John c
removing spray paint
sqrlgtr
@Bar Nuthin Is that Rustoleum Canvas white on wheels?
Bar Nuthin
It's my neighbor's tractor. I'll ask him.
Bar Nuthin
Bar Nuthin
4 hours ago, Bar Nuthin said:
Less than 20 minutes ago we slapped new decals on this old horse. Between that and the freshly painted wheels, it looks a ton better. No longer has that "neglected" look, and the patina looks intentional now.
PS: the oil on the floor is from a rototiller service, not the tractor. :rolleyes:
IMG_5577.jpg.f02903ec59c9e4443cb8bc2ddd9b5f4d.jpg  IMG_5579.jpg.8a5d128c6886b80d3c289a262cc93539.jpg
Here are the "before" photos
20260711_133822.jpg.c65e9bcb1da2565967fa988a73de94bc.jpg 20260711_164230.jpg.6d16ca9916d29fe8526946aadce922f9.jpg
John c
I piddled with it a little bit this afternoon, I had acetone, charcoal lighter fluid, goof off, and actual paint stripper, the heavy gel kind, goof off and lighter fluid just barely cleaned the dirt off, acetone turned the rag a little bit pink, the stripper worked, but kinda touchy easy to go too far.
I think a mix of acetone thinned stripper and maybe a fine pad or steel wool would be the answer, but it would require some time and detailed attention to it, and then it's still an old crusted crunchy faded out sticker, and then seeing you guys pictures using new stickers on some old paint doesn't look bad at all. I think l'll plan on new decals for the hood
  • Excellent 4
c-series don
I think you’ll be happy about that decision!
ebinmaine
:text-yeahthat:
wallfish
Citrus stripper, not regular stuff. Dip the rag and wipe off the spray paint.  New decals doesn't look bad on a patina tractor and paint the rims too
CitriStrip QCSG801 32 -fl oz Regular Strength Paint stripper ( Gel )
Bar Nuthin
  • Haha 2
Handy Don
I suggest extreme caution before mixing chemicals not explicitly specified as safe.
I nearly lost a brother to a runaway exothermic reaction, i.e. the mixture blew up.
Six weeks in the hospital with massive burns. About six ounces of a mixture I won’t describe except to say it was stuff found in many homes.
953 nut
:text-yeahthat:
If it doesn't burn you the gasses given off could be harmful if not lethal.
