ML3 2,510 #1 Posted July 3 (edited) Picked this up yesterday. Was only an hour away. Seller said it was sitting for a few years so he had it serviced to get it running. Was asking $800. Got there & cranked w/no start. Ended up getting it for $300! Got it home & after using my small benchtop 20v blower to pressurize fuel tank it started right up! Everything appears to function. This will be new tractor to use with my Bervac. After the heat wave is over I'll go through it addressing maintenance & any possible needed repairs. Paint is faded so hopefully I can get it reconditioned. Have to get manuals printed off & definitely wanna address the "known issues" with this model. Onans are all new to me. 20260702_160202.mp4 Edited July 3 by ML3 3 4 Share this post Link to post Share on other sites
JCM 11,415 #2 Posted July 3 That red should come back with some elbow grease and determination. Good Luck with it. 2 Share this post Link to post Share on other sites
peter lena 10,065 #3 Posted July 3 @ML3 perfect stage / condition for this , done this on my 3 horses , and any similar faded / neglected anything I pick up , base line simplicity , penetrating aerosol spray down , all / every area , like to leave it in hot sun for hours , to heat up absorb . deeply into paint base , nothing about this is quick , days in , try a spot with a clean , mineral oil , cloth rub down , if it breaks thru , suden clean / clear color depth , you are on your way . like a 6" electric palm buffer , with a cleaner wax , don,t push it , has to be easily shown , once mine have shown themselves , I only gently rub it down with a clean cloth and mineral oil , cloth stays clean / clear , no dust or dirt , many years in on this , no rust or faded paint , fearful / worried ? try a small area , thats how I started , give it a try , pete 2 Share this post Link to post Share on other sites
ebinmaine 80,695 #4 Posted July 3 1 hour ago, ML3 said: Onans are all new to me. Good engines when properly maintained just like many others. On a WH it's the 20 HP that has the more common issues due to lack of cleaning and overheating. The 16 HP is less prone. The New to the Herd list might help some. 1 Share this post Link to post Share on other sites
parsonsponyz 407 #5 Posted July 3 Looks like a nice addition to your herd. You'll have the paint shining in no time. Share this post Link to post Share on other sites
Handy Don 17,474 #6 Posted July 3 (edited) Nice find! I”ve not seen a 416 with the 6” wheels and a 37” deck mounted before. As noted above, Onans will serve you well if you take care of maintenance and cleaning. The fuel does drain back if left for a couple of weeks, but the pump works fine once the engine is running. To that end, we added an outboard motor squeeze bulb to the fuel line. Give it two or three squeezes (it’ll get firm once the carb is fully fueled) and then the tractor starts right up. Edited July 3 by Handy Don 1 Share this post Link to post Share on other sites
lynnmor 9,040 #7 Posted July 3 27 minutes ago, ebinmaine said: Good engines when properly maintained just like many others. On a WH it's the 20 HP that has the more common issues due to lack of cleaning and overheating. The 16 HP is less prone. The New to the Herd list might help some. The 20 HP has .030" more lift on the intake lobe and the carburetor has slightly different jetting. The idea that the 20 has more problems, in my opinion, is just Wisdom of the Crowd. 1 1 Share this post Link to post Share on other sites
ML3 2,510 #8 Posted July 3 2 hours ago, Handy Don said: Nice find! I”ve not seen a 416 with the 6” wheels and a 37” deck mounted before. As noted above, Onans will serve you well if you take care of maintenance and cleaning. The fuel does drain back if left for a couple of weeks, but the pump works fine once the engine is running. To that end, we added an outboard motor squeeze bulb to the fuel line. Give it two or three squeezes (it’ll get firm once the carb is fully fueled) and then the tractor starts right up. I never have seen the smaller wheels on a 416 either but I'm by no means an expert. Might swap out wheels from the Workhorse. The deck when fully raised rubs at front of rear tires. 1 Share this post Link to post Share on other sites
