crackerjohn
Ignition
crackerjohn
Hi folks, new member and have a question. I just acquired a 520h and My ignition is shot, actually not there I am just trying to get it going to see what I have. So what I have done is run a switched wire from positive side of battery to positive on coil then I ran a switched wire from positive side of battery to solenoid. I have lots of spark and it turns over great but won' start. What am I missing? Go easy on the new guy..LOL
953 nut
:WRS:
The floggings will begin next time you post.          :ROTF:
Are you getting fuel to the carburetor?       Have you replaced the spark plugs?
crackerjohn
Thanks r the reply. Yes lots of fuel an plgs are good
Ed Kennell
Good fuel and spark.  Is compression missing?
crackerjohn
Yes lots of compression . So I have compression,fuel and spark. I am wondering if I have to jump any wires in the ignition plug. I didn't want to do that until I got some feedback here.
8ntruck
Is the spark at the correct time?
crackerjohn
should be, it ran good before parked.
Ed Kennell
Not if you see a good fire at the spark plugs.  Can you video the spark plugs firing?
crackerjohn
I am old school and don't have one of those pocket phones to take pictures and there is no reception where I live. I know there is lots of spark because I hooked up one of those spark testers between the plug and plug wire and it was firing really good.
crackerjohn
Well I got it going this AM. I gave it a squirt of starting fluid ( which I don't like to use ) and it fired right up and it runs really good. Now all I have to do is figure out why it is not charging, 12.63v. Thanks for all the replies.
953 nut
Start by cleaning and inspecting the nine pin connector from the engine and the 30 amp fuse holder and fuse blades.
sqrlgtr
I will go ahead and suggest replacing fuel pump with an electric one. My 520H would take forever to fire if it set any length of time, and the factory pump would squirt fuel across shop so must have been draining back. Here is a pic of mine so to give you an idea where and what kind I'm using. I can now turn key on let fuel pump run a sec or two and will fire right up. Your sanity and starter will thank you.:D.15F4F405-A677-4870-8A09-1ECAF5859767.jpeg.5ae88bc04f57b238eb7998560abd55a9.jpeg
Handy Don
WH voltage reguators need solid grounding to work properly. The Onan engine’s voltage regulator is attached to the cooling air shroud. Make sure the body of the regulator has clean electrical contact with the shroud and that the shroud has clean electrical contact with the engine block. For giggles, make sure the battery negative to engine block cable is making solid electrical contact at both ends.
If you have an accurate voltmeter (i.e. the tractor stock meters are “approximate”) measure the AC voltage between the two outer pins of the voltage regulator while the engine is running at wide open throttle (WOT). It should be ~40 volts.
Edited by Handy Don
lynnmor
Download the Onan manuals here they will have the procedures for troubleshooting and maintenance.
8ntruck
I use a shot of carb cleaner into the carb as a starting aid.  Not near as violent as starting fluid.
lynnmor
I use a tablespoon of gasoline, carb cleaner is $44 per gallon.  :)
  • Haha 1
crackerjohn
Thanks for the replies, I was up for hrs last night reading on this site and have to say it is amazing and a lot of knowledge. So I took what I learned and did all the tests and am happy ( or not ) it is a bad RR. Happy that it is not the stator. So I will find one and order it tonight. Thanks
sqrlgtr
I try and encourage everyone to become a supporter of the site especially if you are getting bit by the Wheel Horse bug and plan on staying around. You will not find a better group/community of people to be around. Supporter status gives you chance to post unlimited photos and few other perks. Well worth the cost of admission. :D
