Simplecity 27 #1 Posted August 19 Good Afternoon All Just acquired rear discharge deck and spare mule drive for the Raider 12. Can anyone ID the deck? I see not tags on it. Once my mid mount hitch arrives I should be able to mount and mow. Also, the hight adjustment has no markings, so I'll ASSUME that you adjust with a tape measure off of the blade tips. Thanks to all who respond 1 Share this post Link to post Share on other sites
ol550 880 #2 Posted August 19 Looks like the blades are too short. ? 1 Share this post Link to post Share on other sites
peter lena 10,121 #3 Posted August 19 @Simplecity what is the width underside deck inner side wall to wall , ? looks like a 42" also lucky you ! no baffles ! also no related rot . I have 3 of those , this what my decks look like , how do spindles sound move , any roughness at all ? have a regular bearing clean out and re grease , with lucas x tra hd green chassis grease , also did my mule drive bearings , no noise or bearing whine , what an opportunity ! mine are rust free and quietly very solid . BTW the related pto lever set up . is a GOLD MINE FOR IMPROVEMENT . did this too. wish you were closer ! ask away , pete " rear discharge , also lucky yoy Share this post Link to post Share on other sites
Simplecity 27 #4 Posted August 19 11 minutes ago, peter lena said: @Simplecity what is the width underside deck inner side wall to wall , ? looks like a 42" also lucky you ! no baffles ! also no related rot . I have 3 of those , this what my decks look like , how do spindles sound move , any roughness at all ? have a regular bearing clean out and re grease , with lucas x tra hd green chassis grease , also did my mule drive bearings , no noise or bearing whine , what an opportunity ! mine are rust free and quietly very solid . BTW the related pto lever set up . is a GOLD MINE FOR IMPROVEMENT . did this too. wish you were closer ! ask away , pete " rear discharge , also lucky yoy 1 Share this post Link to post Share on other sites
Simplecity 27 #5 Posted August 19 Pete It is a 42". Would you have any idea of a model #? I would like to get a parts manual. My PTO is the older style. The Raider 12 did not come to me with a deck. My wife has used it to haul a garden cart. The decks offered were vertical belt driven. I added the mule drive to have a better deck selection. I had a Simplicity 3416H 48" left side discharge deck for close to 50 years. I really liked how it mowed. A couple of years ago a Wheel Horse 857 found its way into the garage. I never knew the rear discharge deck existed. It has a 36" deck and it mows as well as the Simplicity. I'm relatively new to the Wheel Horse world. The tractors are simple to work on (at least the older models) the attachments, however, are a bit more complicated. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,552 #6 Posted August 19 It will be one of these. A few of the differences are noted but not all. These all use blades with 3/4" center hole. 1977 model 75-42MR02 replaced by - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support) 1978 model 85-42MR01 - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support) 1979 model 95-42MR01 - Shares an illustrated parts list with 85-42MR01 - (Has the flat spindle belt idler pulley mounted on a flat bar) (Has multi-link hardware at the gauge wheel support) 1979 model 95-42MR02 - (Has no multi-link hardware at the gauge wheel support) 1980-1983 model 05-42MR01 1984 model 05-42MR02 - Last year for bearings with 3/4" ID 1985 model 05-42MR03 - First year for bearings with 17mm ID unless older spindles were updated. 1986-1988 model 05-42MR04 1989-1990 model 15-42RC01 1990-1992 model 15-42RC02 1993-2012 model 78350 Note - 17mm is .669" 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,552 #7 Posted August 19 I don't know if it will help but is there a part number on the belt routing decal or any of the others? Share this post Link to post Share on other sites
Simplecity 27 #8 Posted August 19 Thanks for the model#s The is a part # on the belt routing decal (106748) I'll see if that will help narrow it down. The deck does have the flat bar mounted tensioner pulley. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,552 #9 Posted August 19 That decal was used 1978-2016 so not much help. Share this post Link to post Share on other sites
Simplecity 27 #10 Posted August 20 Thanks for the Models#s I researched them and settled on the 85-42MR01. 1) The belt that came with it measured 98" (O.D.) 2) It has the rubber bumpers 3) It resembles what I have. The blade part # 106635 lists it as a blade kit. Does that mean single blades are not an option? Just wondering... Thanks Again for the research. Simplecity Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,552 #11 Posted August 20 106079 and 106108 blades replaced by106635 3-blade set. Center blade may be a different length. Places like Oregon, Stens and Napa will sell individual blades but Toro does not. 1 Share this post Link to post Share on other sites
Bugzilla46310 68 #12 Posted August 30 Just bought a set of these xht blades from Sunbelt parts for my 48” deck. They seem to have a good selection. We have sandy soil and “normal “ blades get eaten alive. The original blades on our Kubota 2680 look new after 4 seasons. I’m hoping that these xht give similar results. Never heard of them but ran across their site searching for blades. Anyone else have any experience with these? https://www.sunbeltparts.com/pages/xht.html Share this post Link to post Share on other sites