Handy Don 17,474 #9 Posted July 3 (edited) 5 hours ago, ML3 said: I'm by no means an expert. Might swap out wheels from the Workhorse Me neither! The tricks with the 37” deck are the angled, 2-blade setup (which needs the smaller front wheels for clearance on left turns!) and the capacity to run vac-lift blades that permit bagging without a bulky, separately powered chute. These are valuable features to some folks. If you choose to switch to the 8” wheels, you’ll want to switch the spindles, too, to keep things level. They are an inch shorter for the 8” wheels. Of course, then you'll have to switch to a 42, 48, or 60” deck! Some members want the taller 6” spindles with the 8” wheels when they go to larger (i.e. 24 or 25 inch) rear wheels. Edited July 3 by Handy Don 1 Share this post Link to post Share on other sites
953 nut 69,296 #10 Posted July 3 10 hours ago, ML3 said: after using my small benchtop 20v blower to pressurize fuel tank it started right up! Sounds like a good candidate for an electric fuel pump. 1 1 Share this post Link to post Share on other sites
Bill D 3,156 #11 Posted July 4 The 416H is my favorite tractor, but it does have some issues. Here's what I do to mine: 1. Install a foot pedal control. I hate the hand controls, especially on that model. I built my own, but there are a couple you can buy. Huge improvement. 2. Install a new fuel pump. Since OEM Onan pumps are not available, and I don't trust the Chinese knock offs, I installed a Kawasaki pump as shown. 3. If the 9 pin isn't burnt, clean it and put Noalox on the pins. If it's burnt, replace it with Packard connector. You only need seven of the nine pins on the 416. I used a 5 pin and 2 pin connector, but 8 pin connectors are available. 4. Run a wire from the battery positive on the starter to the voltage regulator/rectifier to take the load off the 9 pin. Fuse it as shown in the pictures. I used the unused white wire for the cylinder head temp sensor. 5. Clean the carb carfully. Take out the main jet and clean everything thoroughly. 6. I have removed, split and resealed the intake using Motoseal. If it has enough hours on it to be due for a decarbon and valve adjustment then that would be an ideal time to reseal the manifold. Just some thoughts. How many hours on it? 2 1 Share this post Link to post Share on other sites
ML3 2,510 #12 Posted July 4 (edited) 20 hours ago, Bill D said: The 416H is my favorite tractor, but it does have some issues. Here's what I do to mine: 1. Install a foot pedal control. I hate the hand controls, especially on that model. I built my own, but there are a couple you can buy. Huge improvement. 2. Install a new fuel pump. Since OEM Onan pumps are not available, and I don't trust the Chinese knock offs, I installed a Kawasaki pump as shown. 3. If the 9 pin isn't burnt, clean it and put Noalox on the pins. If it's burnt, replace it with Packard connector. You only need seven of the nine pins on the 416. I used a 5 pin and 2 pin connector, but 8 pin connectors are available. 4. Run a wire from the battery positive on the starter to the voltage regulator/rectifier to take the load off the 9 pin. Fuse it as shown in the pictures. I used the unused white wire for the cylinder head temp sensor. 5. Clean the carb carfully. Take out the main jet and clean everything thoroughly. 6. I have removed, split and resealed the intake using Motoseal. If it has enough hours on it to be due for a decarbon and valve adjustment then that would be an ideal time to reseal the manifold. Just some thoughts. How many hours on it? Definitely will do a foot pedal control- I dont like the lever. Ill have to see who sells them. Likely will do the electric fuel pump also. 9 pin appears to look fine but weather here has been too hot for me to be out inspecting it just yet. Ill definitely do the wiring modification to help take load off 9pin Carb was supposedly cleaned recently. It starts easy & runs/idles good. Hours are unknown. Hour meter is missing, just a hole where it should be. I would guess by overall condition maybe under 1000hrs??? Idk. Doing valve adjustment makes sense. Edited July 4 by ML3 1 Share this post Link to post Share on other sites
Bill D 3,156 #13 Posted July 4 (edited) I've built my own hydro pedal setups. Search Hydro Pedal #1, #2, or #3 and you should find the threads. I can't seem to figure out how to attach links. Feel free to copy my design at your own risk. Not comfortable selling them due to liability issues. I also change over to LED headlights to take addition load off the nine pin connector. Check your fuse box for melted fuse holders. Edited July 4 by Bill D Share this post Link to post Share on other sites
