
Simplecity
Thanks for the model#s
The is a part # on the belt routing decal (106748) I'll see if that will help narrow it down.
 The deck does have the flat bar mounted tensioner pulley.
gwest_ca
That decal was used 1978-2016 so not much help.
Simplecity
Thanks for the Models#s
I researched them and settled on the 85-42MR01.
1) The belt that came with it measured 98" (O.D.)
2) It has the rubber bumpers
3) It resembles what I have.
The blade part # 106635 lists it as a blade kit. Does that mean single blades are not an option? Just wondering...
Thanks Again for the research.
Simplecity
gwest_ca
106079 and 106108 blades replaced by106635 3-blade set.
Center blade may be a different length.
Places like Oregon, Stens and Napa will sell individual blades but Toro does not.
