Hurstmuscle 0 #1 Posted August 3 have a Toro Wheelhorse 416XT with a hydrostatic transmission and upgraded to Deestone 405 ag/bar 6 ply tires in the factory size 23x10-12. 5psi and I am 350+ lbs. My hill is 22 degree (40% grade). If I go past creeping the rear tires lock up and skid. thinking a softer compound tire and maybe filling them would help? I’ve spent hours and hours searching all the forums I can find. I am leaning towards Carlisle Field Trax, or an ATV tire. I could fit up to 25x12x12. I don’t want to drop $150 per tire for them to not fix my problem. I already bought the ags but will sell them if I can find a better tire. Share this post Link to post Share on other sites
pfrederi 21,150 #2 Posted August 3 (edited) Ags are directional tires the provide good traction pulling forward. They are worthless in reverse and not very good at braking (since that is somewhat the equivalent of trying to go backward) My Farmall M with 600lbs of fluid in each tire and 300 lbs of weights willl slide on gravel road if I try to stop too hard or going down hill. Edited August 3 by pfrederi 1 Share this post Link to post Share on other sites
Handy Don 17,474 #3 Posted August 3 (edited) A 22º slope of grass? No tire that I know of will eliminate potentially dangerous slippage--there just isn’t going to be enough friction regardless of weight. I’d say your options are chains on turfs or a tracked vehicle. Edited August 3 by Handy Don 6 Share this post Link to post Share on other sites
Lee1977 7,772 #4 Posted August 3 Sounds to me like you are trying to mow too fast. Hydros speed up going down hill. A Wheel Horse tractor brake only locks one wheel, the other free wheels. I mow some banks that are steeper. I have to slow up before starting down with a hydro. they can get a lot faster even in a short distance. 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,359 #5 Posted August 3 Less ply tires offer better grip. Maybe add chains and weights..but no offense at 350#you shouldn’t need additional wheel weights. Not a fan of ag tires. The Carlisle All-trails (Carlstar their called now I think) are my favorites and I run them on a couple of my machines. They are not a directional tire. The ones in this pic are 23 x8.00 x 12’s . 2 Share this post Link to post Share on other sites
rmaynard 17,582 #6 Posted August 3 My rule of thumb is don't mow grades. But if you do, don't exceed a grade of 15°. Share this post Link to post Share on other sites
8ntruck 9,296 #7 Posted August 3 (edited) the maximum recommended operating angle for Kohler engines is 15 deg. I expect other engine manufacturers use about the same recommendations. Edited August 3 by 8ntruck Share this post Link to post Share on other sites
c-series don 12,446 #8 Posted August 3 1 hour ago, Sparky said: Not a fan of ag tires Here we go again Mike, this is why you should let me come get those 23x10.50-12’s that you should never use 🤣🤣🤣 3 Share this post Link to post Share on other sites
John2189 601 #9 Posted August 3 (edited) 9 hours ago, pfrederi said: Ags are directional tires the provide good traction pulling forward. They are worthless in reverse and not very good at braking (since that is somewhat the equivalent of trying to go backward) My Farmall M with 600lbs of fluid in each tire and 300 lbs of weights willl slide on gravel road if I try to stop too hard or going down hill. Why don’t you try swapping the ag tires? Put the right on the left and left on the right. maybe they will grab better. But, they might not be that good going uphill. It would be worth a try.🤷🏻♂️ Edited August 3 by John2189 Share this post Link to post Share on other sites
953 nut 69,292 #10 Posted August 4 Gear jammer or Hydro, you can mow up a hill much better than down, Simple physics, going up hill the weight of the tractor is being applied to the rear axle, going down a hill the weight is being transferred toward the front axle. I have used tire chains while mowing a steep grade, if you don't spin the tires they won't harm the grass. 3 1 Share this post Link to post Share on other sites
kpinnc 18,960 #11 Posted August 4 (edited) 4 hours ago, rmaynard said: My rule of thumb is don't mow grades. But if you do, don't exceed a grade of 15°. Another rule of thumb comes from zero turns: if you can't back up the entire hill without wheelspin you should not mow it with said machine. If it's steep enough to slide it's well past steep enough to flip. One thing to note: your ag tires might grip better running backwards initially, but when they finally slip they will slide like an ice rink because the chevron shape running correctly should "shed" whatever it pulls up. Running backwards will compact any debris and hold it making the tread useless. Edited August 4 by kpinnc 4 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #12 Posted August 4 13 hours ago, Sparky said: Less ply tires offer better grip. Maybe add chains and weights..but no offense at 350#you shouldn’t need additional wheel weights. Not a fan of ag tires. The Carlisle All-trails (Carlstar their called now I think) are my favorites and I run them on a couple of my machines. They are not a directional tire. The ones in this pic are 23 x8.00 x 12’s . Mike That is what I was thinking in this post. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,989 #13 Posted August 4 10 hours ago, 953 nut said: Gear jammer or Hydro, you can mow up a hill much better than down, Simple physics, going up hill the weight of the tractor is being applied to the rear axle, going down a hill the weight is being transferred toward the front axle. I have used tire chains while mowing a steep grade, if you don't spin the tires they won't harm the grass. 1 Share this post Link to post Share on other sites
Pullstart 71,233 #14 Posted August 4 18 hours ago, Lee1977 said: A Wheel Horse tractor brake only locks one wheel, the other free wheels. To clarify, most every Wheel Horse has an open differential. Preference to the less grip is applied when moving forward, backward, or slowing down. The brake is not simply on one wheel. I know you know what you mean Lee, but I figured it’s worth mentioning for future reading. 2 Share this post Link to post Share on other sites
Pullstart 71,233 #15 Posted August 4 13 hours ago, Sparky said: Maybe add chains and weights..but no offense at 350#you shouldn’t need additional wheel weights. I might recommend a little more than 5 psi, or fluid fill the tires. But more weight unsprung is always a good idea. It’ll keep the effects of that open differential less noticeable for slip. 1 Share this post Link to post Share on other sites
peter lena 10,065 #16 Posted August 6 @Sparky hiding in plane site ? nothing sarcastic , but that deck is at perfect stage for penetrating oil spray down , ? obviousely avoiding belts , that paint penetrant will recover / enhance that deck paint , leave it on for weeks , hot sun is best for absorption , then clean it off with a , clean cloth mineral oil , rub down , its so / easy and simple , done a lot of it , you are right there , easy , try a spot pete, , Share this post Link to post Share on other sites
