RJR49 179 #1 Posted August 13 A few weeks ago my C-160 started then quit. Starts quickly maybe 4 seconds later quits. Afer a couple of those efforts ran fine. Today the same thing happened! I was thinking that the electric pump got tired but if you let it sit for a couple of minutes it will run for 4 or 5 seconds. If I restart immediately it only runs for 2 or 3 seconds so now im leaning towards the filter. Before i start troubleshooting i thought i would ask if anyone has other thoughts. Share this post Link to post Share on other sites
ebinmaine 81,282 #2 Posted August 13 IMHO.... Always do regular maintenance before troubleshooting. If you cycle the fuel pump off and on three or four without starting the engine, that should fill the fuel bowl for sure. Will it stay running then? Have you removed the inlet hose from the carburetor to verify that you are getting good fuel flow? What is the age of the fuel filter? When was the last time the carburetor was rebuilt? All fuel lines replaced? 1 Share this post Link to post Share on other sites
RJR49 179 #3 Posted August 13 I dont think the carburetor is the problem. It starts to easily and repetedly. The flow from the pump is the first thing im planning to check. 1 Share this post Link to post Share on other sites
ri702bill 13,394 #4 Posted August 13 Could be a fuel issue... could be a spark issue. Use an inline xenon bulb spark checker to narrow down the true source of the issue... 1 Share this post Link to post Share on other sites
953 nut 70,654 #6 Posted August 13 Quick way to check your condenser is to disconnect the wire, if the problem goes away then get a new condenser. The engine can be run for a few minutes without it for testing without damaging the points. 3 1 Share this post Link to post Share on other sites
sqrlgtr 4,225 #7 Posted August 13 I know I'm probably the only one that has done this, but could the fuel valve be shut off. 1 3 Share this post Link to post Share on other sites
RJR49 179 #8 Posted August 22 (edited) It was a problem with the carburetor. I bought a Chinese carb from Amazon. Had to cut off the choke tab of course. Fired right up. Edited August 22 by RJR49 Spelling 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #9 Posted August 22 4 minutes ago, RJR49 said: It was a problem with the carburetor. I bought a Chinese carb from Amazon. Had t cut off the coke tab of course. Fired right up. Do you still have the original #30 Kohler carburetor? Can you clean and rebuild it? My experience shows me that the "inexpensive" one won't last..... 1 Share this post Link to post Share on other sites
RJR49 179 #10 Posted August 22 I have a couple of Kohler Carbs i could rebuild but the Chinese carbs are half the price of the Kohler rebuild kits. Other than the choke being backwards I'm satisfied with them. As an aside; I have 3 Honda Motors on various pieces of equipment. All, well over 10 years old. When I start them for the season, snow in the winter, leaf vac in the fall, and my pressurewasher once every blue moon they always start on the first or second pull. I take care of them when i put them away but they are amazing. I've toyed with the idea of putting Honda motors on my two C‐160's if the Kohlers ever die But, as good as they are that just seems WRONG! 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #11 Posted August 22 18 minutes ago, RJR49 said: I have a couple of Kohler Carbs i could rebuild but the Chinese carbs are half the price of the Kohler rebuild kits. I can see your logic but I have NOT had the same results of satisfaction. At least 4 cheap carbs have gone through this shop. Two were from isave. All. Four. Failed. They're excluded forever. Kohler kits are no longer available but I was buying them for about $15. I'll always spend the money and time to do a rebuild. Quote . As an aside; I have 3 Honda Motors on various pieces of equipment. All, well over 10 years old. When I start them for the season, snow in the winter, leaf vac in the fall, and my pressurewasher once every blue moon they always start on the first or second pull. I take care of them when i put them away but they are amazing. I've toyed with the idea of putting Honda motors on my two C‐160's if the Kohlers ever die But, as good as they are that just seems WRONG! Understand and agree. 1 Share this post Link to post Share on other sites
