Walleye Guy 25 #1 Posted 7 hours ago Regarding the glass bowl fuel filter, where can I buy a replacement fuel filter element and gasket to seal the glass bowl to the filter casting? I tried Then & Now Automotive, which is where I bought the kit to rebuild the pulse fuel pump, but they said they replace the elements with a screen and I think I'd rather stick with the original style element. If possible. Wheel Horse 753 (1963 model year) Kohler Engine: 7 hp, SN 652365, Engine Spec Number 28626E, Engine Model Number is K161S Thanks in advance… Share this post Link to post Share on other sites
Achto 32,119 #2 Posted 7 hours ago 4 minutes ago, Walleye Guy said: where can I buy a replacement fuel filter element and gasket to seal the glass bowl to the filter casting? https://www.amazon.com/THUNDERMINGO-Replacement-393169-Wisconsin-13117RPR2/dp/B0DSF87B74/ref=pd_lpo_d_sccl_1/135-9541748-5638623 https://www.amazon.com/YAMAKATO-Inline-Filters-Motorcycle-Snowmobile/dp/B0DXKSTCMB/ref=sr_1_6 This is the combo I run on all my round hoods. Share this post Link to post Share on other sites
Walleye Guy 25 #3 Posted 6 hours ago We actually tried an aftermarket glass bowl filter assembly but the needle leaks on it so we thought we'd try to go back to the original unit and get an element and gasket for it. 1 Share this post Link to post Share on other sites
rmaynard 17,435 #4 Posted 2 hours ago I've always had good luck with Briggs & Stratton 393169 OEM available from Parts Tree Share this post Link to post Share on other sites
Walleye Guy 25 #5 Posted 1 hour ago That's a great suggestion and...if I strike out finding a replacement element...I will probably do that. Share this post Link to post Share on other sites
squonk 47,423 #6 Posted 1 hour ago (edited) Napa. There are 2 sizes. I sold a boatload of bowls and gaskets back in the day. Most likely bowl size BK S66147 Gasket/screen BK S65544 Edited 1 hour ago by squonk Share this post Link to post Share on other sites
Walleye Guy 25 #7 Posted 1 hour ago Does using the screen eliminate the feature of debris collecting at the bottom of the glass bowl? Share this post Link to post Share on other sites
pfrederi 20,898 #8 Posted 32 minutes ago no. The purpose is the gas comes into the bowl and the junk has a chance to settle out then the gas exits through the screen to the carb Share this post Link to post Share on other sites
ineedanother 2,624 #9 Posted 21 minutes ago I believe this is what you're looking for @Walleye Guy https://www.lilredbarn.net/product-p/lrb14503.htm Share this post Link to post Share on other sites
