Pullstart 71,474 #26 Posted July 13 It’s supposed to be 95 or hotter today. The shop just barely fits the new trailer! The shop A/C is on for a bit to bring the temps down to something a bit more comfortable. Rubber flooring and e-track is all here, that’s exciting! 3 11 Share this post Link to post Share on other sites
Pullstart 71,474 #27 Posted July 13 I have the main floor piece rough cut. I need to trim the front corners to a respectable lip. Then find some adhesive laying around and slap it down. 2 8 Share this post Link to post Share on other sites
Pullstart 71,474 #28 Posted July 13 I am very thankful for the shop to keep me comfy. It’s a scorcher out and it’s not even the high for the day. Pool was at 92 last I checked by the way. 2 Share this post Link to post Share on other sites
ebinmaine 81,020 #29 Posted July 13 51 minutes ago, Pullstart said: thankful for the shop to keep me comfy Absolute game changer. I can no longer tolerate the heat and humidity. My workshop has AC. 4 Share this post Link to post Share on other sites
Pullstart 71,474 #30 Posted July 13 I use 2 28oz tubes of HD adhesive, and the floor is glued in on bottom. I still need to cut the door opening and lay some metal over the side flaps. The back edge is still long. I may leave it a bit long, so any wet tires coming in won’t allow moisture at the edge. Let the door press seal it down, if you will. The e-track is 57 lbs and 5’ long. I figured it would work well to press the bubbles out, so I worked it front to rear a few times. I like the outcome. 4 5 Share this post Link to post Share on other sites
rjg854 13,407 #31 Posted July 13 Before cutting that, how about leaving it for like a baseboard. Share this post Link to post Share on other sites
Pullstart 71,474 #32 Posted July 13 57 minutes ago, rjg854 said: Before cutting that, how about leaving it for like a baseboard. Tis my plan, kind of. 1 Share this post Link to post Share on other sites
Pullstart 71,474 #33 Posted July 14 14 hours ago, rjg854 said: Before cutting that, how about leaving it for like a baseboard. 13 hours ago, Pullstart said: Tis my plan, kind of. More explanation is probably helpful. My idea is to run this up the side and staple it in place, a little glue near the cuts to make a better seal of course. I’ll run aluminum sheet along the walls and over the rubber. In my mind, it’s like building a shower pan. I don’t intend for it to be water proof, but withstand a strategic wash if needed. 3 3 Share this post Link to post Share on other sites
Pullstart 71,474 #34 Posted July 14 I got the side door cut in. I left the rubber a bit long, so it can shed water of course. 2 3 Share this post Link to post Share on other sites
Pullstart 71,474 #35 Posted July 14 On to the back door, and little ramp. I think I was awake half the night wondering how this would work. Solid piece of rubber over the hinge set? A scrap piece and a few screws proved that it would not last very long. One fold and the rubber already had stress marks. It would be only a matter of time before it snapped and defeated the purpose. 1 1 Share this post Link to post Share on other sites
Pullstart 71,474 #36 Posted July 14 I took some measurements to verify the hinge was indeed centered, then pulled the small ramp off. Funny tid bit, that’s enough weight loss for the door to begin closing itself! 3 Share this post Link to post Share on other sites
Pullstart 71,474 #37 Posted July 14 Of course edges are left long at this time. I’ll trim it down as needed. I rolled out some rubber and glued the bottom edge in place. I trimmed the lift cable brackets out as close as I could. Then, I reinstalled the hinge. 4 Share this post Link to post Share on other sites
Pullstart 71,474 #38 Posted July 14 I rolled out the entire door, cut it to (excessive) length, and rolled it back down. My glue pattern kind of duplicates the idea of an ag tire. I figured a diagonal grip to the wood would ensure maximum grip to a glued surface at any given time. Time will tell if that is a good idea. Like the trailer floor, I used the e-track box to roll out the bubbles and slack. A few passes center, left, right, repeat, and it seemed to flatten out well. I think the ramp worked out better than the trailer floor, but it needs to hold things by itself too. The floor will have e-track to secure it also. 5 1 Share this post Link to post Share on other sites
