Dave ML 0 #1 Posted 23 hours ago I have an Electro 12 hp 1971 wheelhorse, and my question is when checking the fluid level in the transmission should the dipstick be screwed in or just inserted? The tractor has an automatic transmission, and the last time I used it it became difficult to push the forward lever forward. I thought that perhaps it was low on fluid. Share this post Link to post Share on other sites
pfrederi 20,958 #2 Posted 20 hours ago 2 hours ago, Dave ML said: I have an Electro 12 hp 1971 wheelhorse, and my question is when checking the fluid level in the transmission should the dipstick be screwed in or just inserted? The tractor has an automatic transmission, and the last time I used it it became difficult to push the forward lever forward. I thought that perhaps it was low on fluid. Welcome Push or screw the dipstick all the way in. Motion control lever action is not relat4ed to fluid level Is it also hard to move to reverse 1 Share this post Link to post Share on other sites
Ed Kennell 46,665 #3 Posted 7 hours ago to the Dave. Please follow Paul's instructions above. He knows Sundstrand hydros. 1 Share this post Link to post Share on other sites
953 nut 67,773 #4 Posted 7 hours ago I had a problem with the motion control lever on one of mine being hard to push forward, turned out a family of chipmunks had been building a nest in there that interfered with full movement. 2 1 Share this post Link to post Share on other sites
Bar Nuthin 2,847 #5 Posted 4 hours ago Whatever you do, don't lubricate the friction control. May need taken apart and worked over with some solvent and a Scotch Brite pad. 1 Share this post Link to post Share on other sites
