jsp_333 294 #1 Posted July 24 I told my neighbour I'd take a look at his cub cadet before he had to sell it as a no start. So here's is what I've determined so far Kohler KS595 (5400 series, 541cc, ~2020/2021), Cub Cadet LT46, sat since 2022, no-start • Spark confirmed: inline tester, plug installed under compression, strong/consistent flash while cranking • Compression: 170 psi (healthy for this engine) • Ether sprayed directly into cylinder at TDC compression stroke (valves closed) — still won’t fire • Ignition module air gap checked, in spec (~0.010”) • Battery removed; Jumper cables from 2025 Sierra to battery leads. • Tiny little original 12v battery sits in alcove under the seat • No history of impact/tampering — sat parked since owner couldn’t get it running approx 2021 • Ruling out: carb issues (ether bypasses carb entirely), weak battery/cranking speed (tested off truck battery, strong consistent crank) Anybody have any other ideas or did I miss something obvious. Cheers. Share this post Link to post Share on other sites
953 nut 68,501 #2 Posted July 24 Kohler Command engines are somewhat prone to have sheared flywheel keys that will allow the ignition to occur at the wrong time. 1 Share this post Link to post Share on other sites
TT-(Moderator) 1,173 #3 Posted July 25 Plugged exhaust? Share this post Link to post Share on other sites
jsp_333 294 #4 Posted July 25 Plugged exhaust? Like with a mouse nest built over the winter? I'll have a look. Thx. As for sheared flywheel key that's where I was going next but don't have the correct Kohler puller so that means a trip to the shop which I was trying to avoid. But at this point everything else is pretty much exhausted except for a critter home. Just went out and looked at the tractor. Muffler and exhaust are underneath the front end about 3" off the ground. Ideal spot for a critter. I'm Going to put a shop vac up to the exhaust pipe and see what comes out.. Never would've thought of that. Cheers. Share this post Link to post Share on other sites
Bill D 3,099 #5 Posted July 25 Did you check for spark? Could have an activated safety switch that is cutting the ignition out. Share this post Link to post Share on other sites
953 nut 68,501 #6 Posted July 25 21 hours ago, jsp_333 said: Spark confirmed: inline tester, plug installed under compression, strong/consistent flash while cranking 16 minutes ago, Bill D said: Did you check for spark? Could have an activated safety switch that is cutting the ignition out. Yes he did but is it occurring at the proper time? Share this post Link to post Share on other sites
jsp_333 294 #7 Posted July 25 (edited) 42 minutes ago, 953 nut said: Yes he did but is it occurring at the proper time? Speaks to flywheel key I suppose. I'm going to examine the exhaust system right now because this is really bugging me. So there is nothing living or dead in the muffler. Happened to have a shop vac attachment that made a good seal on the muffler. Even released the muffler from exhaust port and had suction from the shop vac. So back to flywheel key. Edited July 25 by jsp_333 updating information 2 Share this post Link to post Share on other sites
jsp_333 294 #8 Posted July 28 Examined the flywheel key today... Nuthin. It looked like it was supposed to. In place and aligned. 1 Share this post Link to post Share on other sites
