Walleye Guy 28 #1 Posted July 30 Regarding the glass bowl fuel filter, where can I buy a replacement fuel filter element and gasket to seal the glass bowl to the filter casting? I tried Then & Now Automotive, which is where I bought the kit to rebuild the pulse fuel pump, but they said they replace the elements with a screen and I think I'd rather stick with the original style element. If possible. Wheel Horse 753 (1963 model year) Kohler Engine: 7 hp, SN 652365, Engine Spec Number 28626E, Engine Model Number is K161S Thanks in advance… Share this post Link to post Share on other sites
Achto 32,715 #2 Posted July 30 4 minutes ago, Walleye Guy said: where can I buy a replacement fuel filter element and gasket to seal the glass bowl to the filter casting? https://www.amazon.com/THUNDERMINGO-Replacement-393169-Wisconsin-13117RPR2/dp/B0DSF87B74/ref=pd_lpo_d_sccl_1/135-9541748-5638623 https://www.amazon.com/YAMAKATO-Inline-Filters-Motorcycle-Snowmobile/dp/B0DXKSTCMB/ref=sr_1_6 This is the combo I run on all my round hoods. 4 Share this post Link to post Share on other sites
Walleye Guy 28 #3 Posted July 30 We actually tried an aftermarket glass bowl filter assembly but the needle leaks on it so we thought we'd try to go back to the original unit and get an element and gasket for it. 2 Share this post Link to post Share on other sites
rmaynard 17,582 #4 Posted July 30 I've always had good luck with Briggs & Stratton 393169 OEM available from Parts Tree 1 Share this post Link to post Share on other sites
Walleye Guy 28 #5 Posted July 30 That's a great suggestion and...if I strike out finding a replacement element...I will probably do that. Share this post Link to post Share on other sites
squonk 48,126 #6 Posted July 30 (edited) Napa. There are 2 sizes. I sold a boatload of bowls and gaskets back in the day. Most likely bowl size BK S66147 Gasket/screen BK S65544 Edited July 30 by squonk 1 Share this post Link to post Share on other sites
Walleye Guy 28 #7 Posted July 30 Does using the screen eliminate the feature of debris collecting at the bottom of the glass bowl? Share this post Link to post Share on other sites
pfrederi 21,151 #8 Posted July 30 no. The purpose is the gas comes into the bowl and the junk has a chance to settle out then the gas exits through the screen to the carb 2 Share this post Link to post Share on other sites
ineedanother 2,866 #9 Posted July 30 I believe this is what you're looking for @Walleye Guy https://www.lilredbarn.net/product-p/lrb14503.htm Share this post Link to post Share on other sites
953 nut 69,336 #10 Posted July 30 7 hours ago, Walleye Guy said: aftermarket glass bowl filter assembly but the needle leaks on it Did you tighten the packing nut on the new one? Share this post Link to post Share on other sites
sqrlgtr 3,932 #11 Posted July 31 8 hours ago, Achto said: https://www.amazon.com/THUNDERMINGO-Replacement-393169-Wisconsin-13117RPR2/dp/B0DSF87B74/ref=pd_lpo_d_sccl_1/135-9541748-5638623 https://www.amazon.com/YAMAKATO-Inline-Filters-Motorcycle-Snowmobile/dp/B0DXKSTCMB/ref=sr_1_6 This is the combo I run on all my round hoods. great minds think alike this is exactly same combo I run on my round hoods, I could get this cheap as I could try and rebuild old one. 1 Share this post Link to post Share on other sites
Walleye Guy 28 #12 Posted July 31 12 hours ago, 953 nut said: Did you tighten the packing nut on the new one? No, I didn't know this was necessary. Please explain... Share this post Link to post Share on other sites
Blaine 276 #13 Posted July 31 (edited) 34 minutes ago, Walleye Guy said: No, I didn't know this was necessary. Please explain... Tightening the nut just enough to squeeze the packing tighter around the needle to stop it from leaking, and then a tad more. Too tight only makes the needle hard to turn and can destroy the packing. Honestly i only ever close mine at the end of mowing season. I close it and let the motor run the carb bowl empty. Edited July 31 by Blaine 1 1 Share this post Link to post Share on other sites
Walleye Guy 28 #14 Posted July 31 10 minutes ago, Blaine said: Tightening the nut just enough to squeeze the packing tighter around the needle to stop it from leaking, and then a tad more. Too tight only makes the needle hard to turn and can destroy the packing. Honestly i only ever close mine at the end of mowing season. I close it and let the motor run the carb bowl empty. OK, I'll try this and see if it works but my dad who owns the mower (his dad, my grandfather, bought it new) would prefer to keep it as original as possible. Thus, still hoping to get a replacement element for the original glass bowl filter. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #15 Posted July 31 5 hours ago, Walleye Guy said: OK, I'll try this and see if it works but my dad who owns the mower (his dad, my grandfather, bought it new) would prefer to keep it as original as possible. Thus, still hoping to get a replacement element for the original glass bowl filter. I used one of the above vendors to get a replacement bowl (and since acquired a spare on the shelf) Cut my own bowl gasket. For me, the sediment bowl and screen did not get the finest debris so some still got through and clog the carb jet. Added a second filter like @Achto and all is good. The packing surrounds the outlet needle valve’s shaft. Tighten that nut as noted above until the fuel is no longer seeping out when the engine is not running. On mine, the seep was undetectable visually, but I could smell fuel. 1 Share this post Link to post Share on other sites
Walleye Guy 28 #16 Posted August 10 Was the original set-up a gasket and a filter screen as separate parts or was the gasket and screen one part (ie was the gasket molded around the perimeter of the screen)? Share this post Link to post Share on other sites
pfrederi 21,151 #17 Posted August 10 3 minutes ago, Walleye Guy said: Was the original set-up a gasket and a filter screen as separate parts or was the gasket and screen one part (ie was the gasket molded around the perimeter of the screen)? Separate 1 Share this post Link to post Share on other sites
sqrlgtr 3,932 #18 Posted August 10 This is the one I replaced mine with. Never could keep the old one from leaking from around the fuel shut off and I tried a couple times . 1 Share this post Link to post Share on other sites
Walleye Guy 28 #19 Posted August 10 (edited) 42 minutes ago, pfrederi said: Separate So, TWO gaskets and one screen were required? Or did you set extra parts next to each other for clarification? Edited August 10 by Walleye Guy Share this post Link to post Share on other sites
Handy Don 17,474 #20 Posted August 10 1 hour ago, Walleye Guy said: So, TWO gaskets and one screen were required? Or did you set extra parts next to each other for clarification? The original might have had the screen gasket-sandwiched into a single part, but I separated and used two gaskets. Share this post Link to post Share on other sites
pfrederi 21,151 #21 Posted August 11 15 hours ago, Walleye Guy said: So, TWO gaskets and one screen were required? Or did you set extra parts next to each other for clarification? One gasket one screen..note the discoloration on the screen on the left. It is not as big around as the gasket so the gasket completes it seal out side the screen Share this post Link to post Share on other sites
Walleye Guy 28 #22 Posted August 14 Update: today, through two different Ebay sellers, I ordered an OEM Kohler fuel bowl gasket and filter screen. I appreciate the input from everyone who posted here. 1 Share this post Link to post Share on other sites
