Bv1348 0 #1 Posted 6 hours ago I have a k341 that is leaking oil from the flywheel side and the breather. I have been reading some of the replies about this topic. I have replaced the oil seal on the flywheel side and I replaced the gaskets on the breather. I have reassembled the breather correctly per the diagram. Yesterday I mowed with the dipstick ajar. That made a mess of everything around the dipstick. It did slow the oil leak from the breather. The engine doesn't smoke. I bought it new in 1978 and in the late 1980s I had a new. .10 over size piston installed and bored out. I have not touched the engine except for routine maintenance. It is starting to lose power when I mow. What is causing the oil leaking and loss of power and missing? What ideas do you have Thanks Share this post Link to post Share on other sites
pfrederi 20,939 #2 Posted 5 hours ago Probably blow by...You could do a leak down test to verify but oil out the dipstick usually means compression leaking by the rings.. 3 Share this post Link to post Share on other sites
squonk 47,488 #3 Posted 3 hours ago Could even be a busted piston skirt. I found this in my C-160 engine that was still running. Using oil with little smoke and not much in the way of unusual noises. 1 Share this post Link to post Share on other sites
kpinnc 18,777 #4 Posted 2 hours ago 3 hours ago, Bv1348 said: in the late 1980s I had a new. .10 over size piston installed and bored out. Pardon the obvious, but that puts your rebuild at nearly 40 years old. Probably time for another one. The last one I did only lasted about 25 years so you got your money's worth for sure. Share this post Link to post Share on other sites
