FLtractor 223 #1 Posted July 2 (edited) Afternoon, My 856 started ran drive on Sunday… since then I moved the ignition to a new dash hole so it’s not loose.. raised tank up. Added inline fuel shutoff valve.. added proper fuel hose clamps.. attached air filter, checked engine oil level and smell. Went to start it up today and cranked briefly then didn’t even wanna turn over just sounded like a fart of air from the starter. I checked connections.. positive cable at ignition somewhat loose so I tightened it up.. didn’t fix it. Battery fully charged. Could these cables corrison fraying be the issue that Started other day now not at all. Edited July 2 by FLtractor Share this post Link to post Share on other sites
702854boy 1,149 #2 Posted July 2 I'd start with checking all your grounds and redoing the battery cables. That positive cable looks like it needed replaced 20 years ago. 5 1 Share this post Link to post Share on other sites
pfrederi 21,150 #3 Posted July 2 Ar least take the wires off the S/G and clean them up. are you using teh original heavy duty switch with 3 terminals ...Make sure you check them for tightness 2 Share this post Link to post Share on other sites
squonk 48,119 #4 Posted July 2 Those cables are junk. A starter gen takes about 60 amps to start turning the engine. And you need clean grounds including where the gen and gen bracket mounts. 3 1 Share this post Link to post Share on other sites
Thegearhead0324 1,842 #5 Posted July 2 Connectors must be clean clean clean. Running and making new cables/wires would be my first choice, moving the ignition switch maybe moved a wire that is internally corroded. I remember about 7 or so years ago, I put an old Ford style solenoid hidden under my shifter plate, so the switch wouldn’t take all the juice while starting the starter/generator. I honestly forgot how I wired it since it’s been years but works. 1 Share this post Link to post Share on other sites
FLtractor 223 #6 Posted July 2 1 hour ago, 702854boy said: I'd start with checking all your grounds and redoing the battery cables. That positive cable looks like it needed replaced 20 years ago. Any recommendation on which brand or replacement battery cables I should get? I’ll just get new ones Share this post Link to post Share on other sites
pfrederi 21,150 #7 Posted July 2 Please post a picture of the back of your ignition switch. For cables 6ga is adequate (4 ga better) but you need small terminal lugs 1/4" 2 Share this post Link to post Share on other sites
FLtractor 223 #8 Posted July 2 7 minutes ago, pfrederi said: Please post a picture of the back of your ignition switch. For cables 6ga is adequate (4 ga better) but you need small terminal lugs 1/4" Share this post Link to post Share on other sites
pfrederi 21,150 #9 Posted July 2 You need 1/4" or 5/16 terminal lugs. They can be a bit harder to find...but if you try to use the more common 3/8 you have to be very careful about putting then on the ignition switch that they do not touch something other than the terminal and you will need a couple washers so the bolt head does not slip through. 1 Share this post Link to post Share on other sites
rmaynard 17,582 #10 Posted July 2 I can't see all the wires, but if it is wired like it shows on the diagram below, everything should be fine, Share this post Link to post Share on other sites
Thegearhead0324 1,842 #11 Posted July 2 1 hour ago, FLtractor said: Any recommendation on which brand or replacement battery cables I should get? I’ll just get new ones I just went to the local parts store for different length cables, although I had to cut and crimp my own ends anyways, no brand specific. Share this post Link to post Share on other sites
FLtractor 223 #12 Posted July 2 19 minutes ago, rmaynard said: I can't see all the wires, but if it is wired like it shows on the diagram below, everything should be fine, What are these 2 triangle arrows representing? Share this post Link to post Share on other sites
Thegearhead0324 1,842 #13 Posted July 2 2 minutes ago, FLtractor said: What are these 2 triangle arrows representing? those are the grounds. Share this post Link to post Share on other sites
rmaynard 17,582 #14 Posted July 2 This is the back of my 857. B - Battery I - Ignition S - Starter G- Generator light IGN - to ignition coil 1 Share this post Link to post Share on other sites
FLtractor 223 #16 Posted July 2 17 minutes ago, rmaynard said: This is the back of my 857. B - Battery I - Ignition S - Starter G- Generator light IGN - to ignition coil What does the G stand for on your 2 cables here? Share this post Link to post Share on other sites
FLtractor 223 #17 Posted July 2 After calling 3 local hardware stores.. none have 4 gauge with 1/4 inch. so I found these online. seems to be exactly what I need to make it safest and easiest Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #18 Posted July 2 You can check a cable by connecting voltmeter leads to each terminal on the ends of the cable being tested or the stud/screw mounting the terminals . (+) on one end and (-) on the other terminal. Turn the circuit on and see if you get a voltage reading. You may need to reverse the leads if using an analog voltmeter. If the cable and it's connections to the terminals crimped or soldered on the ends are in good shape - no voltage reading. If the cable or it's end terminals are compromised some of the current will flow through the voltmeter giving you a voltage reading. This is known as measuring the voltage drop in the component. You want 0 volts. 2 Share this post Link to post Share on other sites
pfrederi 21,150 #19 Posted July 2 48 minutes ago, FLtractor said: After calling 3 local hardware stores.. none have 4 gauge with 1/4 inch. so I found these online. seems to be exactly what I need to make it safest and easiest the lugs should be good are the cables long enough??? 1 Share this post Link to post Share on other sites
rmaynard 17,582 #20 Posted July 2 1 hour ago, FLtractor said: What does the G stand for on your 2 cables here? Generator light 2 Share this post Link to post Share on other sites
sqrlgtr 3,927 #21 Posted July 2 1 hour ago, FLtractor said: fter calling 3 local hardware stores.. none have 4 gauge with 1/4 inch. so I found these online. seems to be exactly what I need to make it safest and easiest I got tired of trying to find cables that I liked so got all the stuff to make my own. Seem like they are always wrong length, have wrong size ends, etc... I got a hydraulic crimping tool from "horror freight " and never looked back, but Im always trading, buying , working on old WH tractors and stuff so may not be feasible for you to get into making your own. 2 Share this post Link to post Share on other sites
Thegearhead0324 1,842 #22 Posted July 2 What @sqrlgtr said, making cables or wires is easy, as every application is different, length, size, ends, etc. Measure, cut, strip, crimp, heat shrink or electrical tape and you’re good. 1 Share this post Link to post Share on other sites
FLtractor 223 #23 Posted July 3 Made some of my own wires such as for the coil already and the voltage regulator. 1 Share this post Link to post Share on other sites
oldlineman 1,809 #24 Posted July 3 (edited) Looks like PO didn't have the right size barrel lug so they split cable and used two smaller lugs. In itself is not bad but would not use for permanent connection. Reason being more contacts points, you are guessing size of barrel for conductor, and just not right.Just my option after working around electricity for over 50 years, although most was AC not DC, but many things very similar. Bob Edited July 3 by oldlineman 1 1 Share this post Link to post Share on other sites
FLtractor 223 #25 Posted July 9 Replaced battery cables with brand new tonight.. didn’t affect starter.. still didn’t even attempt turn over with charged battery and gas tank taken off tractor. Wanted to see if the starter worked without having to rescure tank again… still have to check the grounds off the voltage regulator that connect to the starter bolts.. but what grounds the starter that would prevent it from even attempting turn over if battery and cables are new… starter cable to ignition is still orignal and should be replaced but other than that I don’t know any wires that would cause this. Share this post Link to post Share on other sites
