JOEPOE1977 1 #1 Posted August 4 Looking for a mechanical fuel pump for a 1990 Wheel Horse 310-8 tractor. It has a Kohler MC10 engine in it. Share this post Link to post Share on other sites
953 nut 69,283 #2 Posted August 4 All things considered you will be better off to replace the mechanical pump with an electric low pressure pump. Quick starts and no danger of gas in your oil. There are lots of threads on here to help you decide which pump to buy. Just leave the mechanical pump where it is, run new hoses and a filter and mount the pump lower than the tank outlet. You can power it from the wire to your hour meter, it is fused and turns off with the key. 1 1 Share this post Link to post Share on other sites
