eo1bart 54 #1 Posted July 4 (edited) I have a running12 hp engine that came with a 312-8 parts tractor that I bought. The hour meter on the tractor had approx. 2000 hours on it . I'd like to freshen up the engine and use it to replace the K301 that is currently in my daily driver. I've removed the head and it is still in spec. but glazed over and wet. At the very least I'll hone it and replace the rings. Looking for recommendation on how far to go with it. Replace the piston also? buy the whole rebuild kit for $150 that includes the conrod and valves? Replace crank bearings? Thanks Edited July 4 by eo1bart Share this post Link to post Share on other sites
ri702bill 13,035 #2 Posted July 4 A lot is determined by the size of the both the block and the crank. This is best determined with the engine disassembled. The bore needs to be measured for diameter, roundness and taper. Three sets of two measurements - at the top near the end of ring travel, midway down, and the bottom of ring travel, taken 90 degrees apart. This will determine if just honing the bore is sufficient (most likely not at 2000 plus hours), or if boring to the next oversize is in order. The tools required are a telescoping bore gage and the correct size micrometer. A dial caliper can be used, but is more difficult to get accurate readings. Note - if the top of the piston already says .030, reboring may not be possible. It is easier to measure the crank journal. Same idea, three sets of measurements 90 degrees apart. Again, if the crank has already been cut .010 undersize, it may need to be replaced. If you have a local trusted Machine Shop nearby, let them do the measurements if you do not possess the proper tools..... One more area - valves, seats, & valve guides. Those need to be inspected for conformity to Kohler specs and are replaceable if needed. IF you go the rebore and recut route, get the oversize piston and undersize connecting rod BEFORE any machine work is done to allow the machinist to remove material for optimum clearances on both. 1 1 Share this post Link to post Share on other sites
953 nut 69,243 #3 Posted July 4 If you do the swap from K Series with battery powered ignition to a Magnum the wiring can be easily modified using the information this thread. 1 Share this post Link to post Share on other sites
WHX?? 58,089 #4 Posted July 4 (edited) 3 hours ago, eo1bart said: how far to go with it. Other than the bore & big end shape I go by other things as well such as the condition of the rest of the block. Did it see regular oil changes/ kept full? Big end shape will tell you that. Lots of sludge? Has it been apart before? Did it smoke a little/a lot? Were the fins kept clean? In other words what kind of life did it lead in those 2000 hours? If it's going to be a daily driver I am already leaning towards full blown. A parade queen maybe just a re-ring. Edited July 4 by WHX?? 3 Share this post Link to post Share on other sites
eo1bart 54 #5 Posted July 5 (edited) After disassembly and taking measurements, I decided to go with the full rebuild kit. (Standard size). Just ordered it off ebay One other question, Yay or Nay on reinstalling the balance gears? Edited July 5 by eo1bart 1 Share this post Link to post Share on other sites
WHX?? 58,089 #6 Posted July 5 4 hours ago, eo1bart said: Yay or Nay on reinstalling the balance gears? No brainer Bart leave them out and I can say I am speaking for the rest of us here. Just out of curiosity what did the bearings in them look like? Share this post Link to post Share on other sites
JoeM 10,266 #7 Posted July 5 1 hour ago, WHX?? said: leave them out should you do that in a magnum? Share this post Link to post Share on other sites
eo1bart 54 #8 Posted July 5 (edited) 2 hours ago, WHX?? said: No brainer Bart leave them out and I can say I am speaking for the rest of us here. Just out of curiosity what did the bearings in them look like? The bearings and everything else in the crankcase were in excellent condition Edited July 5 by eo1bart Share this post Link to post Share on other sites
