Hayden 2 #1 Posted July 23 Hello, Had a pulley in my Mule Drive self disassemble. I have a 520H and looked in the parts manual and the Mule Drive isn't in there, my mower deck PN is either "C560SC01" OR "10525" which I was also unable to find a parts manual for. I would imagine I need to replace the shaft, as the race is pretty marred. The pulley itself doesn't seem to have damage but if I'm buying everything I might as well replace it. A secondary question would be why it broke. I have noticed that my PTO will kick off while mowing a lot, especially when mowing in taller grass too fast. So I just turned in the PTO adjustment a turn (maybe every other week this year) until this broke this weak. What would be a good way to get the PTO adjustment and Mule adjustment where I'm aligned and tightened properly? Thanks for the help. 1 Share this post Link to post Share on other sites
953 nut 69,787 #2 Posted July 23 One of the best features about Wheel Horse is interchangeability of implements and attachments. The manual below has the parts listed individually but yours appears to need a complete replacement. The mule drive on your 1990 60" mower is the same as other dives. Place a Wanted ad in our classified section for a mule drive. https://www.wheelhorseforum.com/classifieds/wanted/ Share this post Link to post Share on other sites
Ed Kennell 47,586 #3 Posted July 23 The spring loaded mule drives used on the 520 are not as common as the regular mule drives. You can place an ad in our classified wanted section or contact A to Z tractor parts Share this post Link to post Share on other sites
JoeM 10,317 #4 Posted July 23 (edited) I would venture to say you had a bearing going bad and dragging the belt. The shaft should be okay as long as you can get the old race off. just clean up the burs so the new pulley slides on. Edited July 23 by JoeM Share this post Link to post Share on other sites
peter lena 10,087 #5 Posted July 23 @Hayden glairing to me ? again , lubrication load stress failure , those 6203 bearings with wide rubber seal access , is literally showing you the way , small flat pocket screwdriver or small flat putty knife , carefully pop out seals , both sides , wipe out and carb cleaner flush , repack with lucas xtra hd green chassis grease ? 550 degree flash point , polyurea rated ( anti sling ) stays with bearing , what a concept ! also have this on my set up on 3 horses , EVERY RELATED MOVEMENT POINT , MOVES WITH TOTAL EASE , no frayed belts , no whyining bearings , never burned out a clutch disc ,2 basic stages ? insure functional detailing , and lucas green chassis grease , every spindle , and pulley , clean out every bearing / carb cleaner flush , no cross contamination , of original lube . this does not fail , have this in regular use for years , bTW , that pto lever set up is a GOLD MINE , for functional / easy lever start . love repetitive problems ? they show you the way to change . like a heim joint , pete Share this post Link to post Share on other sites
Hayden 2 #6 Posted July 30 Got the new pulley in and installed and this just doesn't look right to me. Any ideas on what it could be? The belt is on the inner pto track. Share this post Link to post Share on other sites
8ntruck 9,334 #7 Posted July 30 Looks like you have the bracket and shaft (#5 in the parts diagram) about 180 degrees out of position. The way I read the parts diagram, the outer pulley should be ahead of the inner pulley when installed on the tractor. Your picture shows that it is behind the inner pulley. Disclaimer: I do not own a 520H nor have I worked on one. I'm sure somebody with direct knowledge of a 520H will be along with comments. 2 Share this post Link to post Share on other sites
Ed Kennell 47,586 #8 Posted July 30 I 37 minutes ago, 8ntruck said: 180 degrees out of position. Yeah that, but what fixes the position of the shaft? I am not seeing it on the schematic. Share this post Link to post Share on other sites
Hayden 2 #9 Posted July 30 1 hour ago, 8ntruck said: Looks like you have the bracket and shaft (#5 in the parts diagram) about 180 degrees out of position. The way I read the parts diagram, the outer pulley should be ahead of the inner pulley when installed on the tractor. Your picture shows that it is behind the inner pulley. Disclaimer: I do not own a 520H nor have I worked on one. I'm sure somebody with direct knowledge of a 520H will be along with comments. That was exactly the problem. Too bad the PTO will still not stay engaged. Share this post Link to post Share on other sites
8ntruck 9,334 #10 Posted July 30 41 minutes ago, Ed Kennell said: I Yeah that, but what fixes the position of the shaft? I am not seeing it on the schematic. Gooood question. See my disclaimer above. Share this post Link to post Share on other sites
Ed Kennell 47,586 #11 Posted July 30 13 minutes ago, 8ntruck said: See my disclaimer above I don't have one either. I'm guessing the shaft may have a square end that indexes in a square hole in the housing? 26 minutes ago, Hayden said: PTO will still not stay engaged. Is it slipping or is the engagement lever not staying cammed over? 2 Share this post Link to post Share on other sites
Ed Kennell 47,586 #12 Posted July 30 1 hour ago, Ed Kennell said: I Yeah that, but what fixes the position of the shaft? I am not seeing it on the schematic. I think i see it now. Looks like the guide block #11 and bracket #12 attach to a tapped hole in the shaft. The hole is hidden by the belt on the schematic. Share this post Link to post Share on other sites
lynnmor 9,050 #13 Posted July 30 The staggered pulley, spring loaded mule drive goes with the 60 inch deck only, all other decks for the 520H use the common mule drives that other models use. Only the 520H can handle the 60 inch deck. 1 1 Share this post Link to post Share on other sites
sqrlgtr 4,091 #14 Posted July 31 I have 2 520's and both take regular muleys. Both have 48" decks though Share this post Link to post Share on other sites
76c12091520h 4,290 #15 Posted July 31 Do you have the tension spring installed ? ( #15 ) Share this post Link to post Share on other sites
Hayden 2 #16 Posted July 31 57 minutes ago, 76c12091520h said: Do you have the tension spring installed ? ( #15 ) Yes I do, there is a bit of metal shavings under the engine, I'm thinking it might be the PTO clutch Share this post Link to post Share on other sites
peter lena 10,087 #17 Posted July 31 @Hayden might also check out the inner needle bearing in the pto drive cone , lubrication is usually hard / crusty / cooked , that along with the outer sealed bearing , NAPA has it , makes for enormous collective drag , also like lucas xtra hd , green chassis grease in / on all my bearings , 550 deg flash point and also polyurea rated , never had a bearing fail or whine with it , pto lever set up is based on HAND OFF , EVERY RELATED MOVEMENT AREA , HAS TO BE EQUAL , that also shows itself in frayed belts and heavy wear . pto belt squeal ,is showing you the way , verify as you go , you will find the issue , pete Share this post Link to post Share on other sites
Hayden 2 #18 Posted August 4 (edited) Well I found out a lot today. Ordered a new PTO clutch and went to go replace it. The Housing looks to be completely worn thin, almost all the way through and that it has been metal on metal for some time. The plate on the right is the old one, so not a shred of clutch left. Makes me feel like an idiot. Does anyone know where I can find one? The PN I found was Toro 103478-03, which is unavailable most places. A similar one on ebay is $300 . Any help would be appreciated! Edited August 4 by Hayden 2 Share this post Link to post Share on other sites
Ed Kennell 47,586 #19 Posted August 4 Call Lincoln at A-Z tractor parts. Share this post Link to post Share on other sites
Handy Don 17,557 #20 Posted August 4 Or K&B Horse parts in the Classifieds/Vendor list (link at the top of the page) Share this post Link to post Share on other sites
sqrlgtr 4,091 #21 Posted August 5 22 hours ago, Hayden said: The Housing looks to be completely worn thin, almost all the way through and that it has been metal on metal for some time. That's about as wore as Ive ever seen one. Share this post Link to post Share on other sites
