Walleye Guy 27 #1 Posted yesterday at 03:20 PM Regarding the glass bowl fuel filter, where can I buy a replacement fuel filter element and gasket to seal the glass bowl to the filter casting? I tried Then & Now Automotive, which is where I bought the kit to rebuild the pulse fuel pump, but they said they replace the elements with a screen and I think I'd rather stick with the original style element. If possible. Wheel Horse 753 (1963 model year) Kohler Engine: 7 hp, SN 652365, Engine Spec Number 28626E, Engine Model Number is K161S Thanks in advance… Share this post Link to post Share on other sites
Achto 32,125 #2 Posted yesterday at 03:26 PM 4 minutes ago, Walleye Guy said: where can I buy a replacement fuel filter element and gasket to seal the glass bowl to the filter casting? https://www.amazon.com/THUNDERMINGO-Replacement-393169-Wisconsin-13117RPR2/dp/B0DSF87B74/ref=pd_lpo_d_sccl_1/135-9541748-5638623 https://www.amazon.com/YAMAKATO-Inline-Filters-Motorcycle-Snowmobile/dp/B0DXKSTCMB/ref=sr_1_6 This is the combo I run on all my round hoods. 3 Share this post Link to post Share on other sites
Walleye Guy 27 #3 Posted yesterday at 04:08 PM We actually tried an aftermarket glass bowl filter assembly but the needle leaks on it so we thought we'd try to go back to the original unit and get an element and gasket for it. 2 Share this post Link to post Share on other sites
rmaynard 17,439 #4 Posted 20 hours ago I've always had good luck with Briggs & Stratton 393169 OEM available from Parts Tree Share this post Link to post Share on other sites
Walleye Guy 27 #5 Posted 20 hours ago That's a great suggestion and...if I strike out finding a replacement element...I will probably do that. Share this post Link to post Share on other sites
squonk 47,442 #6 Posted 20 hours ago (edited) Napa. There are 2 sizes. I sold a boatload of bowls and gaskets back in the day. Most likely bowl size BK S66147 Gasket/screen BK S65544 Edited 20 hours ago by squonk 1 Share this post Link to post Share on other sites
Walleye Guy 27 #7 Posted 19 hours ago Does using the screen eliminate the feature of debris collecting at the bottom of the glass bowl? Share this post Link to post Share on other sites
pfrederi 20,904 #8 Posted 19 hours ago no. The purpose is the gas comes into the bowl and the junk has a chance to settle out then the gas exits through the screen to the carb 2 Share this post Link to post Share on other sites
ineedanother 2,629 #9 Posted 18 hours ago I believe this is what you're looking for @Walleye Guy https://www.lilredbarn.net/product-p/lrb14503.htm Share this post Link to post Share on other sites
953 nut 67,521 #10 Posted 17 hours ago 7 hours ago, Walleye Guy said: aftermarket glass bowl filter assembly but the needle leaks on it Did you tighten the packing nut on the new one? Share this post Link to post Share on other sites
sqrlgtr 3,324 #11 Posted 17 hours ago 8 hours ago, Achto said: https://www.amazon.com/THUNDERMINGO-Replacement-393169-Wisconsin-13117RPR2/dp/B0DSF87B74/ref=pd_lpo_d_sccl_1/135-9541748-5638623 https://www.amazon.com/YAMAKATO-Inline-Filters-Motorcycle-Snowmobile/dp/B0DXKSTCMB/ref=sr_1_6 This is the combo I run on all my round hoods. great minds think alike this is exactly same combo I run on my round hoods, I could get this cheap as I could try and rebuild old one. Share this post Link to post Share on other sites
Walleye Guy 27 #12 Posted 4 hours ago 12 hours ago, 953 nut said: Did you tighten the packing nut on the new one? No, I didn't know this was necessary. Please explain... Share this post Link to post Share on other sites
Blaine 248 #13 Posted 3 hours ago (edited) 34 minutes ago, Walleye Guy said: No, I didn't know this was necessary. Please explain... Tightening the nut just enough to squeeze the packing tighter around the needle to stop it from leaking, and then a tad more. Too tight only makes the needle hard to turn and can destroy the packing. Honestly i only ever close mine at the end of mowing season. I close it and let the motor run the carb bowl empty. Edited 3 hours ago by Blaine 1 1 Share this post Link to post Share on other sites
Walleye Guy 27 #14 Posted 3 hours ago 10 minutes ago, Blaine said: Tightening the nut just enough to squeeze the packing tighter around the needle to stop it from leaking, and then a tad more. Too tight only makes the needle hard to turn and can destroy the packing. Honestly i only ever close mine at the end of mowing season. I close it and let the motor run the carb bowl empty. OK, I'll try this and see if it works but my dad who owns the mower (his dad, my grandfather, bought it new) would prefer to keep it as original as possible. Thus, still hoping to get a replacement element for the original glass bowl filter. 1 Share this post Link to post Share on other sites
