TheMooseIsLoose 17 #1 Posted August 19 I am looking to install a Deflector Actuator on my 520-H single stage snowblower. Does anyone out there use one and what brand/model number you are using. A 4" stroke shoud be sufficient. If anyone does please post a pic of it installed. Thank You Share this post Link to post Share on other sites
peter lena 10,065 #2 Posted August 19 @ the moose is Loose , easy to make a chute base swivel mount gasket / slider , also like PAM vegetable oil aerosol to enhance slide , https://www.truevalue.com/product/821098/flexible-flyer-polyethylene-36-in-flying-carpet-snow-sled-821098/?gad_source=1&gad_campaignid=23532714148&gbraid=0AAAAAClad4tcAJpFDnwlxc9INM6dPJgp9&gclid=CjwKCAjwqJXUBhBNEiwA8BgG7qNTP52B-GDGc_aWfSzvvrL2W_1T4q0z2sj_w7KB4FImGLCfREBSwxoCKBsQAvD_BwE , would also , aerosil lube any related movement area , after removal of deflector , very easy to measure up a slide point gasket , that turn handle should move very easily . pete Share this post Link to post Share on other sites
TheMooseIsLoose 17 #3 Posted August 19 I was thinking about something like this 2 Share this post Link to post Share on other sites
wallfish 20,618 #4 Posted August 20 Think I have the same one but my blower is a 2 stage plus the rotation of the chute is also motorized. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #5 Posted August 20 (edited) Not a bad idea, but be sure to pay attention to the actuator's speed vs. stroke. Many move at 0.5” per second or less. That’s 8 (long) seconds for a 4” stroke to switch a chute from one side to the other. It the load is light, consider a mechanism that multiplies the actuator’s displacement. Edited August 20 by Handy Don 1 Share this post Link to post Share on other sites
Racinbob 13,190 #6 Posted August 20 I put this on my tall chute a while back. Mounted this way the 6" stroke is spot on. The control is mounted in a pvc handy box with a magnet. The directional crank works just fine for me. 1 3 Share this post Link to post Share on other sites
Bar Nuthin 3,234 #7 Posted August 20 1 hour ago, Racinbob said: I put this on my tall chute a while back. Mounted this way the 6" stroke is spot on. Looks like a great mod. Do you have a link for this actuator? Share this post Link to post Share on other sites
TheMooseIsLoose 17 #8 Posted August 20 7 hours ago, Racinbob said: I put this on my tall chute a while back. Mounted this way the 6" stroke is spot on. The control is mounted in a pvc handy box with a magnet. The directional crank works just fine for me. Share this post Link to post Share on other sites
TheMooseIsLoose 17 #9 Posted August 20 Do you have a brand name/model #, I've looked at Firgelli and others but don't know which is good. I was thinking of a 4" stroke but a 6" may be better. Share this post Link to post Share on other sites
Racinbob 13,190 #10 Posted August 20 (edited) 55 minutes ago, TheMooseIsLoose said: Do you have a brand name/model #, I've looked at Firgelli and others but don't know which is good. I was thinking of a 4" stroke but a 6" may be better. @Bar Nuthin I don't know if this link is still good. DC 12V Electric Micro Linear Actuator Mini 1.2" 2" 4" 6"Stroke Fast Speed CNC TV | eBay The length depends entirely on your set up. The 6" worked perfectly for my set up with the fairly long chute handle. It lowers the needed power with the leverage. Simply measure what you need. The speed is plenty fast enough. Edited August 20 by Racinbob 1 Share this post Link to post Share on other sites
Bar Nuthin 3,234 #11 Posted August 20 1 hour ago, Racinbob said: The 6" worked perfectly for my set up with the fairly long chute handle. Looks identical to mine 1 Share this post Link to post Share on other sites
wallfish 20,618 #12 Posted August 21 8 hours ago, TheMooseIsLoose said: Do you have a brand name/model #, I've looked at Firgelli and others but don't know which is good. I was thinking of a 4" stroke but a 6" may be better. Mine is a 4" stroke BUT it's mounted on the side instead of directly in the middle in order to speed things up a bit as those actuators are fairly slow. 1 Share this post Link to post Share on other sites
