bradleydavidgood
Help me identify my new tractor
bradleydavidgood
Hi,
I bought a Wheel Horse tractor yesterday for $500.
I looked all over the thing and can't find any plate or serial number.
Can you help me identify it by its features in the photos?
Or tell me where I can find the serial number or year information?
Thanks!
bradleydavidgood
bradleydavidgood
I have lots more pictures but at the limit.  Can a moderator approve a limit increase for me?
Thanks!
Sparky
Welcome!
  That’s a 1987-1989 414-8.
 The data on those year’s was on a decal on the rear fender which you don’t have.
 Very capable rig…I have the same machine here.
AlexR
Check this out comment #7 to narrow down your model year based on the engine numbers
Since you have a magnum engine on there it appears if the engine is original its a 87-89 model year
The model is the 414-8 which is the 400 series 14 hp and 8 speed manual
oldlineman
I have the same  tractor mine is a 1989, you also have the air filter cover missing.
sqrlgtr
Thanks!
if you become site supporter you have unlimited pics and other special stuff. It has paid for its self 10 times over on what I have learned and shared with others over the years. Also WELCOME to RS.
gwest_ca
Welcome to Red Square
If you post the Kohler serial number it may help to identify the model year of the tractor.
bradleydavidgood
1 hour ago, Sparky said:
imageproxy.php?img=&key=74de1d643bd8402fWelcome!
Thank you!  It seems very well built and strong for such a small thing.
bradleydavidgood
Thank you, I'll get one.
bradleydavidgood
Bought lifetime supporter $200.  Thank you for the idea!  Didn't know.
sqrlgtr
Awesome you r hooked now I see future Wheel Horses in your future :handgestures-thumbupright:
bradleydavidgood
I looked all over that engine and all I saw was a silver plate that looked like it once had something you could read but can't read anything on that any longer.  But it seems like we have it identified:
1987-1989 414-8 400 series 14 hp and 8 speed manual
Thanks!
bradleydavidgood
You mean we need more than one?  Interesting.  What will I tell my wife?
I already have a Farmall 140, a Massey Furguson Super 90, and tomorrow I am picking up a Ford 8N.
I can't imagine what else I need but I'm open to new ideas like that.
I'm really impressed by the quality that this thing seems to have which is rare.
Are they as good as they seem to be?
I'm good with mechanics so seems to me I just bought the tractor I can keep for a very long time.
Good parts available, can rebuild the motor if necessary right?
How's the transmissions last?
Are there any weak links that can't be fixed?
Thanks!
AlexR
Thanks!
While some other garden tractor manufacturers made some things stronger then Wheelhorse. Cub Cadet rear ends for example. Which that was only because they used a existing rear end that they already made for small tractors.
NOTHING beats the "keep it simple stupid" of the Wheelhorse's because of that, I enjoy working on them. Other garden tractors are not as enjoyable to work on.
But to put it simply, yes they as good as they seem to be. There is a reason almost everyone on this forum has more then one. Many have 10+
The kohler engines still have good parts support so yes it can still easily be done. A good chunk of what costs money rebuilding the engines is the machine work.
As far as transmissions go most of Wheelhorse's are pretty bulletproof, the one in your tractor is the best of the 8 speeds.
Nope as far as I know, there are no weak links that can't be fixed.
bradleydavidgood
Awesome, then I'm going to make it nice!
Thanks!
sqrlgtr
I believe in stock form the Wheel horse rears are just as tuff or tougher than The boo boo Cubs :hide:. Them pullers like the cub running gears because of the Big tractor style clutch and say they loose power from running belt drive which I can see there point but Ive seen a few belt drive Wheel Horses that were hard to beat on the pulling track.
Absolutely
I have had a few restored myself in years gone bye (Cockshutt 30, Cockshutt 50, Oliver 66, Afew JD's and several Older Fords) I tractor pulled with both the Cockshutts and the Oilver 66 and done very well. These WH's give me the same satisfaction and joy but are so much easier to store and fool with, quality's I appreciate the older I get.:D
