Fordiesel69 272 #1 Posted July 8 Urgently need a belt for the coming weekend and nobody has the toro 95-3878. Need to know its specs. I do not have the old belt. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,361 #2 Posted July 8 Spindle belt 95-3878 (HA x 102.44" or 1/2" x 102.44") 1 Share this post Link to post Share on other sites
Fordiesel69 272 #3 Posted July 8 So 1/2 x 102" long? Or 1/2 x 103" Local belt places dont have half sizes. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,361 #4 Posted July 8 Gates makes a Blade Runner series of belt that have fractional lengths but looked through a list of them and don't see one close to what you need. Part numbers are like 6420BR. Napa sells Gates belts. An A-100 industrial belt is 1/2" x 102" An A-101 industrial belt is 1/2" x 103" I do not know if these belts will withstand the reverse bending over a flat idler. They may because Gates lists some A-xxx belts for applications with a flat idler. If you can find a A-100 (102") to try at least you will know what works or won't work. Keep us posted on what happens for the next person. An A-100 is 100" datum circumference. We don't see that but it is determined by the location of the cords inside the belt and used for belt calculation and selection in industrial applications. You may have noticed the odd dimensions sheaves have that use a tapered hub. That is also a datum diameter also for speed calculations/design long with the belt datum length. Turns out the A belts add 2" to determine the outside circumference. B belts add 3". Some companies loosely use say a A-100 belt. It is the A (1/2") width but may be only 100 " long. Other companies it may be 102" long. So check the actual circumference when ordering. Share this post Link to post Share on other sites
Fordiesel69 272 #5 Posted July 9 As an update we got a Huskee 1/2" by 102" from TSC and it worked like a champ. It puts the spring tensioner right in the middle of travel, whereas when I used to recall rebuilding the other wheel horse decks, a factory belt would only tenstion the spring maybe 1/4th of its travel. In terms of doing the reverse bending of the flat idler, the good news is these decks have a lower blade speed than the actual lawn tractor decks, and also there is much less tension compared to other belt applications. I think it will last a while, maybe not as long as oem. But for $27.99 vs well over $100 at the dealer, I can buy 4 of them before it becomes a problem. 1/2" by 103" would be way too loose. Share this post Link to post Share on other sites
squonk 47,410 #6 Posted July 9 A straight A or B belt don't like reverse back side idlers. Use a 4L or 5L. The Husker belts will have both types printed on the belt. It's kind of a universal design. I think the manufacturers changed the design enough to save on the number of belts they need to make. Share this post Link to post Share on other sites