TheMooseIsLoose 17 #13 Posted August 21 On 8/20/2026 at 2:10 PM, Racinbob said: @Bar Nuthin I don't know if this link is still good. DC 12V Electric Micro Linear Actuator Mini 1.2" 2" 4" 6"Stroke Fast Speed CNC TV | eBay The length depends entirely on your set up. The 6" worked perfectly for my set up with the fairly long chute handle. It lowers the needed power with the leverage. Simply measure what you need. The speed is plenty fast enough. Do you have a brand name, who its made by? Share this post Link to post Share on other sites
Racinbob 13,190 #14 Posted August 21 1 hour ago, TheMooseIsLoose said: Do you have a brand name, who its made by? Nothing on it. I don't know if they said in the listing but it's usually 'unbranded'. Share this post Link to post Share on other sites
TheMooseIsLoose 17 #15 Posted August 22 Thanks, i was looking for a pdf of it for more info Share this post Link to post Share on other sites
TheMooseIsLoose 17 #16 Posted August 24 On 8/20/2026 at 5:53 AM, Racinbob said: I put this on my tall chute a while back. Mounted this way the 6" stroke is spot on. The control is mounted in a pvc handy box with a magnet. The directional crank works just fine for me. This comes with hardware, how is it wired in for power. I cant find a manuel for this. Share this post Link to post Share on other sites
Racinbob 13,190 #17 Posted August 24 3 hours ago, TheMooseIsLoose said: This comes with hardware, how is it wired in for power. I cant find a manuel for this. No manual. It's simply a 2 wire connection. 12v DC. I used a DPDT momentary center off switch to flip the polarity for the in/out. It shuts off automatically when it reaches full extension or retraction. The switch is housed in a pvc box with a cord that plugs into a power port I installed. Switchbox is headed in place with a magnet. Flexibility. The blower will likely go on Dino. I much prefer the manual PTO vs electric. 2 Share this post Link to post Share on other sites
TheMooseIsLoose 17 #18 Posted August 25 I ordered a Vevor 12V linear actuator with a 6" stroke. Well see how that is. Share this post Link to post Share on other sites
c-series don 12,447 #19 Posted August 26 I need to do the same thing on my two stage. I don’t mind the manual crank to turn the chute, it works easy and fast. But I’d like to change the deflector from inside the cab! Seems like this might be a good time to post one of my favorite videos! My wife took it back in January. IMG_4058.mov 2 2 Share this post Link to post Share on other sites
TheMooseIsLoose 17 #20 Posted September 12 On 8/20/2026 at 7:40 AM, Bar Nuthin said: Looks like a great mod. Do you have a link for this actuator? Iam currently installing my actuator, what did you splice into for power. Share this post Link to post Share on other sites
Racinbob 13,190 #21 Posted September 12 Look closely at the pictures and you'll see a power port I installed on the steering tower. I installed that a couple years ago mainly for a tank sprayer. Share this post Link to post Share on other sites
TheMooseIsLoose 17 #22 Posted September 14 On 9/12/2026 at 1:47 PM, Racinbob said: Look closely at the pictures and you'll see a power port I installed on the steering tower. I installed that a couple years ago mainly for a tank sprayer. would it be safe to run power from the battery to the switch with a inline 10 amp fuse between battery and switch. Share this post Link to post Share on other sites
Racinbob 13,190 #23 Posted September 15 1 hour ago, TheMooseIsLoose said: would it be safe to run power from the battery to the switch with a inline 10 amp fuse between battery and switch. Sure. The power port on mine is connected that way. Share this post Link to post Share on other sites
TheMooseIsLoose 17 #24 Posted September 30 On 8/19/2026 at 11:14 AM, TheMooseIsLoose said: I am looking to install a Deflector Actuator on my 520-H single stage snowblower. Does anyone out there use one and what brand/model number you are using. A 4" stroke shoud be sufficient. If anyone does please post a pic of it installed. Thank You Finally got this mounted & wired. It is a little slow but i will deal with it. Thanx 4 all of your help. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #25 Posted September 30 1 hour ago, TheMooseIsLoose said: Nice neat job. Is the knife switch just for an overall cutout? BTW, if you were in an embellishing mood, you could add a cross piece on the deflector arm closer to the pivot to attach the actuator. With the shorter throw, the movement would be quicker. Share this post Link to post Share on other sites
