nyquil junkie 333 #1 Posted July 23 (edited) As the title sez... they leak, badly. Assuming the bearings are not shot (knock wood) are these seals just simple oil seals you pry out and tap new ones in, or is there some horrid complication I'm doomed to run into here? Are they just standard off the shelf seals or, some obscure unavailable 1960's part for a 3 speed trans? Edited July 23 by nyquil junkie Share this post Link to post Share on other sites
ri702bill 12,988 #2 Posted July 23 (edited) Look in the Transmissions section for the Seal P/N interchange list & the tutorial on doing the R&R. SKF seals are readily available. It is easier if the Unidrive is out of the tractor, but not absolutely necessary. Getting the hubs off may be an adventure though... Edited July 24 by ri702bill 1 Share this post Link to post Share on other sites
squonk 48,079 #3 Posted July 23 If you decide to remove the trans, get the hubs off first to hold the trans still. 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #4 Posted July 23 28 minutes ago, ri702bill said: Getting the hubs off may be an adventure though... DO NOT USE A STANDARD THREE JAW PULLER. DO NOT USE A STANDARD THREE JAW PULLER. DO NOT USE A STANDARD THREE JAW PULLER. I set that text three times. One for each jaw that you shall not use. An old hub is a good puller. There are good threads that show good pullers. 1 1 1 Share this post Link to post Share on other sites
953 nut 69,162 #5 Posted July 23 1 hour ago, squonk said: If you decide to remove the trans, get the hubs off first to hold the trans still. And the 3/4" hitch pin. 1 1 1 Share this post Link to post Share on other sites
lynnmor 9,038 #6 Posted July 23 Be super careful prying the seal out, one good nick on the axle will have you doing more work. 1 Share this post Link to post Share on other sites
ineedanother 2,864 #7 Posted July 24 Leaky seals are a hub removal's best friend They tend to come off relatively easily as compared to dry ones. 5 Share this post Link to post Share on other sites
nyquil junkie 333 #8 Posted July 25 I jacked it up to give it a pre-repair check... both hubs are loose on the axles, or the bearings are shot... or the shafts or hubs are wollered out... I dunno. I'll know more when I pull them off. Share this post Link to post Share on other sites
peter lena 10,047 #9 Posted July 25 @nyquil junkie 2 major assists . a screw in . PACKING PULLER , punch in tiny hole in seal metal side wall , screw in pull out seal , replace , also lubricate rubber to axel point it insure smooth operation . like a FLANGE PULLER , TO PULL HUBS , HAVE A SMALL HYDRAULIC RAM ? that will be solid strength against itself , end of axel to inner hub to axel , KROIL PENETRANT , like butter . actually easy with the right set up , like penetrating oil and light sand paper , for axel areas clean up , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #10 Posted July 25 2 hours ago, peter lena said: @nyquil junkie 2 major assists . a screw in . PACKING PULLER , punch in tiny hole in seal metal side wall , screw in pull out seal , replace , also lubricate rubber to axel point it insure smooth operation . like a FLANGE PULLER , TO PULL HUBS , HAVE A SMALL HYDRAULIC RAM ? that will be solid strength against itself , end of axel to inner hub to axel , KROIL PENETRANT , like butter . actually easy with the right set up , like penetrating oil and light sand paper , for axel areas clean up , pete All very good ideas. 1 Share this post Link to post Share on other sites
rmaynard 17,576 #11 Posted July 25 This is my hub puller. Works well. Cheep to make. Plenty of variations have been nade. 4 1 1 Share this post Link to post Share on other sites
nyquil junkie 333 #12 Posted July 26 Well.. after backing out the set screw the hubs fell off... more or less. The hubs are beat up and wallowed out from the hub flopping around, which I didnt notice for apparently years. The keyway beat the hub and the axle slots up pretty bad as the hub got more loose. So the hubs are toast, and the axle keyway slot is a little larger than it should be. Maybe someday I'll trip over a set of old hubs not quite so beat and maybe.... yeah maybe. Until then, its getting sat on some blocks and parts I need elsewhere are getting used. Too bad. This one did more work and more miles than WH probably designed it to do. Maybe someday, It'll get repaired and put back to work. Share this post Link to post Share on other sites
ebinmaine 80,653 #13 Posted July 26 1 hour ago, nyquil junkie said: back to work Lincoln at A to Z Tractor in PA has clamp on hubs. Or... a complete transmission transplant. Share this post Link to post Share on other sites
nyquil junkie 333 #14 Posted July 27 (edited) I found a couple hubs in my junk boxes... didn't know I had them. I put in new keys, and the hubs are now pretty snug. Good enough. I removed the outer tires on the back, and put some oil in the case.... it'll leak out eventually but, who cares. I'll add some now and then. Its good enough to tote the little wagon around, take feed to the cows or go inspect/fix the fences. When I i get some time I'll find the seals and put a set in. Its better than getting set under a tree to rot. I need a bigger machine w duals to crawl up into the high rough fence lines, which is what I'm going to slap together from this 520H roller I drug home the other day. Edited July 27 by nyquil junkie 1 Share this post Link to post Share on other sites
ineedanother 2,864 #15 Posted July 27 Duals are hard on axles and bearings unless the terrain is smooth. The outer wheels just have too much leverage on the axles. Sometimes it's just better to go with aggressive over-sized tires and chains. 1 Share this post Link to post Share on other sites
nyquil junkie 333 #16 Posted July 27 That would be easier. I'll see what fat tires I can scare up. Share this post Link to post Share on other sites
ebinmaine 80,653 #17 Posted Sunday at 12:44 PM On 7/25/2026 at 12:04 PM, rmaynard said: This is my hub puller. Works well. Cheep to make. Plenty of variations have been nade. Hey Bob. What's the specific size of the main bolt there? Share this post Link to post Share on other sites
rmaynard 17,576 #18 Posted Sunday at 12:58 PM 8 minutes ago, ebinmaine said: Hey Bob. What's the specific size of the main bolt there? The main (big) bolt is 7/8" x 5". It is stationary. Does nothing other than push on the axle as the other 3/8" bolts and nuts do all the work. 1 Share this post Link to post Share on other sites
ebinmaine 80,653 #19 Posted Sunday at 01:10 PM 12 minutes ago, rmaynard said: The main (big) bolt is 7/8" x 5". It is stationary. Does nothing other than push on the axle as the other 3/8" bolts and nuts do all the work. Very good. Thank you sir. Share this post Link to post Share on other sites
ineedanother 2,864 #20 Posted 2 hours ago On 7/25/2026 at 12:04 PM, rmaynard said: This is my hub puller. Works well. Cheep to make. Plenty of variations have been nade. Mine is similar and quick. Not as good looking but it was cheap and I used it twice this weekend. Sacrificed a bad hub and the bolts thread directly into the hub being pulled. Share this post Link to post Share on other sites
ebinmaine 80,653 #21 Posted 2 hours ago 1 minute ago, ineedanother said: Mine is similar and quick. Not as good looking but it was cheap and I used it twice this weekend. Sacrificed a bad hub and the bolts thread directly into the hub being pulled. I've tried that exact method and broke the puller on the first attempt. The steering wheel puller just wasn't built strong enough to pull a well stuck hub. Share this post Link to post Share on other sites
ineedanother 2,864 #22 Posted 1 hour ago 21 minutes ago, ebinmaine said: I've tried that exact method and broke the puller on the first attempt. The steering wheel puller just wasn't built strong enough to pull a well stuck hub. My puller is an old one, not the one in the picture. I've used my snap-on impact, I think around 900 ft-lb and can't imagine it breaking the puller. 1 Share this post Link to post Share on other sites
