jsp_333 291 #1 Posted 1 hour ago I told my neighbour I'd take a look at his cub cadet before he had to sell it as a no start. So here's is what I've determined so far Kohler KS595 (5400 series, 541cc, ~2020/2021), Cub Cadet LT46, sat since 2022, no-start • Spark confirmed: inline tester, plug installed under compression, strong/consistent flash while cranking • Compression: 170 psi (healthy for this engine) • Ether sprayed directly into cylinder at TDC compression stroke (valves closed) — still won’t fire • Ignition module air gap checked, in spec (~0.010”) • Battery removed; Jumper cables from 2025 Sierra to battery leads. • Tiny little original 12v battery sits in alcove under the seat • No history of impact/tampering — sat parked since owner couldn’t get it running approx 2021 • Ruling out: carb issues (ether bypasses carb entirely), weak battery/cranking speed (tested off truck battery, strong consistent crank) Anybody have any other ideas or did I miss something obvious. Cheers. Share this post Link to post Share on other sites
