TheMooseIsLoose 16 #1 Posted Wednesday at 03:14 PM I am looking to install a Deflector Actuator on my 520-H single stage snowblower. Does anyone out there use one and what brand/model number you are using. A 4" stroke shoud be sufficient. If anyone does please post a pic of it installed. Thank You Share this post Link to post Share on other sites
peter lena 9,989 #2 Posted Wednesday at 03:50 PM @ the moose is Loose , easy to make a chute base swivel mount gasket / slider , also like PAM vegetable oil aerosol to enhance slide , https://www.truevalue.com/product/821098/flexible-flyer-polyethylene-36-in-flying-carpet-snow-sled-821098/?gad_source=1&gad_campaignid=23532714148&gbraid=0AAAAAClad4tcAJpFDnwlxc9INM6dPJgp9&gclid=CjwKCAjwqJXUBhBNEiwA8BgG7qNTP52B-GDGc_aWfSzvvrL2W_1T4q0z2sj_w7KB4FImGLCfREBSwxoCKBsQAvD_BwE , would also , aerosil lube any related movement area , after removal of deflector , very easy to measure up a slide point gasket , that turn handle should move very easily . pete Share this post Link to post Share on other sites
TheMooseIsLoose 16 #3 Posted Wednesday at 11:43 PM I was thinking about something like this 2 Share this post Link to post Share on other sites
wallfish 20,372 #4 Posted yesterday at 02:02 AM Think I have the same one but my blower is a 2 stage plus the rotation of the chute is also motorized. 1 Share this post Link to post Share on other sites
Handy Don 17,127 #5 Posted yesterday at 02:11 AM (edited) Not a bad idea, but be sure to pay attention to the actuator's speed vs. stroke. Many move at 0.5” per second or less. That’s 8 (long) seconds for a 4” stroke to switch a chute from one side to the other. It the load is light, consider a mechanism that multiplies the actuator’s displacement. Edited yesterday at 02:12 AM by Handy Don 1 Share this post Link to post Share on other sites
Racinbob 13,074 #6 Posted yesterday at 09:53 AM I put this on my tall chute a while back. Mounted this way the 6" stroke is spot on. The control is mounted in a pvc handy box with a magnet. The directional crank works just fine for me. 1 2 Share this post Link to post Share on other sites
Bar Nuthin 2,897 #7 Posted yesterday at 11:40 AM 1 hour ago, Racinbob said: I put this on my tall chute a while back. Mounted this way the 6" stroke is spot on. Looks like a great mod. Do you have a link for this actuator? Share this post Link to post Share on other sites
TheMooseIsLoose 16 #8 Posted yesterday at 05:10 PM 7 hours ago, Racinbob said: I put this on my tall chute a while back. Mounted this way the 6" stroke is spot on. The control is mounted in a pvc handy box with a magnet. The directional crank works just fine for me. Share this post Link to post Share on other sites
TheMooseIsLoose 16 #9 Posted yesterday at 05:18 PM Do you have a brand name/model #, I've looked at Firgelli and others but don't know which is good. I was thinking of a 4" stroke but a 6" may be better. Share this post Link to post Share on other sites
Racinbob 13,074 #10 Posted yesterday at 06:10 PM (edited) 55 minutes ago, TheMooseIsLoose said: Do you have a brand name/model #, I've looked at Firgelli and others but don't know which is good. I was thinking of a 4" stroke but a 6" may be better. @Bar Nuthin I don't know if this link is still good. DC 12V Electric Micro Linear Actuator Mini 1.2" 2" 4" 6"Stroke Fast Speed CNC TV | eBay The length depends entirely on your set up. The 6" worked perfectly for my set up with the fairly long chute handle. It lowers the needed power with the leverage. Simply measure what you need. The speed is plenty fast enough. Edited yesterday at 06:15 PM by Racinbob 1 Share this post Link to post Share on other sites
Bar Nuthin 2,897 #11 Posted yesterday at 08:03 PM 1 hour ago, Racinbob said: The 6" worked perfectly for my set up with the fairly long chute handle. Looks identical to mine Share this post Link to post Share on other sites
wallfish 20,372 #12 Posted 20 hours ago 8 hours ago, TheMooseIsLoose said: Do you have a brand name/model #, I've looked at Firgelli and others but don't know which is good. I was thinking of a 4" stroke but a 6" may be better. Mine is a 4" stroke BUT it's mounted on the side instead of directly in the middle in order to speed things up a bit as those actuators are fairly slow. 1 Share this post Link to post Share on other sites
TheMooseIsLoose 16 #13 Posted 1 hour ago On 8/20/2026 at 2:10 PM, Racinbob said: @Bar Nuthin I don't know if this link is still good. DC 12V Electric Micro Linear Actuator Mini 1.2" 2" 4" 6"Stroke Fast Speed CNC TV | eBay The length depends entirely on your set up. The 6" worked perfectly for my set up with the fairly long chute handle. It lowers the needed power with the leverage. Simply measure what you need. The speed is plenty fast enough. Do you have a brand name, who its made by? Share this post Link to post Share on other sites
Racinbob 13,074 #14 Posted 13 minutes ago 1 hour ago, TheMooseIsLoose said: Do you have a brand name, who its made by? Nothing on it. I don't know if they said in the listing but it's usually 'unbranded'. Share this post Link to post Share on other sites