Bill D 3,213 #12 Posted August 22 1 hour ago, ebinmaine said: I can see your logic but I have NOT had the same results of satisfaction. At least 4 cheap carbs have gone through this shop. Two were from isave. All. Four. Failed. They're excluded forever. Kohler kits are no longer available but I was buying them for about $15. I'll always spend the money and time to do a rebuild. Understand and agree. When did the Kohler 25 757 01S kit become NLA and are there any good aftermarket kits? 1 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #13 Posted August 22 11 minutes ago, Bill D said: When did the Kohler 25 757 01S kit become NLA Not sure. I found out a few weeks ago. 11 minutes ago, Bill D said: and are there any good aftermarket kits? I haven't tried any so I don't dare recommend one. Share this post Link to post Share on other sites
sqrlgtr 4,225 #14 Posted August 23 2 hours ago, ebinmaine said: At least 4 cheap carbs have gone through this shop. I have a couple that wasn't 2 bad but a couple that were junk so 50/50 chance for me to get a good one. I will take an original if given the chance though. Hate to hear the Kohler kits are no longer available. 1 Share this post Link to post Share on other sites
kpinnc 19,107 #15 Posted August 23 On 8/13/2026 at 6:32 PM, sqrlgtr said: I know I'm probably the only one that has done this, but could the fuel valve be shut off. Absolutely yes you are. I have never ever done such a thing. 3 Share this post Link to post Share on other sites
sjoemie himself 3,283 #16 Posted August 23 About the carbs.. are there no good B&S, Honda or custom/aftermarket carbs that fit the Kohler engine(s)? I know from my moped years that carbs were swapped out for (mostly) larger ones all the time. After all it's "just" an air-fuel mixing device.. Seems to me that a carb of a dirtbike with about the same CI's/cc's should work just fine. 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #17 Posted August 23 21 minutes ago, sjoemie himself said: About the carbs.. are there no good B&S, Honda or custom/aftermarket carbs that fit the Kohler engine(s)? I know from my moped years that carbs were swapped out for (mostly) larger ones all the time. After all it's "just" an air-fuel mixing device.. Seems to me that a carb of a dirtbike with about the same CI's/cc's should work just fine. The Pulling community may have something available but that would be $$$$ I've wondered for years if there are other options but haven't had a serious enough need to figure it out. Share this post Link to post Share on other sites
RJR49 179 #18 Posted August 23 BAck in the Hot Rod days guys would make adapter plates to fit the carb of choice on they're cars. I dont see why you couldnt do that with a Honda carb unless it creates interference with the hood 2 Share this post Link to post Share on other sites
ebinmaine 81,282 #19 Posted August 23 3 minutes ago, RJR49 said: BAck in the Hot Rod days guys would make adapter plates to fit the carb of choice on they're cars. I dont see why you couldnt do that with a Honda carb unless it creates interference with the hood Yep. For sure. Matter of fact it would be reasonably easy to craft a small one barrel adapter from hardwood. Share this post Link to post Share on other sites
RJR49 179 #20 Posted August 23 I think steel would be a better choice. Absorption, heat. Steel would be tougher to make but if one of you guys in Connecticut want to try steel. I can help 2 Share this post Link to post Share on other sites
Handy Don 17,735 #21 Posted August 23 7 hours ago, kpinnc said: Absolutely yes you are. I have never ever done such a thing. Neither have I. But I have replaced the points and condenser and spent a bunch of time checking wiring, then opened the fuel cock and had it start right up and keep running! 2 4 Share this post Link to post Share on other sites
RJR49 179 #22 Posted August 23 Being curious I checked Amazon for Honda Carburetors. I was shocked at the price variation. $25.00 to $250.00! I asked AI and the attached picture basically says "don't do it" 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #23 Posted August 23 4 minutes ago, RJR49 said: Carburetors. I was shocked at the price variation. $25.00 to $250.00 Not at all surprising. I was looking for 1978 Briggs 8 HP carbs this afternoon and found almost exactly the same variance. Share this post Link to post Share on other sites
RJR49 179 #24 Posted August 24 For antiques sellers shoot for the moon. The prices I saw were for current OEM carburetors 1 Share this post Link to post Share on other sites
ebinmaine 81,282 #25 Posted August 24 1 minute ago, RJR49 said: For antiques sellers shoot for the moon. The prices I saw were for current OEM carburetors Yepp. Those moon prices are why I ALWAYS call guys like Brian Badman and Lincoln at A to Z. Both treat me well. 1 Share this post Link to post Share on other sites
