JOEPOE1977 2 #1 Posted July 11 (edited) I have a 1990 Wheel Horse 310-8. It has a 42 inch recycler deck. The deck has the original spindles on it and the Kohler MC10 has the original PTO clutch on it. I am continuing to burn and break belts on this unit. New blades on the deck which I just bought for a member on the sight. The last belt lasted me less than 3 hours. Any help very much appreciated on this. Thank you as always. Edited July 11 by JOEPOE1977 Share this post Link to post Share on other sites
ri702bill 13,187 #2 Posted July 11 Joe - Welcome!! Which belt is the problem one? The drive belt from the PTO or the belt that drives the 3 spindles?? Either case, it sounds like it is an alignment or bad bearing issue... Share this post Link to post Share on other sites
Ed Kennell 47,586 #3 Posted July 11 to the Joe. Pictures of the pulleys involved may help us see the problem. Share this post Link to post Share on other sites
rjg854 13,402 #4 Posted July 11 Yes pictures would be a big plus. 1 Share this post Link to post Share on other sites
953 nut 69,787 #5 Posted July 12 Check out the mule drive pullies. Be sure they spin freely and are on the drive correctly. If you remove the nut (takes a 1 1/8" wrench or socket) you can check the order of the pullies. Between the guard and the flat pulley there is a spacer and another spacer between the two pullies. The shorter of the two spacers needs to be between the two pullies and the long one between the guard and the flat pulley. 2 Share this post Link to post Share on other sites
Ed Kennell 47,586 #6 Posted July 12 Any answer on which belt is the problem? Share this post Link to post Share on other sites
rjg854 13,402 #7 Posted July 13 He sent me a picture of his mule drive and one pulley is bright and shiny, so I sure the bearing is set-up on it. Share this post Link to post Share on other sites
Lee1977 7,803 #8 Posted July 13 53 minutes ago, rjg854 said: He sent me a picture of his mule drive and one pulley is bright and shiny, so I sure the bearing is set-up on it. If it's the flat pulley they aways get shiny. Share this post Link to post Share on other sites
Ed Kennell 47,586 #9 Posted July 13 (edited) 56 minutes ago, rjg854 said: He sent me a picture of his mule drive and one pulley is bright and shiny, so I sure the bearing is set-up on it. Yeah, he sent the pics to me too Randy. I asked him to post the pics and his comments on here so we can all see what is happening. He sent pics of the PTO and mule drive so I assume it is the PTO belt and not the deck spindle belt. Edited July 13 by Ed Kennell Share this post Link to post Share on other sites
Ed Kennell 47,586 #10 Posted July 17 @JOEPOE1977 Replied on my status "Thank you to all the members in helping me. All your experience and expertise is very much appreciated." I tried to show and convince him to reply on this thread, but apparently, he didn't get it. 1 Share this post Link to post Share on other sites
