1987_WHEEHORSE312 95 #1 Posted August 17 Hey guys! Has anyone found plow skids that work that bolt on and also adjustable on the fly? My driveway is mostly gravel but I have a pavement apron at the end, as well as my neighbors driveways that are pavement that I plow for them too. I dont have a welder so being able to bolt stuff together is my only option. Thanks! Share this post Link to post Share on other sites
953 nut 69,298 #2 Posted August 17 24 minutes ago, 1987_WHEEHORSE312 said: adjustable on the fly? You planning on putting them on some sort of electric linear actuator or hydraulic cylinder? 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #3 Posted August 17 1 minute ago, 953 nut said: You planning on putting them on some sort of electric linear actuator or hydraulic cylinder? No, just want pins i can pull and slide thwm manually out. Adjustable on the fly meaning no tools needed to slide them up or down. Share this post Link to post Share on other sites
953 nut 69,298 #4 Posted August 17 Check these out. https://www.ebay.com/itm/317620224807?_skw=wheel+horse+snow+plow+skids&itmmeta=01M08Z870V98AS4S8Q5NZ0GQQ2&hash=item49f3a40327:g:1JgAAeSwOcppT-RS&itmprp=enc%3AAQALAAAA4GfYFPkwiKCW4ZNSs2u11xC%2BP1ZGkww8hATohcc%2FsATOTRBGKzfmjk4kZQcciMBF9DoG8xI2Ppaesmys5tIhWWN3lJVpE%2BO4UPWb7xNjbmiCuT74yZiPVXZh2qNKn34ncx%2BPTrqfdaQAsyDVqAZ1BPE%2BI5WAkMN6JuOlA8Tm0GGAj8hRv92hBHgPu9FoqEzgvveKdgS56IsHd7ZAll0XfKtv4pNECc68wloFsRfQZs30l3sRCjMuBALYpJ0TWtdOAUXVCX8DBAyQI%2FtI1Swq5kunfmAovVlj2PPlhJmQDYBR|tkp%3ABk9SR8bwoJ-CaA Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #5 Posted August 17 Just now, 953 nut said: Check these out. https://www.ebay.com/itm/317620224807?_skw=wheel+horse+snow+plow+skids&itmmeta=01M08Z870V98AS4S8Q5NZ0GQQ2&hash=item49f3a40327:g:1JgAAeSwOcppT-RS&itmprp=enc%3AAQALAAAA4GfYFPkwiKCW4ZNSs2u11xC%2BP1ZGkww8hATohcc%2FsATOTRBGKzfmjk4kZQcciMBF9DoG8xI2Ppaesmys5tIhWWN3lJVpE%2BO4UPWb7xNjbmiCuT74yZiPVXZh2qNKn34ncx%2BPTrqfdaQAsyDVqAZ1BPE%2BI5WAkMN6JuOlA8Tm0GGAj8hRv92hBHgPu9FoqEzgvveKdgS56IsHd7ZAll0XfKtv4pNECc68wloFsRfQZs30l3sRCjMuBALYpJ0TWtdOAUXVCX8DBAyQI%2FtI1Swq5kunfmAovVlj2PPlhJmQDYBR|tkp%3ABk9SR8bwoJ-CaA Thanks! Do they have a bracket that will bolt onto the existing holes on the plow? Share this post Link to post Share on other sites
953 nut 69,298 #6 Posted August 17 Just now, 1987_WHEEHORSE312 said: Thanks! Do they have a bracket that will bolt onto the existing holes on the plow? Got to fabricate something of your own. Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #7 Posted August 17 1 minute ago, 953 nut said: Got to fabricate something of your own. Yea thats where im stumped. If I had a welder it would be easy Share this post Link to post Share on other sites
ebinmaine 80,695 #8 Posted August 18 1 hour ago, 1987_WHEEHORSE312 said: Yea thats where im stumped. If I had a welder it would be easy Not sure what your plow has on it but there are 90⁰ angle pieces available from Home Depot that could be considered. FWIW. I've tried those exact skids. I have some you can have for the freight. We stopped using plow skids because they dug into our driveway. Share this post Link to post Share on other sites
mrc 1,119 #9 Posted August 18 another thing to consider is when the blade is fully angled the skids/shoes can rub the front tires 2 Share this post Link to post Share on other sites
wallfish 20,612 #10 Posted August 18 (edited) 2 hours ago, 953 nut said: Check these out. https://www.ebay.com/itm/317620224807? FYI --- When linking any of those things like that could you please delete EVERYTHING after the ? in your post. Everything after the ? is tracking BS that we don't want or need when clicking on it. I didn't know that either until @Handy Don pointed that out a while go. The rest is deleted but the link still links Edited August 18 by wallfish 3 Share this post Link to post Share on other sites
peter lena 10,065 #11 Posted August 18 @1987_WHEEHORSE312 https://www.google.com/search?q=atv+plow+skids&rlz=1C1CHBF_enUS866US866&oq=atv+plow+skids&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIICAEQABgWGB4yCAgCEAAYFhgeMggIAxAAGBYYHjIICAQQABgWGB4yCAgFEAAYFhgeMggIBhAAGBYYHjIICAcQABgWGB4yCAgIEAAYFhgeMggICRAAGBYYHtIBCTEwMzc1ajBqNKgCAbACAfEFllTzXrNDIJfxBZZU816zQyCX&sourceid=chrome&source=chrome.ob&ie=UTF-8 atv set ups are the same , a spring following slider , would let you dial in your ground contact . picture reference , ideas ? pete Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #12 Posted August 18 1 minute ago, peter lena said: @1987_WHEEHORSE312 https://www.google.com/search?q=atv+plow+skids&rlz=1C1CHBF_enUS866US866&oq=atv+plow+skids&gs_lcrp=EgZjaHJvbWUyBggAEEUYOTIICAEQABgWGB4yCAgCEAAYFhgeMggIAxAAGBYYHjIICAQQABgWGB4yCAgFEAAYFhgeMggIBhAAGBYYHjIICAcQABgWGB4yCAgIEAAYFhgeMggICRAAGBYYHtIBCTEwMzc1ajBqNKgCAbACAfEFllTzXrNDIJfxBZZU816zQyCX&sourceid=chrome&source=chrome.ob&ie=UTF-8 atv set ups are the same , a spring following slider , would let you dial in your ground contact . picture reference , ideas ? pete Thanks! Yea the actual skids is the easy part, making a mounting bracket it hard given I dont have a welder. Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #13 Posted August 18 11 hours ago, mrc said: another thing to consider is when the blade is fully angled the skids/shoes can rub the front tires Yea thats true, but mine has the little 6" fronts on it, its a 312 Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #14 Posted August 18 11 hours ago, ebinmaine said: Not sure what your plow has on it but there are 90⁰ angle pieces available from Home Depot that could be considered. FWIW. I've tried those exact skids. I have some you can have for the freight. We stopped using plow skids because they dug into our driveway. Maybe I should just use the pipe trick then? I dont want skids digging into my driveway either. 1 Share this post Link to post Share on other sites
peter lena 10,065 #15 Posted August 18 has to be someone close that could weld on brackets , pete Share this post Link to post Share on other sites
ebinmaine 80,695 #16 Posted August 18 16 minutes ago, 1987_WHEEHORSE312 said: Maybe I should just use the pipe trick then? I dont want skids digging into my driveway either. You might be better off. Our driveway has some soft spots where the water settles a bit. Once it freezes here, it stays solid for a couple months or more. Several years ago we started tilting the plow blade forward one hole further than standard. That works very good and also helps the snow roll off to the sides better. Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #17 Posted August 18 19 minutes ago, peter lena said: has to be someone close that could weld on brackets , pete There is but they want to charge $150 to weld them. My buddy has a cheap mig but it runs off 120v, which makes him not sure its gonna get hot enough. Share this post Link to post Share on other sites
ebinmaine 80,695 #18 Posted August 18 2 hours ago, 1987_WHEEHORSE312 said: There is but they want to charge $150 to weld them. My buddy has a cheap mig but it runs off 120v, which makes him not sure its gonna get hot enough. It will. Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #19 Posted August 18 10 minutes ago, ebinmaine said: It will. Yea, I was looking into stuff and realized that if the skids sit up, ill always have a half inch of snow left, where with the pipe method it gets it alot cleaner. 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #20 Posted August 18 2 hours ago, 1987_WHEEHORSE312 said: Yea, I was looking into stuff and realized that if the skids sit up, ill always have a half inch of snow left, where with the pipe method it gets it alot cleaner. The clean scrape is why we leave the plow down and forward. 1 Share this post Link to post Share on other sites
1987_WHEEHORSE312 95 #21 Posted August 18 Just now, ebinmaine said: The clean scrape is why we leave the plow down and forward. Yea truck, just dont wanna have a rock pile at the end of the winter 2 Share this post Link to post Share on other sites
Handy Don 17,474 #22 Posted August 18 5 hours ago, 1987_WHEEHORSE312 said: There is but they want to charge $150 to weld them. My buddy has a cheap mig but it runs off 120v, which makes him not sure its gonna get hot enough. My 120v MIG will go up to 140 amps (on a 20 amp circuit) and I’ve burned through things even at lower amperages. The trick is to practice on scrap of similar gauges until you have the feed rate and amperage correct. For me, I had to learn to move more quickly and bump the feed rate a bit--I had plenty of heat. Share this post Link to post Share on other sites
sqrlgtr 3,930 #23 Posted August 18 (edited) 17 hours ago, wallfish said: FYI --- When linking any of those things like that could you please delete EVERYTHING after the ? in your post. Everything after the ? is tracking BS that we don't want or need when clicking on it. I didn't know that either until @Handy Don pointed that out a while go. The rest is deleted but the link still links @wallfish @Handy DonThat is good to know, are y'all talking about the ? mark after the first part of the link that's been pasted? @1987_WHEEHORSE312 im not a fan of the skids and prefer the pvc pipe over the cutting edge. Edited August 18 by sqrlgtr Share this post Link to post Share on other sites
wallfish 20,612 #24 Posted August 18 19 minutes ago, sqrlgtr said: are y'all talking about the ? mark after the first part of the link that's been pasted? Yes. Just like I deleted everything after the ? in that link above 1 Share this post Link to post Share on other sites
sqrlgtr 3,930 #25 Posted August 18 3 hours ago, wallfish said: Yes. Just like I deleted everything after the ? in that link above Gotcha I see that now that you pointed it out Thanks Share this post Link to post Share on other sites
