EthanL
48” deck center pulley
EthanL
This is the center drive stacked pulley off my 48” mower deck I just picked up. I have looked everywhere and can’t seem to find it. The only style I can find are the double D types. Is anyone able to point me in the right direction or give me a part number?
It is a 3/4” keyed shaft and the pulley measure 5” across. I will be uploaded more pictures tomorrow.
lynnmor
Find the model number for the deck, if that isn’t possible then take your best guess as to the year.  You can look up parts on the Toro website and then do a search for the best deal.  Most of the 48” were about the same.
gwest_ca
Here is a list of the decks using blades with 3/4" center hole
Note - 3/4" or .750" is 19.05mm
1977 model 75-48MS02 - Uses 6203 bearings with 3/4" ID - (First deck to use blades with 3/4" center hole) - Originally had a nylon-insert nut holding spindle pulley on.
1978 model 85-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1979 model 95-48MS00 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1979 model 95-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1980 model 05-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1981-1983 model 05-48MS02 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
1984 model 05-48MS03 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on.
Note - 17mm is .669"
1985 model 05-48MS04 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers
1986-1988 model 05-48MS05 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers
1987-1988 model 05-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers
1989 model 15-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1990 model 15-48SC02 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1991-1992 model 15-48SC03 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1993-1997 model 78360 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
1998-2007 and 2009-12 model 78361 - Uses 6203 bearings with 17mm ID - (These all use blades with 3/4" center hole) - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers
peter lena
@EthanL  did you / are going to , do a bearing  clean out  and lubrication  UPGRADE  ON ALL RELATED BEARINGS ? really not that difficult   , but so worth it  . those 6203 bearings , really  work well with  , lucas , x tra hd green chassis grease , same bearings in the mule  drive , pto  inner cone needle bearing , clean out  very light  grease , application ,550 deg , polyurea , anti sling , all muel  drive nearings , done , spin up is smooth easy / quiet , no pto clutch , screaming , opportunity  is yours , pete
76c12091520h
Part # 106073 , center keyed pulley for a 48" deck. Plenty in stock here :D
EthanL
Sounds like it would be a good opportunity to do this. Disassemble all spindles and bearing and repack with grease. Am I understanding that correctly ?
peter lena
@EthanL  yes you are ! https://www.walmart.com/ip/Lucas-Xtra-Heavy-Duty-Grease/36052505?vshVwLdHBAOnfwul-  this is the grease , every bearing in my decks , spindle bearings , pto inner cone bearing , very lightly , also did this to my  pto lever start  set up lots of gold mine improvement AREAS , just washer add a heim joint ing up that sloppy start , makes a world of functional ease add a heim joint  , remove trundle , always smooth , silent . 3 horses with  this set up , smooth . quiet , easy . pete
