sqrlgtr
Headlight Bucket Refurb
ri702bill
Posted (edited)
That ground wire is super important - when I reburbed the C81, I used a 2 wire polarized trailer plug pair at the hood hinge so that the wiring could be easily unplugged if the hood needed to be removed. Sorry, no picture...
Edited by ri702bill
  • Like 4
sqrlgtr
Funny I had a trailer plug that I was going to use but could only find one side of it. Probably step on it tomorrow :D. I tied hot wires coming from light sockets together then used bullet connectors for them and ground wire fer a quick disconnect. Also put inline fuse between light switch and ignition switch fer peace of mind.
  • Like 4
ebinmaine
Niiiiice!
MainelyWheelhorse
Posted (edited)
@sqrlgtr how much of a PITA was the headlight bucket to get out of the hood? I’m thinking about pulling the one out of the C-141 and refurbing it. It doesn’t look super complicated, but I figured I’d get a good idea what I was in for. Nice work too, looks like the LED’s are definitely an upgrade from the stock bulbs.
Edited by MainelyWheelhorse
sqrlgtr
56 minutes ago, MainelyWheelhorse said:
@sqrlgtr how much of a PITA was the headlight bucket to get out of the hood? I’m thinking about pulling the one out of the C-141 and refurbing it. It doesn’t look super complicated, but I figured I’d get a good idea what I was in for. Nice work too, looks like it’s definitely a  upgrade from the stock bulbs.
I just used hand drill to drill out old rivets. My headlight bucket had been "worked on" before and someone had ruined the light sockets, so I had to take a center punch and go around the lip of socket to get them out. Actually, took longer to remove light sockets :D and clean the 40yrs of dirt and grim off than anything else. If you don't have to remove old light sockets it isn't bad at all. You shouldn't have any trouble if you decide to tackle it.
ebinmaine
The ones we've removed were riveted in.
Drilling rivets can be a challenge if they start to spin.
Otherwise fairly straightforward.
MainelyWheelhorse
@ebinmaine I got the rivets out pretty easy the headlight bucket came right out. In the process of shining it up a small piece broke out but I JB welded it and I’m just waiting for it to cure.
