Bull
KT17 series 2 piston & rod part numbers
Bull
Hello All,
I have pulled the cylinder heads on my KT17 series 2 motor and came up with following stamped numbers:
Pistons: 52058-25
Connecting Rod:52 059 06.
I don't see these part numbers in the Kohler manual and wanted to see if they were standard or oversized.
Regards,
Bob
pfrederi
T
Edited by pfrederi
pfrederi
What Spec # engine do you have...
Bull
Hello,
I have the Kohler part numbers from their parts manual but was wondering what the numbers on my motor indicated. The engine spec # is 24350 and model # KT17QS.
Thanks,
Bob
pfrederi
You bring up an interesting question.  Kohler part numbers are 7 digits plus a suffix.  Which you show but I can't find a match.  Looking at some other Kohler engine parts left over from overhauls the numbers cast in the connecting rod do not match the part# listed in manuals...
Usually over pistons are stamped  .010 etc     standard piston may be stamped STD or not marked at all.  I think you are going to have to measure...I seriously doubt your engine has been overhauled and if yours isn't marked probably is std.
If you are going to do an overhaul research what parts are available and how much they will cost you some things are getting harder to find.  i did overhaul an M-18 a few years ago some parts were hard to find or expensive and of course machine shop work is expensive as everything is times 2.
