Sparky-(Admin) 25,793 #1 Posted 4 hours ago All new rigs that come here need something, so they all get a turn in the garage for fluids/grease and all that. Well my new C-81 from the Wheel Horse Show had a pretty good oil leak that I didn’t notice at first. Showed up after a 20 minute drive. Turned out the fuel pump gasket was on UPSIDE DOWN! Had a new gasket here in stock and it was an easy fix. I don’t have a gasket for the carb to engine block as that one isn’t correct, but it does seem to seal. Any reason I need to do the carb gasket??? 2 1 Share this post Link to post Share on other sites
pfrederi 20,805 #2 Posted 3 hours ago if you are going to run her long and hard you might want to get the correct gasket as it insulates the carb from engine heat. Honestly I have several engines with whatever gasket i could find and haven't had issues but most are limited duty. 2 1 Share this post Link to post Share on other sites
ebinmaine 79,411 #3 Posted 3 hours ago 7 minutes ago, Sparky said: Turned out the fuel pump gasket was on UPSIDE DOWN I've seen that too. 8 minutes ago, Sparky said: I don’t have a gasket for the carb to engine block as that one isn’t correct, but it does seem to seal. Any reason I need to do the carb gasket??? If you can get that one to reseal and set exactly where it was, it'll be fine for now. 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,793 #4 Posted 3 hours ago Oh…and this repair was completed in my garage at 95 degrees 4 Share this post Link to post Share on other sites
squonk 47,174 #5 Posted 3 hours ago I picked up a tractor once that ran fine but had NO GASKET at the carb. 2 1 Share this post Link to post Share on other sites
squonk 47,174 #6 Posted 3 hours ago 2 minutes ago, Sparky said: Oh…and this repair was completed in my garage at 95 degrees I grabbed this Horror Fright fan on the clearance shelf yesterday. Then got 15% off and used my $15 HF money as well! 1 1 Share this post Link to post Share on other sites
ebinmaine 79,411 #7 Posted 3 hours ago 3 minutes ago, Sparky said: Oh…and this repair was completed in my garage at 95 degrees Ya know there's stores that sell AC units? Share this post Link to post Share on other sites
Sparky-(Admin) 25,793 #8 Posted 3 hours ago 15 minutes ago, ebinmaine said: Ya know there's stores that sell AC units? Garage is 28’x36’ (1008 sq/ft) and not insulated…how big an AC unit ya think I need . 3 Share this post Link to post Share on other sites
Sparky-(Admin) 25,793 #9 Posted 3 hours ago 18 minutes ago, squonk said: I grabbed this Horror Fright fan on the clearance shelf yesterday. Then got 15% off and used my $15 HF money as well! I do have this industrial/oscillating fan cranking away…helps some. And before all the comments about “go boating” …the local lake is a zoo being a holiday weekend and they shut down the boat launch. Plus my wife had knee surgery and she wouldn’t be able to climb in and outa the boat. 2 Share this post Link to post Share on other sites
ri702bill 12,354 #10 Posted 2 hours ago Mike - I agree it can be resealed - either with Permatex #2 - the non hardening stuff, or a smear of heavy grease. FYI when I get a new to me WH and the carb is removed, I use the Permatex #2 to "glue" the new gasket to the engine and apply the light coat of grease to the carb mating flange. Makes carb removal easy down the road... 1 1 Share this post Link to post Share on other sites
peter lena 9,926 #11 Posted 2 hours ago @Sparky what did your wife have done on the knee? pete Share this post Link to post Share on other sites
ebinmaine 79,411 #12 Posted 2 hours ago 40 minutes ago, Sparky said: Garage is 28’x36’ (1008 sq/ft) and not insulated…how big an AC unit ya think I need . All of em? 3 Share this post Link to post Share on other sites
Sparky-(Admin) 25,793 #13 Posted 2 hours ago 7 minutes ago, peter lena said: @Sparky what did your wife have done on the knee? pete Two meniscus repairs Share this post Link to post Share on other sites
squonk 47,174 #14 Posted 2 hours ago 35 minutes ago, Sparky said: And before all the comments about “go boating” …the local lake is a zoo being a holiday weekend and they shut down the boat launch. I'm stuck right at the northern tip between the 2 largest Finger Lakes. I take my dog for walks at the only State Park I don't have to pay on weekends. Dean's Cove. They have this large parking lot for the trucks and boat trailers. Plus a large grassy area. Last Sunday the trailers were parked along the highway there were so many boaters there. I'm not even going to try to go there tomorrow! 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 25,793 #15 Posted 2 hours ago 16 minutes ago, ri702bill said: Mike - I agree it can be resealed - either with Permatex #2 - the non hardening stuff, or a smear of heavy grease. FYI when I get a new to me WH and the carb is removed, I use the Permatex #2 to "glue" the new gasket to the engine and apply the light coat of grease to the carb mating flange. Makes carb removal easy down the road... I still chuckle when I think about that carb gasket on the C-81 you bought off me. Bizarre that it even fired and ran! 1 Share this post Link to post Share on other sites
squonk 47,174 #16 Posted 2 hours ago 46 minutes ago, Sparky said: Garage is 28’x36’ (1008 sq/ft) and not insulated…how big an AC unit ya think I need . I got a 220 volt 24,000 btu (2 ton) window shaker in my garage. It only gets used if "I have to " be out there in heat like this. That fan you have is sucking all the heat out of the rafters and blowing it all on you. Get a barn fan on wheels at least and circulate the " cooler"air on the floor. 2 Share this post Link to post Share on other sites
peter lena 9,926 #17 Posted 2 hours ago @Sparky close to 20 years on my both knees being done , exactly 6 months apart total joints , almost comical today , 3 days in hosp , then 10 days in nursing home , learning how to walk , then home for rehab work , most gained area , ? using a roller stool to pull / push myself around . today everything is hour's and , home therapy . my wifes , thumb split bone , was months , of constant involvement , helped any way I could , hand is close to 100% , pete Share this post Link to post Share on other sites
ebinmaine 79,411 #18 Posted 1 hour ago (edited) 24 minutes ago, squonk said: 220 volt 24,000 btu (2 ton) window shaker That's about what we have in the workshop space. Permanently mounted in the back wall. 10 x 40 ft. Very light insulation (the silver stuff). The room is as airtight and rodent resistant as we could do. Because of my body issues I can't take the combination of heat and humidity. Anything above 80⁰ and mild humidity and I'm just absolutely spent. Edited 1 hour ago by ebinmaine Added AC pic Share this post Link to post Share on other sites
ri702bill 12,354 #19 Posted 1 hour ago 1 hour ago, Sparky said: I still chuckle when I think about that carb gasket on the C-81 you bought off me. Bizarre that it even fired and ran! Add one more to the oops list from the PO. It's only been a year - today - that I bought that C81 from you. It is going back together... The + and - wires on the coil are backwards... neither one of us spotted that! It has the hot wire going to the - terminal and the condenser & points wire going to the + terminal - and it ran! 1 Share this post Link to post Share on other sites
