tntatro 184 #1 Posted August 17 Hello, I have a Wheel Horse that is overcharging the battery. It has a K241. I tried running a ground wire directly from the voltage regulator to the battery with no change. The ac voltage is 36v. When first starting, the DC voltage is around 14.6v but will go way up above 15.5v the longer it runs. It had an aftermarket voltage regulator that I replaced with another aftermarket a while back. Now the new one I just put in still overcharges the same way. I tried one of those smaller flat regulators and it is over 14.5v at startup, full throttle. It has a new battery, key switch and I rewired all the wires that go to the key switch and replaced the amp meter with an hour meter. I think it's been overcharging for a while because I had to replace a battery that didn't seem to last as long as it should and a key switch and the plastic harness to the voltage regulator was melted. Any suggestions on what to do next? Thanks, Tim Share this post Link to post Share on other sites
rmaynard 17,659 #2 Posted August 17 (edited) I had the same problem, but my output was running at around 20vdc. I solved the problem by cleaning the area of the aluminum heat sink of the regulator and where it mounted to the frame. I don't know why that worked better than a direct wire to battery ground. However, if neither grounding suggestions work, replace the entire regulator with a known-good one from a donor tractor. Edited August 17 by rmaynard 3 Share this post Link to post Share on other sites
tntatro 184 #3 Posted August 17 27 minutes ago, rmaynard said: I solved the problem by cleaning the area of the aluminum heat sink of the regulator and where it mounted to the frame Okay, thanks for the suggestion. I'll try that and see how it goes. 1 Share this post Link to post Share on other sites
tntatro 184 #4 Posted August 18 I cleaned up the metal and did some sanding on all the places that will ground the regulator and that helped. It still puts out 14.7v but it doesn't go up after driving it around a bit. Before I would drive it a couple hundred yards and it would go up to 15v or more. Is 14.7v too high? Share this post Link to post Share on other sites
Achto 32,962 #5 Posted August 18 28 minutes ago, tntatro said: Is 14.7v too high? You should be OK at 14.7vdc 1 Share this post Link to post Share on other sites
tntatro 184 #6 Posted August 18 28 minutes ago, Achto said: You should be OK at 14.7vdc Thanks, I'll have to keep an eye on it. 1 1 Share this post Link to post Share on other sites
