Natejc_98 23 #1 Posted Monday at 09:05 PM Has anyone had any luck with at home sandblasters? Been looking at a few different options from Harbor Freight, Lowe’s, etc. wanted to see if anyone has experience with them. Also, what grit works best for sandblast media? 1 Share this post Link to post Share on other sites
rmaynard 17,416 #2 Posted Monday at 09:22 PM This kind of blaster is okay, but there is a lot of waste. Placing a blanket or tarp behind your work helps catch your media. You must wear eye protection . Also, be careful to be sure that you turn off the air and bleed the tank before disconnecting any hose. I learned the hard way just today. I disconnected the pressure hose and there was still 120psi in the tank. I am not going to show how I sanded the back of my hand, just the bandage. 6 Share this post Link to post Share on other sites
ri702bill 12,429 #3 Posted Monday at 09:48 PM You do that once, and it is a forever memory thst you will not repeat! 2 1 Share this post Link to post Share on other sites
ri702bill 12,429 #4 Posted Monday at 09:55 PM (edited) we have 2 dedicated blasters. The tabletop unit is for fine work, and uses glass bead media. The larger floor cabinet is from Harbor Freight. Used for general sandblasting - we use coal slag from TSC in that one. Out of the box the HFT floor unit leaves a lot to be desired; we have done about a half dozen upgrades - well worth it. Most are available on YouTube. Edited Tuesday at 09:00 AM by ri702bill 2 Share this post Link to post Share on other sites
rmaynard 17,416 #5 Posted Monday at 10:06 PM 8 minutes ago, ri702bill said: .Out of the box the HFT floor unit leaves a lot to be desired; we have do about a half dozen upgrades - well woth it. Most are available on YouTube. Been there, done that. Some mods are better than others but they sure beat the out-of-the-box version. 2 Share this post Link to post Share on other sites
sqrlgtr 3,202 #6 Posted Monday at 10:17 PM 55 minutes ago, rmaynard said: I sanded the back of my hand, just the bandage. ouch Share this post Link to post Share on other sites
sqrlgtr 3,202 #7 Posted Monday at 10:23 PM I have this one and it works well but like mentioned above there is a lot of waste. I always thought a one-piece old shower would make a good way to catch the media while blasting but have never found one somebody was throwing out. 1 Share this post Link to post Share on other sites
squonk 47,313 #8 Posted Monday at 11:07 PM If you want a Cabinet, cut loose with the cash and get a TP Tools cabinet. The money you'll spend on mods on a cheapie ain't worth it. TP also has a better gun, and accessories like foot pedals, carbide nozzles and vacuums. An air compressor that can handle sandblasting is half the battle! https://www.tptools.com/ 3 Share this post Link to post Share on other sites
ri702bill 12,429 #9 Posted Monday at 11:23 PM 13 minutes ago, squonk said: An air compressor that can handle sandblasting is half the battle! Our 60 gallon 2HP Vertical can keep up with the glass bead unit, struggles to do about an 80% duty cycle on the larger one. The TP Tools gun was one of the cabinet upgrades. 1 Share this post Link to post Share on other sites
pfrederi 20,834 #10 Posted Monday at 11:51 PM Get a TP Tool cabinet, The HF one didn't have enough slope the media would not get back down to be picked up 3 Share this post Link to post Share on other sites
WHX?? 57,334 #11 Posted Tuesday at 12:56 AM 1 hour ago, squonk said: cut loose with the cash if you have filled deep pockets like me. There fixed that... The HF cab works good and even with all the mods bet I ain't got 200 in it. Lots of threads here on them and like said y tube. Make your own cyclone bucket works too. I use the coal slag form TSC. Yah big thing is the air supply. 11-12 cfm @90 PSI minimum for most cabs. 1 Share this post Link to post Share on other sites
Natejc_98 23 #12 Posted Tuesday at 01:02 AM 5 minutes ago, WHX?? said: There fixed that... The HF cab works good and even with all the mods bet I ain't got 200 in it. Lots of threads here on them and like said y tube. Make your own cyclone bucket works too. I use the coal slag form TSC. Yah big thing is the air supply. 11-12 cfm @90 PSI minimum for most cabs. Might just stick with the angle grinder for time being 😂 1 Share this post Link to post Share on other sites
