Sparky-(Admin) 26,890 #1 Posted July 4 All new rigs that come here need something, so they all get a turn in the garage for fluids/grease and all that. Well my new C-81 from the Wheel Horse Show had a pretty good oil leak that I didn’t notice at first. Showed up after a 20 minute drive. Turned out the fuel pump gasket was on UPSIDE DOWN! Had a new gasket here in stock and it was an easy fix. I don’t have a gasket for the carb to engine block as that one isn’t correct, but it does seem to seal. Any reason I need to do the carb gasket??? 5 1 1 Share this post Link to post Share on other sites
pfrederi 21,342 #2 Posted July 4 if you are going to run her long and hard you might want to get the correct gasket as it insulates the carb from engine heat. Honestly I have several engines with whatever gasket i could find and haven't had issues but most are limited duty. 4 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #3 Posted July 4 7 minutes ago, Sparky said: Turned out the fuel pump gasket was on UPSIDE DOWN I've seen that too. 8 minutes ago, Sparky said: I don’t have a gasket for the carb to engine block as that one isn’t correct, but it does seem to seal. Any reason I need to do the carb gasket??? If you can get that one to reseal and set exactly where it was, it'll be fine for now. 1 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #4 Posted July 4 Oh…and this repair was completed in my garage at 95 degrees 2 4 Share this post Link to post Share on other sites
squonk 48,427 #5 Posted July 4 I picked up a tractor once that ran fine but had NO GASKET at the carb. 3 2 Share this post Link to post Share on other sites
squonk 48,427 #6 Posted July 4 2 minutes ago, Sparky said: Oh…and this repair was completed in my garage at 95 degrees I grabbed this Horror Fright fan on the clearance shelf yesterday. Then got 15% off and used my $15 HF money as well! 3 1 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #7 Posted July 4 3 minutes ago, Sparky said: Oh…and this repair was completed in my garage at 95 degrees Ya know there's stores that sell AC units? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #8 Posted July 4 15 minutes ago, ebinmaine said: Ya know there's stores that sell AC units? Garage is 28’x36’ (1008 sq/ft) and not insulated…how big an AC unit ya think I need . 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #9 Posted July 4 18 minutes ago, squonk said: I grabbed this Horror Fright fan on the clearance shelf yesterday. Then got 15% off and used my $15 HF money as well! I do have this industrial/oscillating fan cranking away…helps some. And before all the comments about “go boating” …the local lake is a zoo being a holiday weekend and they shut down the boat launch. Plus my wife had knee surgery and she wouldn’t be able to climb in and outa the boat. 3 Share this post Link to post Share on other sites
ri702bill 13,391 #10 Posted July 4 Mike - I agree it can be resealed - either with Permatex #2 - the non hardening stuff, or a smear of heavy grease. FYI when I get a new to me WH and the carb is removed, I use the Permatex #2 to "glue" the new gasket to the engine and apply the light coat of grease to the carb mating flange. Makes carb removal easy down the road... 2 1 Share this post Link to post Share on other sites
peter lena 10,125 #11 Posted July 4 @Sparky what did your wife have done on the knee? pete Share this post Link to post Share on other sites
ebinmaine 81,278 #12 Posted July 4 40 minutes ago, Sparky said: Garage is 28’x36’ (1008 sq/ft) and not insulated…how big an AC unit ya think I need . All of em? 4 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #13 Posted July 4 7 minutes ago, peter lena said: @Sparky what did your wife have done on the knee? pete Two meniscus repairs Share this post Link to post Share on other sites
squonk 48,427 #14 Posted July 4 35 minutes ago, Sparky said: And before all the comments about “go boating” …the local lake is a zoo being a holiday weekend and they shut down the boat launch. I'm stuck right at the northern tip between the 2 largest Finger Lakes. I take my dog for walks at the only State Park I don't have to pay on weekends. Dean's Cove. They have this large parking lot for the trucks and boat trailers. Plus a large grassy area. Last Sunday the trailers were parked along the highway there were so many boaters there. I'm not even going to try to go there tomorrow! 2 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #15 Posted July 4 16 minutes ago, ri702bill said: Mike - I agree it can be resealed - either with Permatex #2 - the non hardening stuff, or a smear of heavy grease. FYI when I get a new to me WH and the carb is removed, I use the Permatex #2 to "glue" the new gasket to the engine and apply the light coat of grease to the carb mating flange. Makes carb removal easy down the road... I still chuckle when I think about that carb gasket on the C-81 you bought off me. Bizarre that it even fired and ran! 1 Share this post Link to post Share on other sites
