Fj40z 240 #1 Posted July 13 I only have a drawbar on both my WH’s. I’d like to have a clevis hitch or something similar to be able to use a plow or other implements even though I don’t have them yet. Trouble is I’m still fairly green to this whole scene so knowing what I need, options available or if it’s even feasible I do not know. I’ve searched a lot on here and see a lot of WH’s with lift cables or manual lifts and slot hitches and I gotta be honest I can’t figure out from pictures what I’d need or how it bolts up. Here’s a pic of the rear of the C160-8, as always any insight is certainly appreciated! 2 Share this post Link to post Share on other sites
WHX?? 58,302 #2 Posted July 13 (edited) You need a slot hitch or a Brinly. Just remove the pin, take off the spacers and it will fit right in. Looks like might need a lift cable or rockshaft depending on what you want to do. Not sure how/what is needed for a lift cable for a 160 but everything can be had at https://wheelhorsepartsandmore.com/ You may also have to lose the ball. A Brinly is best for a Brinly field plow. Slot adapters can be had for a slot hitch. I run a slot/draw bar combo on all my horses. Edited July 13 by WHX?? 1 8 Share this post Link to post Share on other sites
AlexR 3,121 #3 Posted July 14 Others might be able to tell you for sure but it looks like you need a rockshaft to me I made one of my sleeve hitches. Even making it back around 2018 I think it cost me around $60-70 in material to make one. I also didn't need the rockshaft. Like mentioned you can get everything from wheelhorsepartsandmore. It's not really that easy to get the setup used for cheaper, because not that many people will get rid of those parts. 1 4 Share this post Link to post Share on other sites
Fj40z 240 #4 Posted July 14 Thanks for the info @WHX?? and @AlexR Those pics help a lot. I can see where a clevis hitch or a slot hitches would fit around the drawbar. I guess I would have to come up with my own lift system or maybe a manual lift if there is such a thing? Share this post Link to post Share on other sites
WHX?? 58,302 #5 Posted July 14 14 minutes ago, Fj40z said: come up with my own lift system or maybe a manual lift if there is such a thing? A C-160 should have came with a manual lift bar and mid mount rockshaft for a lift cable. 3 1 Share this post Link to post Share on other sites
sqrlgtr 4,091 #6 Posted July 14 @Fj40z more pics of mochine would be helpful in seeing what your have or have not"s are. If you are missing the lift handle, rock shaft, etc. you may be better off purchasing a whole parts mochine... 2 2 Share this post Link to post Share on other sites
clueless 3,439 #7 Posted July 14 13 hours ago, WHX?? said: You need a slot hitch or a Brinly. Just remove the pin, take off the spacers and it will fit right in. Looks like might need a lift cable or rockshaft depending on what you want to do. Not sure how/what is needed for a lift cable for a 160 but everything can be had at https://wheelhorsepartsandmore.com/ You may also have to lose the ball. A Brinly is best for a Brinly field plow. Slot adapters can be had for a slot hitch. I run a slot/draw bar combo on all my horses. 3 Share this post Link to post Share on other sites
953 nut 69,789 #8 Posted July 14 Your transaxle should have a lift cable conduit like this one bolted to the top of it. just need to get the cable from Wheel Horse Parts and More and attach it to the rockshaft where it says rear lift cable. 1 2 Share this post Link to post Share on other sites
Fj40z 240 #9 Posted July 15 Thanks again for all the help! Went out again this evening and the lift cable conduit is there. Does the lift cable go through and connect to the lift/lower mechanism that the mower deck also? I have nothing else there that I can see that you could use to operate it. 2 Share this post Link to post Share on other sites
cleat 9,380 #10 Posted July 15 This may help you. Hitch Clevis Type A 85518 Installation Instructions.pdf 2 1 Share this post Link to post Share on other sites
953 nut 69,789 #11 Posted July 15 you have the conduit already, all you will need is the cable. Call https://wheelhorsepartsandmore.com/shop-now/ and they will fix you up., 1 Share this post Link to post Share on other sites
WHX?? 58,302 #12 Posted July 15 For the mower deck it's just a rod, some guys use a chain, that goes from the deck to the rock shaft. That's in a deck manual. Looks like all you need for the rear is a cable and slot hitch. 1 1 Share this post Link to post Share on other sites
Fj40z 240 #13 Posted July 16 Many thanks to you all! I’ll be gathering up some parts in the not so distant future! Share this post Link to post Share on other sites