Mike'sHorseBarn 3,704 #39 Posted July 14 Dang it Kevin, you're giving me trailer fever! 1 1 2 Share this post Link to post Share on other sites
Pullstart 71,474 #40 Posted July 14 10 minutes ago, Mike'sHorseBarn said: Dang it Kevin, you're giving me trailer fever! Momma says I can’t haul with it until it’s done! 2 1 Share this post Link to post Share on other sites
Pullstart 71,474 #41 Posted July 14 I trimmed the back edge of the floor rubber and trimmed and fastened the ramp rubber. The door closes and opens well! 5 1 Share this post Link to post Share on other sites
Pullstart 71,474 #42 Posted July 14 I ordered a few hundred self tapping stainless screws to install the E-track. I think I have settled on the spacing for the floor pieces. I believe this spacing will work well for any sized GT I have, motorcycles or even a small car. I’ll run the full 16’ for these, starting as close to the back door as possible. 4 1 Share this post Link to post Share on other sites
Pullstart 71,474 #43 Posted July 14 The last piece to cover is the ramp flapper. I cut out a piece of rubber and squared it up real good. I glued the face of the rubber and stuck the wood on, maneuvering it around a bit. I then added the e-track weight kits and will let it cure up for a day or so. I’ve got a 3/4” square aluminum tube that I will use as a lock seam for the two loose pieces of rubber. I drilled 17 holes in the tubing and chamfered them for some coarse construction screws to hold it down. Glued of course! It’ll be about 4” back from the edge so it can support the ramp but not elevate it too much. Time will tell if I will need to add a different skid plate at the immediate edge. 5 1 Share this post Link to post Share on other sites
Pullstart 71,474 #44 Posted July 14 1 hour ago, Pullstart said: will let it cure up for a day or so. who am I kidding? 2 6 1 1 Share this post Link to post Share on other sites
Pullstart 71,474 #45 Posted July 15 I found some black PVC 1x4 trim in town. Once I get the sheet metal up along the walls, it should finish the bottom well without concern of rot. 3 1 Share this post Link to post Share on other sites
Pullstart 71,474 #46 Posted July 15 I tidied some of my rubber edges up, and @Lil’ Pullstart helped me snap some lines for the e-track. 5 3 Share this post Link to post Share on other sites
MainelyWheelhorse 3,160 #47 Posted July 17 (edited) On 7/13/2026 at 1:41 PM, ebinmaine said: Absolute game changer. I can no longer tolerate the heat and humidity. My workshop has AC. I like the heat to a point. Usually up to the point you can’t do anything but sweat. After that I’m done. My basement/workshop is half in the ground, and except for the 80-90+ days it stays around a cool 50 degrees. So no A/C as of yet. I’ve got one in the house though, as that becomes an oven during the summer. Edited July 17 by MainelyWheelhorse 2 Share this post Link to post Share on other sites
ML3 2,548 #48 Posted July 17 On 7/13/2026 at 1:41 PM, ebinmaine said: Absolute game changer. I can no longer tolerate the heat and humidity. My workshop has AC. I'm going to do a mini-split system in my garage mostly for a/c but also for heat too. 3 Share this post Link to post Share on other sites
ebinmaine 81,020 #49 Posted July 17 29 minutes ago, ML3 said: I'm going to do a mini-split system in my garage mostly for a/c but also for heat too. We looked at those in comparison to the huge window unit we bought. I did not find the value in the mini split. The AC we bought was well under $1,000 and the mini split was going to be 2.5 times that or more. We know some people that have mini splits installed including the electrician that was going to do it. None of them are super pleased with the results they get under outside temps about 25°. That's pretty much the entire month of January and can spread another month either direction up here. Share this post Link to post Share on other sites
Pullstart 71,474 #50 Posted July 17 4 hours ago, ML3 said: I'm going to do a mini-split system in my garage mostly for a/c but also for heat too. If ever needed, I would not be opposed to putting a small one in this trailer. But I think we are to the point that the motorhome will be our refuge. 5 Share this post Link to post Share on other sites
