Retired Wrencher 6,810 #1 Posted 12 hours ago I was on you tube a few weeks ago, and I found this page that had a case dealership in Connecticut I believe.. He had this new tool that I’ve never heard about how to safely clean the top end of the engine and the head. It’s nylon attached to steel that you can put in your drill or whatever. You spray it down with like fantastic or some kind of household cleaner, but let it sit for about 10 minutes. These nylon attachments made the whole head and top of the engine clean within a 10 minutes. I was truly impressed on that. The other bonus it doesn’t leave any scratches or gouging of the material which according to this video it’s the first place where carbon will build up. So here’s a couple pics before and after this was about 10 minutes worth of work. The orange is course this kit came with two others gray, which is a medium grit and I believe the blue is a fine grit. I’m sold on this so far much easier. I used to use steel but at left a lot of scratches. 12 Share this post Link to post Share on other sites
953 nut 67,537 #2 Posted 11 hours ago D you have a link to the video or the product? 2 Share this post Link to post Share on other sites
ebinmaine 79,749 #3 Posted 8 hours ago Looks like this gives excellent results. Remember to hand plane the cylinder head for flatness too. 1 Share this post Link to post Share on other sites
peter lena 9,958 #4 Posted 7 hours ago @Retired Wrencher that fuel, oil related varnish , is the issue , 2 things I changed to years ago , sta bil , enhances fuel cleaning debris , another major cleaner ? zinc, been adding rislone zinc , typically 2 to3 oz to a fresh oil change , also like the valvoline 10-30 VR1 flat tappet oil , no smoke or varnish . repetitive problems , are simply something I have to get after . after EVERY USAGE , I go after a regular check over , for FEED BACK , HOW IS IT DOING ? WHAT IS IT DOING ? need a tweak ? over 40 years , regular maintenance , go to what makes it bombproof , my screaming pto neighbor , has no clue , pete Share this post Link to post Share on other sites
8ntruck 9,082 #5 Posted 6 hours ago 32 minutes ago, peter lena said: valvoline 10-30 VR1 flat tappet oil First I've heard of this product. I wonder how the specs compare to the Rotella 30 wt? Share this post Link to post Share on other sites
peter lena 9,958 #6 Posted 4 hours ago @8ntruck actually its a very good , oil made for older type engines , with the latest upgrades , thing I notice most is , operational , running ease , definitely happier , smoother , also better on fuel for related usage . none of my engines , smoke in any phase. near instant starts , very impressed with its smooth / quick response . no oil usage at all , better fuel use , my experience , pete 1 Share this post Link to post Share on other sites
sqrlgtr 3,335 #7 Posted 2 hours ago 4 hours ago, 8ntruck said: First I've heard of this product. I wonder how the specs compare to the Rotella 30 wt? Ive used both and have had good luck with both. The VR1 has a higher zinc content and is designed for run in flat tappet race engines (high rpm) and not as easy to find, around these parts anyhow. Share this post Link to post Share on other sites
squonk 47,450 #8 Posted 1 hour ago I wouldn't knock yourself out looking for VR1 oil over Rotella. These are lawn mowers. Not Indy cars or space ships! 1 1 Share this post Link to post Share on other sites
8ntruck 9,082 #9 Posted 1 hour ago 15 minutes ago, squonk said: I wouldn't knock yourself out looking for VR1 oil over Rotella. These are lawn mowers. Not Indy cars or space ships! Yup. Our wide open speed isn't much more than the idle speed on some of those race engines. Share this post Link to post Share on other sites
pfrederi 20,906 #10 Posted 23 minutes ago Over the years I have use synthetic , expensive stuff and wally world stuff...never heard an engine sound different Haven't had an oil related failures either... 1 Share this post Link to post Share on other sites
ebinmaine 79,749 #11 Posted 20 minutes ago Change it on time. That is all. 1 Share this post Link to post Share on other sites
