Goldnboy 1,154 #1 Posted July 12 Been wanting to setup a way to tow, move and lift items for some time. You know the dead tractor far from home... Recently got around to doing this rear crane idea. I decided to go simple by using a brinly hitch. Well the cable could break in up or down position. But I figured it should be good for about 500lbs at least since I had a rear dirt scoop on one and it never broke. I made it with a bumper hitch receiver and had a brinly sleeve hitch adapter on it.. I could go to a rear receiver hitch mount on the tractor for added strength. But this is a good start to see how much I use it. 1 6 Share this post Link to post Share on other sites
peter lena 10,065 #2 Posted July 12 @ goldenboy , the farther you get away from the tractor , the more leverage stress is created , as a basic would suggest , adding one of these under the lower tongue of hitch , under trans . would ease that metal to metal contact zone . castings by themselves are ok , but prone to cracking in leverage zones . regularlyhttps://www.google.com/search?q=impact+vibration+pads&rlz=1C1CHBF_enUS866US866&oq=impact+vibration+pads+&gs_lcrp=EgZjaHJvbWUyCQgAEEUYORifBTIHCAEQIRigATIHCAIQIRirAjIHCAMQIRirAjIHCAQQIRirAjIHCAUQIRifBTIHCAYQIRifBTIHCAcQIRifBTIHCAgQIRifBTIHCAkQIRifBdIBCTEyODcwajBqNKgCAbACAfEFPD8qDtz78rLxBTw_Kg7c-_Ky&sourceid=chrome&source=chrome.ob&ie=UTF-8 add a buffer to impact areas . just a thought , pete 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #3 Posted July 12 31 minutes ago, Goldnboy said: bumper hitch receiver and had a brinly sleeve hitch adapter on it.. Neat idea. 31 minutes ago, Goldnboy said: I could go to a rear receiver hitch mount on the tractor for added strength. Do this right now. That 500 lbs you're familiar with is gonna get much heavier very quickly with the added length. More importantly - dynamic motion loads. A rolling and broken down machine being pulled will add very different load moments to the crane and pulling tractor. The crane I built years ago is a little too heavy duty... But works great. It definitely puts a considerable strain on the tractor. 1 Share this post Link to post Share on other sites
Bill D 3,156 #4 Posted July 12 I made a tow bar for my Wheel Horse. Clips into the front hitch. Works great for towing a non running 8 speed. 1 1 Share this post Link to post Share on other sites
ineedanother 2,864 #5 Posted July 12 I definitely use mine enough to justify having it around. Tillers, decks, motors, all the stuff I don't have any interest in manually carrying (most everything!). Bungee cords are a must to keep stuff from swinging out of control. Mine uses the attachment points and a section of an old frame and works pretty well. 2 5 Share this post Link to post Share on other sites
ri702bill 13,059 #6 Posted July 12 2 hours ago, ebinmaine said: More importantly - dynamic motion loads. A rolling and broken down machine being pulled will add very different load moments to the crane and pulling tractor. And now you are relying on the marginal WH brake to stop it. Best to travel in Low Range while towing... 1 Share this post Link to post Share on other sites
Lee1977 7,772 #7 Posted July 14 (edited) That's going to be hard on you lift cable. The hydrolic jack can lift a lot more then that cable can hold. It's best to have them mounted in a receive hitch. I have.towed tractors with mine as low as it goes it will still lift the front of the tow tractor. Edited July 14 by Lee1977 1 Share this post Link to post Share on other sites
