Natejc_98 21 #1 Posted 3 hours ago Has anyone had any luck with at home sandblasters? Been looking at a few different options from Harbor Freight, Lowe’s, etc. wanted to see if anyone has experience with them. Also, what grit works best for sandblast media? Share this post Link to post Share on other sites
rmaynard 17,415 #2 Posted 3 hours ago This kind of blaster is okay, but there is a lot of waste. Placing a blanket or tarp behind your work helps catch your media. You must wear eye protection . Also, be careful to be sure that you turn off the air and bleed the tank before disconnecting any hose. I learned the hard way just today. I disconnected the pressure hose and there was still 120psi in the tank. I am not going to show how I sanded the back of my hand, just the bandage. 2 Share this post Link to post Share on other sites
ri702bill 12,412 #3 Posted 2 hours ago You do that once, and it is a forever memory thst you will not repeat! 1 1 Share this post Link to post Share on other sites
ri702bill 12,412 #4 Posted 2 hours ago (edited) we have 2 dedicated blasters. The tabletop unit is for fine work, and uses glass bead media. The larger floor cabinet is from Harbor Freight. Used for general sandblasting - we use coal slag from TSC in that one. Out of the box the HFT floor unit leaves a lot to be desired; we have done about a half dozen upgrades - well woth it. Most are available on YouTube. Edited 1 hour ago by ri702bill Share this post Link to post Share on other sites
rmaynard 17,415 #5 Posted 2 hours ago 8 minutes ago, ri702bill said: .Out of the box the HFT floor unit leaves a lot to be desired; we have do about a half dozen upgrades - well woth it. Most are available on YouTube. Been there, done that. Some mods are better than others but they sure beat the out-of-the-box version. 1 Share this post Link to post Share on other sites
sqrlgtr 3,190 #6 Posted 2 hours ago 55 minutes ago, rmaynard said: I sanded the back of my hand, just the bandage. ouch Share this post Link to post Share on other sites
sqrlgtr 3,190 #7 Posted 2 hours ago I have this one and it works well but like mentioned above there is a lot of waste. I always thought a one-piece old shower would make a good way to catch the media while blasting but have never found one somebody was throwing out. Share this post Link to post Share on other sites
squonk 47,297 #8 Posted 1 hour ago If you want a Cabinet, cut loose with the cash and get a TP Tools cabinet. The money you'll spend on mods on a cheapie ain't worth it. TP also has a better gun, and accessories like foot pedals, carbide nozzles and vacuums. An air compressor that can handle sandblasting is half the battle! https://www.tptools.com/ 2 Share this post Link to post Share on other sites
ri702bill 12,412 #9 Posted 1 hour ago 13 minutes ago, squonk said: An air compressor that can handle sandblasting is half the battle! Our 60 gallon 2HP Vertical can keep up with the glass bead unit, struggles to do about an 80% duty cycle on the larger one. The TP Tools gun was one of the cabinet upgrades. 1 Share this post Link to post Share on other sites
pfrederi 20,830 #10 Posted 49 minutes ago Get a TP Tool cabinet, The HF one didn't have enough slope the media would not get back down to be picked up 1 Share this post Link to post Share on other sites
