EthanL 56 #1 Posted 17 hours ago This is the center drive stacked pulley off my 48” mower deck I just picked up. I have looked everywhere and can’t seem to find it. The only style I can find are the double D types. Is anyone able to point me in the right direction or give me a part number? It is a 3/4” keyed shaft and the pulley measure 5” across. I will be uploaded more pictures tomorrow. Share this post Link to post Share on other sites
lynnmor 8,935 #2 Posted 17 hours ago Find the model number for the deck, if that isn’t possible then take your best guess as to the year. You can look up parts on the Toro website and then do a search for the best deal. Most of the 48” were about the same. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,390 #3 Posted 16 hours ago Here is a list of the decks using blades with 3/4" center hole Note - 3/4" or .750" is 19.05mm 1977 model 75-48MS02 - Uses 6203 bearings with 3/4" ID - (First deck to use blades with 3/4" center hole) - Originally had a nylon-insert nut holding spindle pulley on. 1978 model 85-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1979 model 95-48MS00 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1979 model 95-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1980 model 05-48MS01 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1981-1983 model 05-48MS02 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. 1984 model 05-48MS03 - Uses 6203 bearings with 3/4" ID - Originally had a nylon-insert nut holding spindle pulley on. Note - 17mm is .669" 1985 model 05-48MS04 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers 1986-1988 model 05-48MS05 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers 1987-1988 model 05-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Single rear shaft for 2 rollers 1989 model 15-48SC01 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1990 model 15-48SC02 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1991-1992 model 15-48SC03 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1993-1997 model 78360 - Uses 6203 bearings with 17mm ID - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers 1998-2007 and 2009-12 model 78361 - Uses 6203 bearings with 17mm ID - (These all use blades with 3/4" center hole) - Originally had a standard nut and lockwasher holding spindle pulley on. Two rear shafts for 2 rollers Share this post Link to post Share on other sites
peter lena 9,978 #4 Posted 6 hours ago @EthanL did you / are going to , do a bearing clean out and lubrication UPGRADE ON ALL RELATED BEARINGS ? really not that difficult , but so worth it . those 6203 bearings , really work well with , lucas , x tra hd green chassis grease , same bearings in the mule drive , pto inner cone needle bearing , clean out very light grease , application ,550 deg , polyurea , anti sling , all muel drive nearings , done , spin up is smooth easy / quiet , no pto clutch , screaming , opportunity is yours , pete Share this post Link to post Share on other sites
76c12091520h 4,269 #5 Posted 6 hours ago Part # 106073 , center keyed pulley for a 48" deck. Plenty in stock here 2 Share this post Link to post Share on other sites
