tractor. 3 #1 Posted August 18 I have a b80 and im unsure of what snow plow i can use, do I need a long frame, a short frame, or does it not matter being its a mid frame. Also not sure if it will matter or not, but I swapped the trans being it was seized, and i think it was from an 856 and the brakes are a little differently placed so i dont know if it will get in the way or not. Not sure if this will help or not, the photo with the newer red and chain is the one I put in and the other one is the original style from my parts b80 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #2 Posted August 18 These models should fit your tractor. Look at an illustrated parts list (IPL) to see all the separate pieces required to install it. 1968 model 6-4111 - First to fit LONG & SHORT frame tractors and first to mount under the rear axle - Lift bracket behind crossmember 7716 A-frame - replaced by 1969 model [6-4112 + 6-9621] - First to have the lift bracket ahead of the crossmember 7716 A-frame 1970-73 model [6-4113 + 6-9622] 1973-74 model [6-4113 + 6-9623] 1974 model [6-4114 + 6-9624] 1974 model 6-2131 1975 model 6-2132 1976 model 6-2133 1976 model 66-42BC01 1977 model 76-42BC01 1978 model 86-42BC01 1979 model 96-42BC01 (1968 model 6-4111 to 1980 model 06-42BC01 use the same 7716 A-frame assembly but the lift tab changed according to the ipl's) 1980 model 06-42BC01 1981-1984 model 06-42BC02 (Up to here they are 42" wide) (Uses 104341 and 3771 index wires - See file for dimensions) 1984-1989 model 06-48BC01 (They are now 48" wide) (Uses 104341 and 3771 index wires - See file for dimensions) [M] 1990 model 06-48BC02 (Last blade to have 3 angle positions) 1991-1993 model 06-48BC03 (First blade to have 5 angle positions) 1993-2001 model 79350 - (105-1502 kit adapts 2001 and older GT Classic-Series blades to fit 2002 and later tractors 2002 2004-2009 2012 model 79364 - (105-1501 kit adapts 79364 blade to fit 2001 and older GT Classic-Series) 2 Share this post Link to post Share on other sites
ebinmaine 80,694 #3 Posted August 18 You need a long frame even though you have a mid frame because if you don't, the plow might hit the tires in the right situation of angle. 3 Share this post Link to post Share on other sites
Ed Kennell 47,311 #4 Posted August 18 The brake location will not matter. The long frame will work with either style axle bracket. The short frame may work with the older style axle bracket that has the notches in front of the axle. 1 Share this post Link to post Share on other sites
ebinmaine 80,694 #5 Posted August 18 45 minutes ago, Ed Kennell said: The brake location will not matter. The long frame will work with either style axle bracket. The short frame may work with the older style axle bracket that has the notches in front of the axle. With a fairly tall 16" tire and the plow angled full it's reeeaaally close on one side. Don't recall which. Bump an obstacle and it makes contact, tire to plow. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #6 Posted August 19 2 hours ago, ebinmaine said: Bump an obstacle and it makes contact, tire to plow. Do it hard enough and wreck a tire or even bend/break something! 1 Share this post Link to post Share on other sites