953 nut 69,296 #14 Posted July 4 (edited) 23 minutes ago, Bill D said: I can't seem to figure out how to attach links. To attach a link to your own (or other threads) you can open that thread, highlight the address at the top, right click COPY, return to the thread you want to post it in and right click again then hit PASTE. Magickly it will appear. Edited July 4 by 953 nut fat finger 1 Share this post Link to post Share on other sites
ebinmaine 80,695 #15 Posted July 4 35 minutes ago, 953 nut said: To attach a link to your own (or other threads) you can open that thread On my Android phone it's different. You touch and hold the address bar at the top for a second or two and a little black/ grey window appears that states Copied to clipboard. Here's a screenshot of this very thread. Then you touch & hold the text window where you want to insert the copied link. Touch "Paste" And the link is inserted. Note: THIS PROCEDURE CHANGES OCCASIONALLY BECAUSE OF UPDATES. Share this post Link to post Share on other sites
953 nut 69,296 #16 Posted July 4 32 minutes ago, ebinmaine said: my Android phone I had heard some owned an Android, now I know who! 1 Share this post Link to post Share on other sites
clueless 3,439 #17 Posted July 4 The tractor doesn't usually have many problems, with a little maintenance now and then. The 37" deck on the other hand can, most of them have developed small cracks around where the cradle mounts to the deck, the front right is usually the first to start, if not addressed then the back right starts and so on. Share this post Link to post Share on other sites
ML3 2,510 #18 Posted July 4 (edited) 6 hours ago, Bill D said: I've built my own hydro pedal setups. Search Hydro Pedal #1, #2, or #3 and you should find the threads. I can't seem to figure out how to attach links. Feel free to copy my design at your own risk. Not comfortable selling them due to liability issues. I also change over to LED headlights to take addition load off the nine pin connector. Check your fuse box for melted fuse holders. Already ordered led headlamps. Haven't had a chance yet to really inspect fuse box closely. From what I see it appears to be ok..... Edited July 4 by ML3 Share this post Link to post Share on other sites
ML3 2,510 #19 Posted July 4 (edited) 4 hours ago, clueless said: The tractor doesn't usually have many problems, with a little maintenance now and then. The 37" deck on the other hand can, most of them have developed small cracks around where the cradle mounts to the deck, the front right is usually the first to start, if not addressed then the back right starts and so on. Not worried about the deck or ever mowing with it. The Bervac is getting installed & its staying on! Designated heavy duty snow removal machine is what it will be Edited July 4 by ML3 1 1 Share this post Link to post Share on other sites
kpinnc 18,960 #20 Posted July 5 On 7/3/2026 at 8:17 AM, ML3 said: Onans are all new to me. I'm no fan of the P220 engine but the P216 engines like yours seem to be less prone to some of the issues of the 20hp models. This should be a great tractor for you. Keep it serviced and it will last a long time! Share this post Link to post Share on other sites
ML3 2,510 #21 Posted July 5 1 hour ago, kpinnc said: I'm no fan of the P220 engine but the P216 engines like yours seem to be less prone to some of the issues of the 20hp models. This should be a great tractor for you. Keep it serviced and it will last a long time! Hope so. Already got a list started of parts to purchase to do all the needed maintenance items. Like I mentioned its my 1st experience with an Onan. 2 Share this post Link to post Share on other sites
cjb398 40 #22 Posted July 5 On 7/3/2026 at 9:45 PM, Bill D said: Run a wire from the battery positive on the starter to the voltage regulator/rectifier to take the load off the 9 pin. Fuse it as shown in the pictures. Hey Bill, what amperage and type of fuse are you using for this? I can't determine from the picture. Thanks. Chuck Share this post Link to post Share on other sites
Bill D 3,156 #23 Posted July 7 On 7/5/2026 at 11:42 AM, cjb398 said: Hey Bill, what amperage and type of fuse are you using for this? I can't determine from the picture. Thanks. Chuck Sorry for the late reply, it's a 30 amp fuse. 1 Share this post Link to post Share on other sites
