Retired Wrencher 7,034 #1 Posted August 1 I was on you tube a few weeks ago, and I found this page that had a case dealership in Connecticut I believe.. He had this new tool that I’ve never heard about how to safely clean the top end of the engine and the head. It’s nylon attached to steel that you can put in your drill or whatever. You spray it down with like fantastic or some kind of household cleaner, but let it sit for about 10 minutes. These nylon attachments made the whole head and top of the engine clean within a 10 minutes. I was truly impressed on that. The other bonus it doesn’t leave any scratches or gouging of the material which according to this video it’s the first place where carbon will build up. So here’s a couple pics before and after this was about 10 minutes worth of work. The orange is course this kit came with two others gray, which is a medium grit and I believe the blue is a fine grit. I’m sold on this so far much easier. I used to use steel but at left a lot of scratches. 14 Share this post Link to post Share on other sites
953 nut 70,276 #2 Posted August 1 D you have a link to the video or the product? 2 Share this post Link to post Share on other sites
ebinmaine 81,119 #3 Posted August 1 Looks like this gives excellent results. Remember to hand plane the cylinder head for flatness too. 2 Share this post Link to post Share on other sites
peter lena 10,106 #4 Posted August 1 @Retired Wrencher that fuel, oil related varnish , is the issue , 2 things I changed to years ago , sta bil , enhances fuel cleaning debris , another major cleaner ? zinc, been adding rislone zinc , typically 2 to3 oz to a fresh oil change , also like the valvoline 10-30 VR1 flat tappet oil , no smoke or varnish . repetitive problems , are simply something I have to get after . after EVERY USAGE , I go after a regular check over , for FEED BACK , HOW IS IT DOING ? WHAT IS IT DOING ? need a tweak ? over 40 years , regular maintenance , go to what makes it bombproof , my screaming pto neighbor , has no clue , pete 3 Share this post Link to post Share on other sites
8ntruck 9,375 #5 Posted August 1 32 minutes ago, peter lena said: valvoline 10-30 VR1 flat tappet oil First I've heard of this product. I wonder how the specs compare to the Rotella 30 wt? Share this post Link to post Share on other sites
peter lena 10,106 #6 Posted August 1 @8ntruck actually its a very good , oil made for older type engines , with the latest upgrades , thing I notice most is , operational , running ease , definitely happier , smoother , also better on fuel for related usage . none of my engines , smoke in any phase. near instant starts , very impressed with its smooth / quick response . no oil usage at all , better fuel use , my experience , pete 1 Share this post Link to post Share on other sites
sqrlgtr 4,172 #7 Posted August 1 4 hours ago, 8ntruck said: First I've heard of this product. I wonder how the specs compare to the Rotella 30 wt? Ive used both and have had good luck with both. The VR1 has a higher zinc content and is designed for run in flat tappet race engines (high rpm) and not as easy to find, around these parts anyhow. Share this post Link to post Share on other sites
squonk 48,315 #8 Posted August 1 I wouldn't knock yourself out looking for VR1 oil over Rotella. These are lawn mowers. Not Indy cars or space ships! 3 1 1 1 Share this post Link to post Share on other sites
8ntruck 9,375 #9 Posted August 1 15 minutes ago, squonk said: I wouldn't knock yourself out looking for VR1 oil over Rotella. These are lawn mowers. Not Indy cars or space ships! Yup. Our wide open speed isn't much more than the idle speed on some of those race engines. Share this post Link to post Share on other sites
pfrederi 21,291 #10 Posted August 1 Over the years I have use synthetic , expensive stuff and wally world stuff...never heard an engine sound different Haven't had an oil related failures either... 2 1 Share this post Link to post Share on other sites
ebinmaine 81,119 #11 Posted August 1 Change it on time. That is all. 3 1 Share this post Link to post Share on other sites
Retired Wrencher 7,034 #12 Posted August 2 22 hours ago, 953 nut said: D you have a link to the video or the product? Yes. Just not sure of location. I see if I can post link. Share this post Link to post Share on other sites
Retired Wrencher 7,034 #13 Posted August 2 21 hours ago, ebinmaine said: Looks like this gives excellent results. Remember to hand plane the cylinder head for flatness too. I will Eric. Thanks. Share this post Link to post Share on other sites
Retired Wrencher 7,034 #14 Posted August 2 23 hours ago, 953 nut said: D you have a link to the video or the product? Just can not find the like Richard. I am Computer illiterate. I just get buy. 2 Share this post Link to post Share on other sites
953 nut 70,276 #15 Posted August 2 21 hours ago, 8ntruck said: First I've heard of this product. I wonder how the specs compare to the Rotella 30 wt? VR1 would be about the same as any oil made for use in a deisal engine. 16 hours ago, squonk said: These are lawn mowers. Not Indy cars or space ships! Not too sure how long an Indy Car or a Space Ship would hold up with ValvolineVR1 or Rotella 30 Share this post Link to post Share on other sites
Cee245 874 #16 Posted 7 hours ago I found it. I first watched this years ago when I did my 416h Share this post Link to post Share on other sites
Retired Wrencher 7,034 #17 Posted 6 hours ago Thanks for the post CEE! Share this post Link to post Share on other sites
Wild Bill 633 943 #18 Posted 5 hours ago (edited) On 8/1/2026 at 10:06 AM, peter lena said: zinc, been adding rislone zinc , typically 2 to3 oz to a fresh oil change , also like the valvoline 10-30 VR1 flat tappet oil Per the Valvoline product info sheet, VR-1 10W30 has 1100 ppm zinc. Per the Risoline product data sheet, "With typical SN rated oil at a 7% dosage rate (4.5 oz. added to 2 qts.) expect levels to be raised a total of 1700-1800 ppm." Standard oils, for example SN, have a max. 800 ppm, due to catalytic converters. Older flat tappet engines benefit from 1000-1200 ppm. Danger zone: levels pushed past 1400-1900 ppm cross the threshold where corrosive damage and accelerated wear start to take over. Adding Rislone zinc additive to Valvoline VR-1 pushes the zinc ppm into the danger zone. As a famous tribologist, Lake Speed Jr. says, "If you have to use additives to oil, then you are using the wrong oil." Edited 4 hours ago by Wild Bill 633 2 Share this post Link to post Share on other sites
Bar Nuthin 3,514 #19 Posted 4 hours ago (edited) On 8/1/2026 at 7:01 AM, 953 nut said: D you have a link to the video or the product? I believe these are the style of discs he's referring to. I can't see @Retired Wrencher's photos. Available from several different suppliersin arbor style or the twist in Roloc style, with 3M/Scotchbrite being a premium mfr. When I worked at a GM dealership, GM mandated this type of disc over the standard ROLOC discs due to fibers that could possibly shed. click photo to see on Amazon Edited 4 hours ago by Bar Nuthin Share this post Link to post Share on other sites
