hotajax 284 #1 Posted July 12 (edited) Just so I understand this stuff, what is the small black wire that is attached to the battery side of the solenoid? Is that from the "on" side of the starter switch? There was a small black wire with a ring connector that went with the 4 gauge battery cable from the battery, and connected to the one side of the solenoid. BTW, I'm sure you astute guys figured out I had to have help getting it running An old farmer fixed it in like 5 mins. A simple circuit tester and screwdriver were all the tools that were necessary. Thanks in advance. Edited July 12 by hotajax Share this post Link to post Share on other sites
rmaynard 17,527 #2 Posted July 12 All models have wiring diagrams in their manual which can be found in our manuals section of this forum. That should answer your question. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #3 Posted July 13 That is likely the wire that feeds the ignition switch with battery power. A fuse in that wire would be good protection for the rest of the wiring. 1 2 Share this post Link to post Share on other sites
953 nut 68,495 #4 Posted July 13 11 hours ago, hotajax said: There was a small black wire with a ring connector that went with the 4 gauge battery cable from the battery, and connected to the one side of the solenoid. There are a couple of possibilities here, Wheel Horse used black wires with a colored tracer line printed on it for several years. Presuming this is factory wiring there should be a RED line on that wire. The second possibility is that a previous owner had some black wire and decided to add something that needed power. Share this post Link to post Share on other sites
Bar Nuthin 3,040 #5 Posted July 13 If you post the model number of your tractor, most likely someone here will link you to the download files for the owner's manual, and wiring diagram. Or you can do a search on your model number and likely find those files. They can save you a lot of headaches. Share this post Link to post Share on other sites
hotajax 284 #6 Posted July 13 4 hours ago, 953 nut said: There are a couple of possibilities here, Wheel Horse used black wires with a colored tracer line printed on it for several years. Presuming this is factory wiring there should be a RED line on that wire. The second possibility is that a previous owner had some black wire and decided to add something that needed power. NO red line on the small wire to the battery side of solenoid. All original wiring, and I am the original owner of this machine. She ain't much to look at, but she sure does get it done. Share this post Link to post Share on other sites
