JOEPOE1977
Carburetor
JOEPOE1977
1990 Wheel Horse 310-8 CARBURETOR. Looking for a Kohler if possible or the best replacement for the carburator that is on the tractor. It has a Welbro on it. I am sending pictures of it. A Welbro if possible if new or the best replacement for it. You are the PROFESSIONALS I AM CERTAINLY NOT. I believe that it has the shaft choke on it. Thank you to all that help me all the time.
Mike'sHorseBarn
Following along as I'd like a replacement walbro for my 312-8.
JOEPOE1977
Yes I know it is a 36 year old tractor. And I also know it is going to be a hard find. SAD they don’t make things like this no more.
ri702bill
The general concensus here is that if the OE part is at all rebuildable, you are better off to go that route instead of the "it may work or not" offshore knockoff option...
  • Excellent 3
lynnmor
Exactly what part of the carburetor have you identified as worn or broken?
Retired Wrencher
check with Brian Badman 570 492 9706.
953 nut
There are several ways to deal with this situation.
1)   Buy a cheap knock-off and wish you hadn't.
2) send it to @ebinmaine, he loves to rebuild them.
3) rebuild it yourself using some information from here  https://gardentractorpullingtips.com/carbfuel.htm
4) pull the :wh: outside, with your air cleaner removed and engine running near wide open, spray some Seafoam into the throat of the carb until it almost stalls out, let it recover, repeat a couple of times. This may clear up any rough running condition you have. The huge clouds of white smoke will dissipate before the EPA arrives if you are lucky.  This has worked for me on a couple of ocasions.
ebinmaine
There's the question.
Why do you believe your particular carb needs replacing?
I appreciate the "mention"..... that's maybe not quite the phrasing I'd use.  🙂
  • Haha 2