squonk 48,427 #16 Posted July 4 46 minutes ago, Sparky said: Garage is 28’x36’ (1008 sq/ft) and not insulated…how big an AC unit ya think I need . I got a 220 volt 24,000 btu (2 ton) window shaker in my garage. It only gets used if "I have to " be out there in heat like this. That fan you have is sucking all the heat out of the rafters and blowing it all on you. Get a barn fan on wheels at least and circulate the " cooler"air on the floor. 2 Share this post Link to post Share on other sites
peter lena 10,125 #17 Posted July 4 @Sparky close to 20 years on my both knees being done , exactly 6 months apart total joints , almost comical today , 3 days in hosp , then 10 days in nursing home , learning how to walk , then home for rehab work , most gained area , ? using a roller stool to pull / push myself around . today everything is hour's and , home therapy . my wifes , thumb split bone , was months , of constant involvement , helped any way I could , hand is close to 100% , pete Share this post Link to post Share on other sites
ebinmaine 81,278 #18 Posted July 4 (edited) 24 minutes ago, squonk said: 220 volt 24,000 btu (2 ton) window shaker That's about what we have in the workshop space. Permanently mounted in the back wall. 10 x 40 ft. Very light insulation (the silver stuff). The room is as airtight and rodent resistant as we could do. Because of my body issues I can't take the combination of heat and humidity. Anything above 80⁰ and mild humidity and I'm just absolutely spent. Edited July 4 by ebinmaine Added AC pic Share this post Link to post Share on other sites
ri702bill 13,391 #19 Posted July 4 1 hour ago, Sparky said: I still chuckle when I think about that carb gasket on the C-81 you bought off me. Bizarre that it even fired and ran! Add one more to the oops list from the PO. It's only been a year - today - that I bought that C81 from you. It is going back together... The + and - wires on the coil are backwards... neither one of us spotted that! It has the hot wire going to the - terminal and the condenser & points wire going to the + terminal - and it ran! 1 Share this post Link to post Share on other sites
sqrlgtr 4,224 #20 Posted July 5 (edited) 6 hours ago, Sparky said: Any reason I need to do the carb gasket??? I wouldnt worry about (if it seals up right) but have one on hand fer next time ya have carb off... Edited July 5 by sqrlgtr 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,890 #21 Posted July 5 3 minutes ago, sqrlgtr said: I wouldnt worry about but have one on hand fer next time ya have carb off... That’s my plan.. next time I place an order for small engine parts I’ll get a carb gasket as well . 1 Share this post Link to post Share on other sites
sqrlgtr 4,224 #22 Posted July 5 Just now, Sparky said: That’s my plan.. next time I place an order for small engine parts I’ll get a carb gasket as well . yeah I try and keep a few small block and big block carb to block gaskets on hand. Share this post Link to post Share on other sites
kpinnc 19,105 #23 Posted July 6 On 7/4/2026 at 2:18 PM, Sparky said: Any reason I need to do the carb gasket??? New gaskets or old carb gaskets, I use a tiny bit of silicone gasket sealer. Never had one leak, and the excess wipes off easily after all the bolts get torqued. Just a little insurance... 1 Share this post Link to post Share on other sites
Retired Wrencher 7,042 #24 Posted July 8 (edited) On 7/4/2026 at 3:16 PM, Sparky said: Garage is 28’x36’ (1008 sq/ft) and not insulated…how big an AC unit ya think I need . Mike: Stick one in the window. Maybe a 8000btu? There cheap Ocean StateJob lot stores. you can also put a divider in there get yourself a cheap tarp and run it along the ceiling so the air-conditioning only goes in that one area and I think you can think the same way if you want for at winter time for heat I pretty much did that when we built the garage and it had no sheet rock and insulation in it. but once we put sheet rock in insulation in it, it’s pretty warm in the winter with the triple burner,propane heater. I also have a two burner once the garage is fairly warm. I switched to that. Edited July 8 by Retired Wrencher 1 Share this post Link to post Share on other sites
