meadowfield 3,173 #26 Posted August 28 On 7/20/2026 at 3:47 PM, ri702bill said: Nice work. What keps the stub shaft located in the bearing sleeve? I do not see any snap rings... ignore the cut down axle - it’s hardened so I had to angle grind. Snap ring in place now 2 Share this post Link to post Share on other sites
peter lena 10,020 #27 Posted August 28 @meadowfield awesome ! your very typical detailing is showing you the way , a stand out for me . would be the related , chain lubrication , should be specific to that , would also think , polyurea rating , anti sling , open gear , cable related , sure you have a similar lube over there .BTW my favorite LUCAS X TRA HD , green chassis grease , has eliminated , , mower deck bearing failure / whine , 560 deg , drop point , been bombproof , important to flush out any original lube , ensuring no cross contamination, also perfect on pto lever , cone needle bearing , minimal ammount , spin up is very easy , responsive . love your work ! pete Share this post Link to post Share on other sites
wallfish 20,516 #28 Posted August 29 (edited) 9 hours ago, meadowfield said: ignore the cut down axle - it’s hardened so I had to angle grind. Snap ring in place now Hold on! All that beautiful machine work so far and then this????? Edited August 29 by wallfish 5 Share this post Link to post Share on other sites
sjoemie himself 3,176 #29 Posted August 29 On 8/24/2026 at 10:27 AM, meadowfield said: Axle with steering That is some next level engine-nerding going on there sir! Curious to see how you will feed power to the front axle. I've toyed with the idea of building a 4wd but was looking at ready made differentials. Like I said, this is next level. Greetings from the Netherlands, Mark 1 2 Share this post Link to post Share on other sites
Dave D. 72 #30 Posted September 1 Very cool fabrication. This should be a most useful tractor. That looks very heavy duty. Dave 1 Share this post Link to post Share on other sites
meadowfield 3,173 #31 Posted September 2 Now driving and steering - a lot of trial and error! 11 2 Share this post Link to post Share on other sites
Retired Wrencher 6,927 #32 Posted September 2 1 hour ago, meadowfield said: Now driving and steering - a lot of trial and error! Well done. Looks great. Another quality designed idea. Enjoy. 1 Share this post Link to post Share on other sites
rjg854 13,320 #33 Posted September 2 So what does the chain system look like? And is it a true 4 wheel drive or a 3 wheel drive? Does it have a posi rear end? 1 Share this post Link to post Share on other sites
meadowfield 3,173 #34 Posted September 2 3 minutes ago, rjg854 said: So what does the chain system look like? And is it a true 4 wheel drive or a 3 wheel drive? Does it have a posi rear end? drive to front still to do - deciding whether to spoil a suburban 400 - or use my suburban 551 - and swap the trans for an 8 speed before I do the drive. Which will be chain from the back to front... 5 1 1 Share this post Link to post Share on other sites
meadowfield 3,173 #35 Posted September 9 (edited) A few more pictures, a lot more messing with the steering and getting the right clearance and Ackerman angle. Chain out from front axle Another test run - and a photogenic picture Edited September 9 by meadowfield 5 9 Share this post Link to post Share on other sites
sjoemie himself 3,176 #36 Posted Monday at 10:37 AM Pretty slick! Excellent work. Share this post Link to post Share on other sites
meadowfield 3,173 #37 Posted 5 hours ago (edited) A bit more thinking…. And progress Steering complete tidied up that butchered end... tube for drive line Edited 4 hours ago by meadowfield 3 Share this post Link to post Share on other sites
