meadowfield
Suburban - 4x4…. Will it work?
meadowfield
On 7/20/2026 at 3:47 PM, ri702bill said:
Nice work. What keps the stub shaft located in the bearing sleeve? I do not see any snap rings...
ignore the cut down axle - it’s hardened so I had to angle grind.  Snap ring in place now
  • Excellent 2
peter lena
@meadowfield  awesome ! your very typical detailing  is showing you the way , a stand out for me . would be  the related , chain lubrication  , should be specific to that  , would also  think , polyurea  rating , anti sling  , open gear , cable related , sure you have a similar lube over there .BTW  my favorite LUCAS X TRA HD , green chassis grease , has eliminated ,  , mower deck bearing failure / whine , 560 deg , drop point  , been bombproof , important to flush out  any original lube , ensuring no  cross contamination, also  perfect on pto lever , cone needle bearing , minimal ammount , spin up is very easy , responsive .  love your work ! pete
wallfish
Posted (edited)
Hold on!
All that beautiful machine work so far and then this?????
Edited by wallfish
  • Haha 5
sjoemie himself
On 8/24/2026 at 10:27 AM, meadowfield said:
Axle with steering
That is some next level engine-nerding going on there sir! Curious to see how you will feed power to the front axle.
I've toyed with the idea of building a 4wd but was looking at ready made differentials. Like I said, this is next level.
Greetings from the Netherlands, Mark
  • Heart 2
Dave D.
Very cool fabrication. This should be a most useful tractor.
That looks very heavy duty.
Dave
Retired Wrencher
1 hour ago, meadowfield said:
Now driving and steering - a lot of trial and error!
Well done. Looks great. Another quality designed idea. Enjoy.
rjg854
So what does the chain system look like? And is it a true 4 wheel drive or a 3 wheel drive? Does it have a posi rear end?
meadowfield
drive to front still to do - deciding whether to spoil a suburban 400 - or use my suburban 551 - and swap the trans for an 8 speed before I do the drive. Which will be chain from the back to front...
  • Like 5
sjoemie himself
Pretty slick! Excellent work.
meadowfield
A bit more thinking…. And progress
Steering complete
tidied up that butchered end...
tube for drive line
Edited by meadowfield
  • Excellent 6
sjoemie himself
That's coming together nicely!
Thinking is about 75% of the work, and time.. I'm sure lot's of staring at metal bits has happened before you came to this point.
meadowfield
4WD selector fork done.
first test
  • Excellent 5
WHMan2012
How were you able to figure out the gear ratio ( front chain sprocket ) ? Just wondering if they're going to be the same or want to fight you or slow you down. Nice build though looks like she'll be a good little tractor when you're finished.
meadowfield
I made a calculator, same as I did for the other 3 4x4 built, each one tuned for the wheel size and axle design.
  • Excellent 5
