Joshyg 40 #1 Posted July 23 My c-145 auto is dropping its rpms when the throttle is open. It mainly happens when I’m mowing or driving and I have to jam it up to have the deck cut right: note it is a 48in side discharge. Please help, all advice is appreciated Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #2 Posted July 23 Your throttle control is a lever - correct? Why it happens is the cable pulls on a spring connected to the governor arm to increase rpm. As the throttle is used to increase rpm the governor creates an opposing force to slow the rpm down. The higher the rpm the more force created by both. To fix the problem the throttle lever requires more tension at the pivot. You can remove the control and try pinching the pivot rivet tighter to increase tension. For a permanent fix remove the rivet and replace with a bolt with about 5/16"-3/8" of unthreaded shank. Add flat washers to take up the extra length and cut off what is not needed. Add a nylon insert nut that you use to adjust the tension required to hold the throttle in position at high rpm. The unthreaded shank in the pivot area reduces the wear on the moving parts. If there were threads there everything wears fast. If the problem reoccurs in the future just go in with two wrenches and adjust. 2 Share this post Link to post Share on other sites
Joshyg 40 #3 Posted July 23 (edited) So is it the governor spring that needs readjusted or something else because that spring controls how responsive the governor is. Please Correct me if I’m wrong Edited July 23 by Joshyg Share this post Link to post Share on other sites
lynnmor 9,010 #4 Posted July 23 3 minutes ago, Joshyg said: So is it the governor spring that needs readjusted or something else because that spring controls how responsive the governor is. Please Correct me if I’m wrong Wrong, read it again. Put more drag on the throttle lever at the dash. Share this post Link to post Share on other sites
Joshyg 40 #5 Posted July 23 Oh ok I understand now. thank you guys Share this post Link to post Share on other sites
squonk 47,887 #6 Posted July 24 This is going to sound stupid, but I had a similar thing on my C-160. The RPMs would change when the deck was raised up to the stops. The hood stand was cracked on the left side where it meets the frame. The rock shaft was lifting the hood stand which in turn would pull on the throttle cable 1 1 Share this post Link to post Share on other sites
Lee1977 7,750 #7 Posted July 27 On 7/24/2026 at 6:22 AM, squonk said: This is going to sound stupid, but I had a similar thing on my C-160. The RPMs would change when the deck was raised up to the stops. The hood stand was cracked on the left side where it meets the frame. The rock shaft was lifting the hood stand which in turn would pull on the throttle cable The hood stand on my 1977 C-120 cracked on one side. After fixing it I decovered the it only had 2 bolts holding it to the frame. The frame had 4 holes the hood stand didn't have the holes drilled fot the back holes. It has 4 bolts holding it now. Share this post Link to post Share on other sites
