Dave ML 0 #1 Posted August 11 I have an Electro 12 hp 1971 wheelhorse, and my question is when checking the fluid level in the transmission should the dipstick be screwed in or just inserted? The tractor has an automatic transmission, and the last time I used it it became difficult to push the forward lever forward. I thought that perhaps it was low on fluid. Share this post Link to post Share on other sites
pfrederi 21,290 #2 Posted August 11 2 hours ago, Dave ML said: I have an Electro 12 hp 1971 wheelhorse, and my question is when checking the fluid level in the transmission should the dipstick be screwed in or just inserted? The tractor has an automatic transmission, and the last time I used it it became difficult to push the forward lever forward. I thought that perhaps it was low on fluid. Welcome Push or screw the dipstick all the way in. Motion control lever action is not relat4ed to fluid level Is it also hard to move to reverse 1 Share this post Link to post Share on other sites
Ed Kennell 47,807 #3 Posted August 12 to the Dave. Please follow Paul's instructions above. He knows Sundstrand hydros. 1 Share this post Link to post Share on other sites
953 nut 70,262 #4 Posted August 12 I had a problem with the motion control lever on one of mine being hard to push forward, turned out a family of chipmunks had been building a nest in there that interfered with full movement. 2 1 Share this post Link to post Share on other sites
Bar Nuthin 3,510 #5 Posted August 12 Whatever you do, don't lubricate the friction control. May need taken apart and worked over with some solvent and a Scotch Brite pad. 1 Share this post Link to post Share on other sites
