TonyBer
Dead C-160 Wheelhorse
TonyBer
Help battery was weak / dead and used my truck battery to jump (vehicle NOT running).  Now I get nothing...turning key does nothing...no sounds, noises, movement, etc.  Is there an ignition fuse or something I may have sent to much power to and shorted?  Could I have blown out the starter?  There was no smoke, smell and no heat meaning no areas seemed to get hot.   Starter is relatively new.  Thoughts?  Thanks in advance.
gwest_ca
See if you have power on both terminals of the ammeter. If not remove the negative battery cable from the battery. Put both ammeter wires on one terminal - does not matter which. Reinstall the negative battery cable to the battery.
No fuse originally but one may have been added which is a good idea. It would be between the solenoid battery terminal and the ammeter.
The reason for negative cable removal first and last connection to be made is if you accidently short the power to the chassis no harm done. The circuit is not complete because there is no negative connected.
Let us know what you find.
8ntruck
Start your trouble shooting by checking the connections on the battery cables - they need to be clean and tight at both the battery end and load end.
I'll agree with @gwest_ca.  Ammeter can go bad and kill power to the various systems on the tractor.
I've got a 1973 14-8 that has a similar electrical system to your tractor.  The safety switch on the PTO lever does not always close with the lever in the off position, resulting in no crank.  If I gently pull the lever towards the steering wheel, the switch closes and all works as it should.  Got to check the bushings on the lever and maybe adjust the switch one of these days.....
Good luck.
rmaynard
Be sure that the PTO is not engaged, and that you have the clutch pedal depressed (safety switches).
squonk
That seat on the tractor is the best tractor seat you will ever come across! :handgestures-thumbupright:
953 nut
The negative terminal and ground connection are just as important. If the engine is is mounted on a shaker plate check the ground wire going to the engine mount.
ineedanother
I approach this issue differently by eliminating a bad ground as step 1. Attach your black lead to the engine block and the positive lead to the battery. Less than 12.5 or so tells you bad ground or bad battery. If good, then I follow the power through the harness.
TonyBer
Thank you all...huge help.  It was loose ground terminal (replaced wire) and replaced starter relay.  All good.  Thank you!
8ntruck
Thanks for the follow up.  It is nice to know what solves the problems that are posted here.