Brockport Bill 2,420 #13 Posted Tuesday at 04:18 AM I do a few rehab projects with grandsons each year...mostly decks, seat pans, few footrests, an occasional plow blade, etc.....some need more rust cleaning than others..if not very severe rust or pitting, then grinder, wire wheel, scaler etc often get job done. However, I did do some consideration couple years ago to buy blaster....Instead, I use a nearby fairly priced professional sand blaster who has done various projects for me... Every one of us has different considerations, but for me I'd rather have him deal with all the downside issues of doing the blasting than me. .... I'm happy dropping project with him and picking it up few days later. No $ cost for me to buy and maintain equipment, buy media, no mess, no labor, no sweating, no clean up, no health considerations, etc....and great perfectly finished beautiful bare metal piece 8 Share this post Link to post Share on other sites
ebinmaine 79,573 #14 Posted Tuesday at 11:08 PM 18 hours ago, Brockport Bill said: I do a few rehab projects with grandsons each year...mostly decks, seat pans, few footrests, an occasional plow blade, etc.....some need more rust cleaning than others..if not very severe rust or pitting, then grinder, wire wheel, scaler etc often get job done. However, I did do some consideration couple years ago to buy blaster....Instead, I use a nearby fairly priced professional sand blaster who has done various projects for me... Every one of us has different considerations, but for me I'd rather have him deal with all the downside issues of doing the blasting than me. .... I'm happy dropping project with him and picking it up few days later. No $ cost for me to buy and maintain equipment, buy media, no mess, no labor, no sweating, no clean up, no health considerations, etc....and great perfectly finished beautiful bare metal piece Sometimes the best value is letting someone else do the job. 4 Share this post Link to post Share on other sites
Brockport Bill 2,420 #15 Posted yesterday at 05:54 AM 6 hours ago, ebinmaine said: Sometimes the best value is letting someone else do the job. the other benefit of taking the decks to a pro sandblaster is if the deck ( or other tractor item ) is pitted -- its more challenging for me to get rust out --- even with scaler tool, or wire brush etc to get rust out from those pitted spots - - the propfessional sand blasting certainly makes them 100 % cleaned 3 Share this post Link to post Share on other sites
Kenneth R Cluley 686 #16 Posted yesterday at 02:02 PM Be sure the air is "DRY" also. Makes it a lot smoother process with no clogging up nozzle or pick up tube. 1 Share this post Link to post Share on other sites
Wishin4a416 2,598 #17 Posted 7 hours ago On 7/13/2026 at 5:22 PM, rmaynard said: This kind of blaster is okay, but there is a lot of waste. Placing a blanket or tarp behind your work helps catch your media. You must wear eye protection . Also, be careful to be sure that you turn off the air and bleed the tank before disconnecting any hose. I learned the hard way just today. I disconnected the pressure hose and there was still 120psi in the tank. I am not going to show how I sanded the back of my hand, just the bandage. I did that Bob while restoring a car. Rented a commercial pull behind the truck unit.I was blasting a chevelle frame with black beauty..Got me in the same place. I had pieces of sand in my hand for 10 years. Not unhooking but it got away from me for a very short while trying to get a stubborn little area. 1 Share this post Link to post Share on other sites
Wishin4a416 2,598 #18 Posted 7 hours ago I have an old Craftsman tub type that has done many small jobs for me. They work good if you have a good compressor. Share this post Link to post Share on other sites
bds1984 1,513 #19 Posted 5 hours ago Whatever your decision is with a sandblaster, make sure you have a larger diameter air hose going to it. Over the years I have seen several people toss out perfectly usable units while claiming they don't work well but didn't upgrade from the 1/4" diameter hose they use to air up tires. 2 Share this post Link to post Share on other sites
squonk 47,313 #20 Posted 1 hour ago I have one of these and it works pretty well with glass bead and a 1/2" air supply line. I close 2 ball valves before letting go of the nozzle and wear sandblasting gloves. Share this post Link to post Share on other sites
