Kenneth R Cluley
Lubrication dilemma
Kenneth R Cluley
I have decided to upgrade the wheel bearings on front wheels of Rear engine rider. The original flange "bearings" are Taiwan lets call flow through not sealed . The hub of wheel has a grease zerk and entire hub fills with grease until it flows through bearings and out side. I have purchased a sealed flange bearing and cannot decide if I should pull the shields and just pump it up till it flows through or flush out and pack with Pete approved Lucas high pressure and replace seals and not use zerk anymore. What do you geniuses recommend? I realize I would have to regrease on some maintenance interval either way.
ri702bill
Ken - how worn are the spindles - usually the bottoms??  Theh get worn by the inner race(s) spinning on the spindle when they should be stationary.... Regardless of what grease you use, the inner race needs to be non-rotating. You may have to address that fisst.
Kenneth R Cluley
They look good, I'm aware of the inner being stationary. Caught it in time I believe but I will definitely verify when I reassemble.
Ed Kennell
IMO, the sealed bearings are the way to go.     They keep the grease in where it is needed and keeps the dirt out.   No need to fill a wheel hub with a pound of grease that makes a mess.       The low RPM of these sealed bearings should insure a long life.
  • Like 5
  • Excellent 4
oliver2-44
:text-yeahthat:
rjg854
I use the sealed bearings also, I  just clean out the grease that came in them and use red and tacky grease and close them up again. They don't put very much grease in there to begin with.
ri702bill
Is that what you call that substance they use?? I've seen what looks like wax, not grease in new sealed bearings... That stuff comes out in chunks & does not wash out well at all....
rjg854
What I saw was like a clear gel, and not much at all.
ri702bill
Bryl-Cream... a little dab 'll do ya! Goo for a 1950's hairdo, not wheel bearings!
  • Haha 2
wallfish
Keep the seal on after packing with new grease and they'll be perfectly fine. Waste of time and grease filling that entire wheel hub with grease IMO. (For normal intended use anyway)
However, If you're "4 wheel'n" with it through the swamps and puddles every week then I would recommend removing the inner seals and flushing them out with new grease through the zerk. Mowing the lawn or towing a trailer, not so much.
We have the technology they didn't have back in the day with the seals, so use them until they fail many years down the road and let your grandchildren replace them when necessary. :twocents-02cents:
(Stay away from the stamped steel bearings sealed or not )
Edited by wallfish
  • Like 4
Racinbob
I've been using sealed bearings for the front wheels for quite some time now. Excellent results. I decided to try them on a mower deck with some hesitation. The first deck is on the 5th year now and no issues. :)
JimSraj
Did you repack them or use them as they came?
Kenneth R Cluley
Thanks for all the replies, I truly value all your advice and opinions. I also felt that pumping half a tube of grease into the wheel hub when a teaspoon of it in the right place would do the job. So, I'm going to open them up flush the OEM lubrication out, repack with Lucas tacky red and seal them back up.
Racinbob
Straight out of the box. Maximum lazy. :rolleyes:
There's no heat buildup at all on the front wheel bearings. It kinda sounded like I used these bearing on the deck spindles. Nope. But I did use a sealed bearings. I don't remember the brand.
Edited by Racinbob
WHX??
:text-yeahthat:The general consensus tho for a hard worker leave the inner seal out and re-grease.  Even that said these don't cost that much and super easy to replace. My queens even have the zerk pulled and hole filled in. I always keep a re-packed set on the shelf.
Edited by WHX??
sqrlgtr
I'm with Bob on this one:handgestures-thumbupright:
  • Similar Content
    • Jeff_B
      By Jeff_B
      Where's your go-to source for QUALITY 103119 bearing shaft assemblies? Also, I don't have my deck apart yet, but seem to remember they're tough to remove from the housings. Any tips or tricks? Finally, just recently I've had a couple of  the center bearings go loose on two different decks. Once is one thing, but twice? More than a coincidence? Should I be releasing tension on the belt by loosening the mule drive when not in use? We've had WH tractors for over 40+ years and I've never done that before! THANKS in advance!
    • RichInWalworth
      By RichInWalworth
      Question. I have a 1990 single stage snow thrower for my 312-8. I am trying to replace the bearings on the drive shaft. How do you remove them? I have taken out the set screw, soaked the collar in pb blaster, put some heat to them, pounded on them. etc. They will not move. Am I missing something? The only thing that is curious is, there is only one set screw in each bearing collar. There appears to be a second partially drilled hole but no set screw installed and it does not appear to be tapped. What gives???
      Rich In Walworth
    • IthacaJeff
      By IthacaJeff
      Hi folks:
      The wheel bearings in one of the front wheels of my 416-8 imploded the other day while mowing. 32 years old, I'm not complaining. Anyway, with the advice of another thread I picked up a set of 4 flanged bearings off an ebay seller. . .3/4" ID, 1 3/8" OD. Problem is they are a loose fit in the wheel hub. I should need to tap them in, but they just slide in and out. No real play, but they can just fall out. The insides of the hubs are clearly worn.  Any advice on snugging up the bearings"
      Thanks,
      J
    • porschpow
      By porschpow
      Good Morning everybody!
      I am in the process of sharpening the blades for my mowing deck (Model 78360 - Serial 7904987) and I noticed that the deck has a crack in it right where the bracket to the mounting hardware (to the tractor) is. SO I know I have to get that repaired.
      But while I was at this, I thought I could do a good quick once over on the deck to make sure I am ready for the season.
      What I would like to do is the following:
      Change the bearings for the spindles (or pack them with more grease)
      Get new rear tires (since they squeak)
      And that's about it
      If anyone here thinks I should do anything else, I would love to hear it!
      Where does everyone get the hardware (bearings, wheels for these rebuilds?)
    • mkueb
      By mkueb
      Does anybody have a good source for replacement front wheel bearings for a mid to late 1970's D160 wheel horse tractor?  There are two push in bearing units (inner and outer) per wheel.   I first attempted to replace with standard bearings but quickly found out these are not standard sizes.   It's been a while since I check and I don't completely remember,  but I think the wheelhorse bearings where something like 1/16" of an inch larger OD than a standard catalog bearing.   At the time,  I remember finding bearings but they wanted somthing like $100 for each bearing.   I was able to located two bearings and did purchase them for a reasonible price,  but am still looking for two for completing the set.   The part numbe ron the two that I was able to locate is 104396.   If anybody has any ideas,  I would appreciate.
      Thanks
      Marc
