mjf8267 0 #1 Posted July 25 I'm loosing my mind! I have a 1998 522xi model 73561. I have a 1998 52" side discharge mowing deck model 78370 . I need a replacement PTO drive belt. I've replaced it in the past and now I cant determine the part number for the life of me. I also have the 42" snowthrower, but the PTO V-belt is not the same length belt (and I already have a replacement in my shed if needed). I've looked on the Toro website but can't seem to find the part in the tractor parts or the mower deck parts - what the heck am I missing, doing wrong? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #2 Posted July 25 Belts are listed in the mower ipl. Click on the picture in the link and they are on the page that comes up. 2 Share this post Link to post Share on other sites
JoeM 10,317 #3 Posted July 25 Toro xi belt notes 95-4094 (5/8" x 96.7") drive belt for 52" deck - This belt is correct and also used with 44" decks 2 Share this post Link to post Share on other sites
953 nut 69,786 #4 Posted July 25 @mjf8267, if you would like to tell us more about your Wheel Horse and how you came to own it pleas do an introduction. https://www.wheelhorseforum.com/forum/47-introductions/ 1 Share this post Link to post Share on other sites
peter lena 10,087 #5 Posted July 26 @mjf8267 while zeroing in on those belts , most important part of that is ? rotational movement EASE AT EVERY PULLEY , its the COLLECTIVE DRAG that kills any belt set up , look for any bearing hang up or roughness , of course bearing WHINE IS TELLING YOU WHAT ? LUBRICATION FAIURE ! that related failure also EATS PTO DRIVE CLUTCHES , every / any related movement area , should move with , smooth / solid / ease . have this set up on my 3 horses , many years in , absolutely no related failures or movement issues , isn,t that what you want ? easy to remove bearing , side grease shields , wipe out , carb cleaner flush out , repack with lucas xtra hd green chassis grease , 550 deg flash point , polyurea rated , stays with bearing , making sense ? I have no bearing failures / or related whyining , basic set up for my 3 horses , never failed , pete 1 Share this post Link to post Share on other sites
mjf8267 0 #6 Posted July 26 Thank you all for the help. This forum is awesome. Share this post Link to post Share on other sites
